Question about Electrical Supplies
How many amps does motorguide 743 43 thrust 12 volt use
2 Suggested Answers
SOURCE: Wire going to prop of Motorguide trolling motor shorted
Unless you are mechanically inclined, dont attempt this. Take the lower unit apart by removing the prop and removing the two bolts that hold the forward and aft housing to the center housing. Fwd being the cone shaped part. Pull the aft housing away from the motor so you can inspect the connections to the board that holds the brushes and the soldered wiring terminals. You should find the solder missing from at least one of the terminals that connects the wiring from the foot switch to the speed control windings inside the aft housing. Clean up the terminal and wiring and re-solder. Also re-flow the solder on the other terminals. Clean up the seals and the area where the seals meet the housing parts. Replace seals if damaged. Reassemble the lower unit and torque the bolts 45-50 in-lbs and no more otherwise you will fail the seals. This problem is due to a "cold" solder joint that creates a high resistance to elec current flow and heats enough to melt the solder. This is a result of poor quality control at the manufacturer. Good luck.
Posted on Dec 29, 2011
Steering cable broke motorguide tr109 45
any marina/boat dealer and yes u can..rather simple too.
Aug 06, 2012 | MotorGuide Tour Series Freshwater Bow...
Ihave a motorguide brute hyper 67 trolling motor can't get the 24 volts to work motor runs on 12 and 24 volts and all five speeds but don't have the thrust of 24 volts
This is most often caused by a faulty 24 Volt, section, (usually damaged output semiconductors, or the drive?) in the speed controller, fault, the only "Fix" is replacement. Simply obtain the entire speed controller and replace it "En Bloc" as it were. You will need to also obtain a service manual so you can disassemble it and obtain the parts numbers for the replacement parts.Otherwise take it to a professional and ask for a "Quote" as to prospective costings and go from there.
Oct 20, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
The switch keeps burning out and the motor turns about one turn and then will not turn again. Motorguide Trolling Motor Brute,767 67 lb thrust 12/24 volt Hyper Drive
i think its time to strip this motor out,, it sounds like its has a short in the field coil winding,,as its pulling far to many amps,,,,
Jul 01, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Lost #1 and #2 speeds
Contacts inside switch may have become corroded.
May 12, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
I bought a used trolling motor (motorguide brute 750 50# thrust) it has a 12-24 volt selector switch and three wires to hook up to battery, a black, a white, and a red. i'm assuming on 12v setting of...
the black wire goes to - and the red goes to + for 12 volts. If you want 24 volts you need to add another battery and run a jumper wire from the - of the first battery to the + of the second battery and hook the white wire to the - of the second battery. Here is a picture to help you.
Mar 15, 2010 | MotorGuide Electrical Supplies
Have a 56lbs thrust motorguide that is 12/24 volt. it has three wires how do i hook it up to have 24 volt
2 of the wires are line voltage and they share a common nuetral.if they hook to batteries then the common will go to the neg of each battery and the other leads go to the positive terminal
Dec 07, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
I HAVE A MOTORGUIDE MOTOR WITH THE FOLLOWING LABEL ON IT... "EP2.3HP" WITH SERIAL #SN 42663". LABEL ON TOP OF MOTOR IS "36 VOLT DIGITAL. VARIABLE SPEED". CANT FIND ANY INFO ON THIS MOTOR ANYWHERE? IT HAS...
I need the information off the tag motor frame volts amps and shaft type and I can tell you how to make it work. you didn't leave your e-mail address, also please rate. Thank you.
Aug 08, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
May 22, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Depth control tensioner knob. Plastic knob spins and breaks off the bolt. Would like to replace the bolt & Knob. Motorguide Magnum 752, 52 lbs. thrust, 12 volt. Cannot locate a parts diagram. Jim
I just entered your motor on Search (motorguide magnum) and there were several sites that are suppose to carry parts for it. If you contact them by computer or find their phone number, they can help you.
May 03, 2009 | Boating
Electrical Supplies Logo
41 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
