Question about Craftsman Garden
Model 917270750 how to adjust shifting lever
How to adjust the column shifter on a 1951 chevy deluxe car
Hello Jeff Poe,
Assuming you are talking about the MANUAL TRANSMISSION... simply because of the "FASTWAY" product you are posted under... (appears to be the old "three on the tree") column shifter.
And
Assuming ALL your shift bushings are new & firm
You can have an assistant find and hold the neutral
(fully disengaged... but middle of the "H" position)
In the car: Have your assistant select the first & reverse positons. Under the vehicle: Carefully observe the throw in each direction.
Underneath at the transmission shift lever: Pull the cotter-pin and remove the washer from 1st (1st & reverse) gear shift lever.
Manually operate the shift lever to feel the exact center of its disengaged position (after assuring your assistant is holding the shift lever in the middle of the lever throw... adjust the lever to lengthen or shorten to precisely match that centered position.
If the vehicle has been used... very little adjustment should be required. Place the pivot pin, restore the washer and fit a new cotter-pin.
Repeat the process for the 2nd (2nd & 3rd) gear shift lever.
Hope this helps.
https://en.wikipedia.org/wiki/Powerglide
Manual transmission
Aug 01, 2016 | Fastway Adjustable Linkage Guard Trail...
How do I REPLACE SHIFT CABLE
rtm? no symptoms so i must guess, ill say , cant shift. and is not park lock out causing that.
want to read the manual or me to you.'?
ill guess you.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
click 1996 to 2001
it replaces like all cables do
detach both ends and remove it. if clamps seen those too.
what matters is adjustment is needed.
some have 2 cables, one to gear box and one to ignition switch.
Chapter 21, page 150 states
REMOVAL
(1) Shift transmission into Park.
(2) Remove shift lever bezel and necessary console
parts for access to shift lever assembly.
(3) Disconnect cable at shift lever and feed cable
through dash panel opening to underside of vehicle.
(4) Raise vehicle.
(5) Disengage cable eyelet at transmission shift
lever and pull cable adjuster out of mounting
bracket. Then remove old cable from vehicle.
INSTALLATION
(1) Route cable through hole in dash panel. Fully
seat cable grommet into dash panel.
(2) Place the auto transmission manual shift control
lever in "Park" detent (rearmost) position and
rotate prop shaft to ensure transmission is in park.
(3) Connect shift cable to shifter mechanism by
snapping cable retaining ears into shifter bracket
and press cable end fitting onto lever ball stud.
(4) Place the floor shifter lever in park position.
Ensure that the pawl is seated within the confines of
the adjustment gauge clip.
(5) Snap the cable into the transmission bracket so
the retaining ears are engaged and connect cable end
fitting onto the manual control lever ball stud.
(6) Lock shift cable into position by pushing
upward on the adjusting lock button.
(7) Remove and discard the shift cable adjustment
gauge clip from the park gate of the shifter.
easy?
Aug 25, 2015 | 1996 Jeep Cherokee
1991 Ford F150 won't shift into park or reverse. Will go into neutral and drive, and the linkage at the transmission moves ok
The linkage may be out of adjustment preventing the shifter from moving into reverse or park.
One way to test this is to disconnect the linkage and manually move the lever on the transmision making sure that it can be set into park. Also try moving the lever counting each click from park to low gear to make sure it is clicking into each gear. If this works then the linkage is probably out of adjustment.
On the link cable there is typically a bolt in an oval shaped metal near the transmission shift lever.
1)Detach the shift cable from the transmission shift lever
2)Put the transmision shift lever in the park position, and also the shifter in the cab
3)Loosen the adjustment bolt
4)Reattach the cable to the lever
5)Tighten the adjustment bolt in place
6)Confirm that you can shift through all of the gears
Hope this helps
Dec 01, 2013 | 1993 Ford F150 SuperCab
How do I adjust the automatic transmission shifter cable, sometimes it will not go right into park. This could be dangerous. Thank you
Most of them (you didn't mention what model you have) have a slot at the end of the cable that is held in place on a stud. The slot allows adjustment in the cable. Have someone move the shift lever so you can see what direction park is in on the lever coming out of the transmission. Loosen the nut and push the lever as far into park as it will go to be sure it is in park all the way. Make sure the shift lever is in the park position. Do not let anyone touch the shifter now and make sure it is fully in park. Tighten the nut on the lever now. It should be adjusted properly at this point. Go though all the gears and make sure they work properly to verify the adjustment.
Aug 11, 2011 | Mazda Protege Cars & Trucks
HAVE A 1989 FORD F-150 WITH AUTO TRANS THAT YOU CAN'T SHIFT OUT OF THE "PARK" POSITION AT THE STEERING COLUMN. THE TRANY CAN BE SHIFTED AT THE TRANS WHEN LINKAGE IS DICONNECTED.I THINK THE...
What trans? AOD? This is 1992 F Series, all I have.
Shift Controls, Automatic Transmission The transmission shift control linkage or cable transfers the transmission operating mode from the selector lever to the transmission. The indicated transmission position on the steering column is transferred to a shift lever on the bottom of the steering column. On vehicles equipped with cable-operated shift systems, the indicated position of the transmission selector lever is transferred to the transmission through the shift cane, then to the cable, and down to the transmission manual shift lever at the transmission. On vehicles equipped with shift rod assemblies, the rod transfers the indicated transmission selector level position through a bell crank assembly to a control rod. The control rod transfers the indicated position to the transmission assembly.
Automatic Transmission Manual Linkage Adjustments
  1. With the engine stopped and the parking brake applied, place the transmission selector lever at the steering column in the D (DRIVE position) for C6 applications and in the (D) (OVERDRIVE position) for AOD and E4OD applications, and hold against the D or (D) stop by applying a three-pound force to the selector lever knob.
  1. Loosen the shift rod adjusting nut at point A. Refer to the following illustrations.
  1. Shift the manual lever at the transmission into the (D) (overdrive) position for E4OD, by moving the lever all the way rearward, then forward two detents.
  1. With the selector lever and transmission manual lever in the(D) position, tighten the nut at point A to 17-24 Nm (12-18 ft-lb) torque. Use care to prevent motion between the stud and rod.
  1. Remove the three-pound force from the steering column selector lever knob.
  1. Operate the shift lever in all positions to make certain that the manual lever at the transmission is in full detent in all gear ranges. Re-adjust the linkage if required.
  1. On F-Super Duty Chassis Cab and Motorhome and Commercial Chassis recheck for correct operation of the automatic transmission selector indicator (PRN(D)21). Refer to Section 11-04A, Steering Column, Shift Rod Within Tube. ani_caut.gif CAUTION: Under no circumstances will it be permissible to adjust linkage in any position other than the(D) position for E4OD applications.
Automatic Transmission Shift Cable Adjustment
  1. From inside the vehicle, place the column shift select lever in the DRIVE position (C6) of the OVERDRIVE (AOD and E4OD). Hang a three-pound weight on the selector lever.
  1. Raise vehicle on a hoist.
  1. Remove the shift cable from the transmission lever ball stud.
  1. Pull down the lock tab on the shift cable body.
  1. Position the transmission shift lever in the DRIVE position (C6) or the OVERDRIVE position (AOD and E4OD). This is three detents from the front-most lever position with the first position counting as one.
  1. Connect the cable end fitting to the transmission lever ball stud.
  1. Push up on the lock tab to lock the cable in the correctly adjusted position.
  1. Lower vehicle down from hoist and remove the three-pound weight from the column shift select lever.
  1. After making the adjustment, check for park engagement. Check the transmission control lever in all detent positions with the engine running to make sure correct detent/transmission actions. Readjust if necessary.
Jun 21, 2011 | Ford F-150 Cars & Trucks
My transmission will not go into park. how do i fix that
  1. Install the shift cable end of the shift cable to the transmission shift lever stud ball.
  2. Install the retainer to the shift cable and transmission bracket.
  3. Feed the shift cable through the floor panel.
  4. Lower the vehicle.
  5. Adjustment Procedure
    1. Ensure that the shift cable is not restricted.
    2. Place the shift lever into the NEUTRAL position.
    3. Position the shift cable to assume a natural routing. The shift cable must be free to move 20.0 mm (0.80 inch) axially during the adjustment under adjustment spring loads.
    4. Pull the cable end completely forward and release it. (When the cable is pulled completely forward and released, the adjustment spring will position the cable to its most rearward position.) Notice: Do not pull the shift lever ball stud forward of the transmission shift lever ball stud during installation. Pulling the shift cable end forward of the transmission shift lever ball stud before installing the shift cable end to the transmission shift lever ball stud will result in a poor adjustment.
    5. Connect the end of the shift cable to the transmission shift lever stud ball.
    6. Press the locking tab IN in order to secure the shift cable to the transmission bracket.
Oct 13, 2009 | 1984 AMC American Motors Eagle
Clucth not disengauging....
try this.you have 2 shifter cables.one is select cable the other is shift cable.first put the transmission selector lever in neutral.then move transmission shift lever to 4th gear.depress clutch to if necessary to shift.move the shift lever to the 4th gear position until contacts stop.then you turn the adjuster turn buckle so the shift cable eye aligns with the eye in the gear shift lever.when installing the cable eye. make sure the flange side of plastic bushing at the shift cable end is on the cotter pin side.the cables should be adjusted so the clearance between the shift lever and both stoppers are equal when the shift lever is moved to 3rd and 4th gear. move the shift lever to each position and check that the shifting is smooth.
Jul 12, 2009 | 1996 Mitsubishi Galant
1999 Dodge Intrepid...shift lever wil shift gears
I believe that the cable has to be adjusted. Most cases, the cable adjustment is off. Worst case senario, is the bushing in tranny is worn out.
Jun 22, 2009 | 1994 Dodge Intrepid
2000 Mercury Villager: Is there a shift lever adjustment? When placing foot on brake pedal and pulling shift lever rearward it doesn't feel like the transmission is completely disengaging and it is...
You may have a loose shift linkage in the steering column. Remove the upper and lower plastic covers behind the steerong wheel (5 or 6 philips head) and see if you have any loose torx head or allen head screws. Ea
rlier models had this isue.
Also, go to this site for Villager Quest help.
http://autos.groups.yahoo.com/group/villagerquest/
Here's adjustment procedure too
SECTION 307-05: Automatic Transaxle/Transmission External Controls 2000 Villager Workshop Manual
GENERAL PROCEDURES Cable Adjustment —Shift Control
  1. Place the gearshift lever in PARK (P) position.
  1. Raise and support the vehicle. Refer to Section 100-02 .
  1. Remove the splash shield.
  1. Loosen the shift cable nut.
  1. Position the shift linkage in PARK (P) position.
  1. Tighten the shift cable nut.
  1. Move the gearshift lever through the entire shifting range.
  1. Verify that the engine will crank with the gearshift lever in PARK (P) or NEUTRAL (N) position.
  1. Adjust the transmission range (TR) switch as necessary, refer to Section 307-01 .
Item Part Number Description 1 043B13 Driver side air bag module 2 — Steering wheel nut 3 3600 Steering wheel 4 — Radio volume control cover 5 — Air bag sliding contact electrical connector access panel 6 — Cruise control cover 7 14A664 Air bag sliding contact 8 13K359 Multifunction switch 9 — Tilt wheel lever 10 13318 Turn indicator cancel cam 11 — Steering column assembly 12 — Steering column mounting bracket nuts (4 Req'd) 13 3C695 Lower column shroud 14 — Steering column opening cover nuts (3 Req'd) 15 — Steering column lower yoke bolt 16 3N725 Steering column lower yoke 17 — Steering column clamp bolt 18 3C695 Upper column shroud 19 7210 Gearshift lever
May 05, 2009 | 2000 Mercury Villager
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
