Question about Whirlpool LSB6200KQ Top Load Washer
Squealing noise during spin cycle
When we moved our washer and installed it in the new place, it started making a very loud squealing noise during the spin cycle. The noise occurs only when the motor is running the spin cycle. It stops when the motor shuts off. Is this something I could repair myself?
  • 6 more comments
  • mad hunter Nov 04, 2007
    same problem here, but it's a beltless direct drive washer help!!!
  • Anonymous Jun 02, 2008
    squealing and won't drain
  • Anonymous Mar 12, 2014
    washer makes noise during spin cycle
  • Anonymous Mar 15, 2014
    Hi. My washer is making a grinding noise during wash cycle. Stops and starts with each change in direction.
  • Anonymous Mar 27, 2014
    high pitch noise while agitator works. can move agitator freely when turned off
  • Anonymous Mar 28, 2014
    washer made loud noise and stopped during cycle
  • Anonymous Mar 30, 2014
    Won't spin
    when i spin cycle there is a loud noise and the faster it spins the louder it gets
  • 4 Answers
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
Posted on Jul 08, 2007
3 Suggested Answers
Coldcut
  • 1554 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
The belt is slipping and needs replaced.
Posted on Jan 26, 2008
clusterfx
  • 67 Answers
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Loud noises during spin cycles
Hello, If the noise is a squealing or grinding sound, you are likely looking at a bad seal and bearing.
If the noise is a knocking sound, it's more likely a suspension or out of balance condition.
Thanks
Jun 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Loud squealing noise during spin cycle.
Please keep in mind, I'm attempting to diagnose your unit without being there and with very little information.
From my experience, I would think you have a bad belt. They get stretched over time and start squealing in the spin cycle. If you don't change it, it will make a noise in every cycle until it comes off.
NOTE.
When changing belt. Check and be sure the pulleys have no play on their shafts. They also go bad. It's better to fix it all now than one to have to repair four or five times this year. Good luck!
Please rate solution
Sep 25, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
During the spin cycle, the machine shakes violently and dances across the floor. It has a loud squealing noise during this. My Performa is only about 14 months old. This is very disappointing for a Maytag.
Look in owners manual. I think these washers have a 1/2 hp. variable speed motor. make sure the washer is level from front to back and side to side, if its not that could be the problem. The motor has a lot of force, the squealing could be a bad bearing not sure.
Aug 24, 2009 | Washing Machines
My Maytag HAV2557AWW Loud Noise
pull hoses off the pump and see if there is anything stuck in it
Jun 12, 2009 | Maytag HAV2557 Top Load Washer
Loud squeal during wash and spin cycles, maytag atlantis washer
hope this helps
Feb 23, 2008 | Washing Machines
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Whirlpool LSB6200KQ Top Load Washer Logo
3,054 people viewed this question
Sal De
Marvin
Marvin
jimorris77
