Question about Pure Protein Pure One Mini Series Ii Compact Portable Dab/Fm Radio - Black
PUREONE MINI STUCK ON SETTING CLOCK - Pure Protein Pure One Mini Series Ii Compact Portable Dab/Fm Radio - Black
How to set clock on musky
Unsure which model Musky. Example of DY28.
https://www.banggood.com/Musky-DY-28-Touch-Sense-Mini-Bluetooth-Speaker-TF-AUX-Colorful-LED-Light-Alarm-Clock-p-1084269.html?cur_warehouse=CN
Time Mode and Alarm Mode:
Press and hold MODE to enter the setting time mode, you can begin to set the time based on your local time.
In Alarm mode, long press MODE key to enter the setting alarm mode. Once you see a bell photo shines on the display, you can set alarm time as you need.
Musky DY 28 Touch Sense Mini Bluetooth Speaker TF AUX Colorful LED Light...
May 15, 2018 | Audio Players & Recorders
How do I get the clock off of military time?
There is no setting to change it to a 12-hour clock. So, your stuck with the 24-hour clock. However if there is a firmware update, it could add a option for a 12-hour clock. So you could check for that on the Visual Land website:http://www.visual-land.com/downloads.html.
Jan 22, 2012 | Visual Land V-Touch Digital Media Player
My @ key always come up with " where do i change
In language field (left of clock field) or if you hav it disabled, go to Control Panel and you should see Clock, Keyboards and Language settings....
Feb 17, 2011 | Dell Inspiron Mini 10 Notebook
Sony camcorder model dcra-c123
If you bought your camera from a shop then you will have an inst book, the setting are clearly listed how to do what you ask.
Jul 06, 2010 | Sony Handycam DCR-HC20 Mini DV Digital...
Setting clock in 12 hour format instead of 24hr
You can download the manual here: www.topeak.com/mediafiles/assets/341/file/1
By performing a reset and setup under section A. of the manual you can select 24 or 12hr time.
Jan 06, 2010 | Topeak Panoram V12 Mini 12 Function Cycle...
WENT TO SET CLOCK CAME UP WITH 5A6 ON CLOCK SETTING NOW OVEN WILL NOT COME ON
Your range is stuck in SABBATH mode. You should be able to press and hold the clock button for 5 seconds to reset.
Nov 03, 2009 | Maytag MER5552BAW / MER5552BAQ /...
I cant set the clock on my pioneer deh 21001b cd player
Adjusting initial settings
1 Press SRC/OFF and hold until the unit
turns off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select one of
the initial settings.
CLOCK SET (clock)—AUX (auxiliary input)
# To return to the previous display, press
DISP/BACK/SCRL.
# To return to the main menu, press and hold
DISP/BACK/SCRL.
# To cancel initial settings, press BAND/ESC.
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select
CLOCK SET in the initial setting menu.
Refer to Adjusting initial settings on this page.
2 Press MULTI-CONTROL to display the
setting mode.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
Sep 26, 2009 | Pioneer DEH-2100 CD Player
Setting the time
I believe that to set the time, you'll need to have the key on, but the radio powered off. Then, you'll have to press the "Func" key and now you can cycle the menu to get to "clock adjust".
Aug 10, 2008 | Pioneer Car Audio & Video
Sony MHC-2800 setting the clock
Hi, it's simple. First press "Timer1" and Timer2" buttons together, clock on display will start blinking, by cursors "Up/Down" you can change the value of hours and minutes (switching between hours/minutes by "Left/Right" cursor). To save set time press "Memory". Enjoy your set clock :)
Jan 07, 2008 | Audio Players & Recorders
Pure Protein Pure One Mini Series Ii Compact Portable Dab/Fm Radio - Black Logo
24 people viewed this question
Top Pure Protein Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Pure Protein Audio Player and Recorder Expert? Answer questions, earn points and help others
