Question about Garden
Kubota b7510 leaking water pump
New pumps simply continue to leak
  • 316 Answers
SOURCE: leaking antifreeze buick century 1998
Check your heater hoses. It sounds like your leak is a hose.
Posted on May 23, 2009
Molson02536
  • 3854 Answers
SOURCE: We replaced the water pump and radiator - leaking coolant
It could be leaking thought the gasket or radiator hose. Remove the water pump and replace the gasket, inspect the water pump first to make sure it's not leaking through the radiator hose and weep holes, if it is leaking through the weep hole then replace the water pump again since the water pump is faulty. good luck and keep me posted.
Posted on Jun 29, 2009
jdlipscomb41
  • 157 Answers
SOURCE: kubota diesel lawn tractor overheats
check the radiater
Posted on Sep 18, 2009
  • 811 Answers
SOURCE: Coolant leak when parked near water pump
run pressure test on coolant system, tighten all hoses, has water pump been changed?
Posted on Sep 29, 2009
  • 10 Answers
SOURCE: jet pump does not pump water
I had a similar problem and as a last resort took the pump apart and cleaned it and the jet. It's a very old pump but works ok now.
Posted on Oct 24, 2009
Onga 4352 Spa Pump is leaking from the opening in the bottom of the pump. I have opened it & siliconed the Oring seal but it continues to leak. Any suggestions?
I had a new pump brought to me once that continued to leak after replacing the shaft seal three times. Careful examination revealed a sand casting fault in the pump body. The water was leaking through the body of the pump. Have you replaced the shaft seal?
Nov 04, 2014 | Plumbing
Water pump leaks
It will be leaking from either the housing seal or bearing seal - if it's the housing seal it will be leaking from the edge of the pump, if it's the bearing seal it will be leaking from the centre of the shaft or from a small bearing drain hole.
You may be able to get a housing seal, but if it's coming from the bearing, it will need a new pump...
Jun 21, 2014 | Smart Vehicle Parts & Accessories
Kubota m59 hyd system not strong
Check your hydrolic fluid. If low, be sure there are no leaks. If your fluid is topped off and there are no leaks then your pump may be going bad.
Sep 16, 2013 | Cover My Tractor Tractor Cab-Enclosure for...
Kubota M 5030 2.8 6 cyl. Diesel in oil sump. Why?
Diesel gets in the sump from an seal leaking in the fuel pump through to the drive gear and out into the sump. If it has an inline pump( one where the injector lines are in a row at the top of the pump) the fuel will be leaking past the plunger elements and into the pump sump which then drains back tot he engine sump. IF it is slight but consistent sometimes injectors will dribble when shut down and the fuel will by pass the piston rings into the sump. Talk with a diesel pump and injector repair specialist for any faults particular to the Kubota fuel system
Apr 03, 2013 | Cars & Trucks
Water pump leak
Pumps leak at a 'weep" hole just under the pulley. This allows pump to let fluid escape after seal fails. Many pumps will continue to work for a long time before total failure. Just check radiator fluid level often. Your car may not justify an immediate fix due to cost of new pump replacement.
Sep 01, 2012 | 1995 Cadillac DeVille
Put new water pump on and engine continues to
The old gasket was not cleaned fully off. A very small peice will cause this to leak. Mechanics use 3M abrasive disc to clean off the gaskets which works fasst and clean on any small drill
May 15, 2010 | 1998 Jeep Grand Cherokee
Why is there a water leak coming from the water pump?
i would say you answered your own question, if there is water leaking from the water pump i would say the water pump is leaking and it needs to be replced,either the bearing is bad and its leaking out the shaft,or the seal is bad and its leaking outta there either way you need a new water pump,check the belt for wear when you replace it,,
Oct 07, 2009 | 1998 Dodge Caravan
I have a leak in the water pump on my Kubota F2400 and also a oil/hydraulic fluid leak somewhere underneath the engine. I need to repair them. Help.
your rear seal (oil) pump and mybe your engine seal both are out. do you have water in the pump oil? if so your water seals are out too. need to get A comlete seal kit for the pump.
Oct 05, 2009 | Garden
Replaced water pump for the 5th time and it leaks from the hole u
No , it's not normal to leak.
Either , water pump is bad ( 5 times ? )
or instalation was bad or more likely , leak is not the water pump at all
May 09, 2009 | Ford SVT Cars & Trucks
1998 plymouth voyager3.3l has leak at water pump behind pulley
First of all, changing thermostat will not fix your water pump leak. Obviously defective pump or install. Be sure to take a closer look, in case it's a loose hose in the area. Leaking from behind pulley, usually calls for new pump. What I would do though, is take it back to original repair shop & question them about any warranty that may apply. Some have 1 yr. some have limited lifetime etc. If you can obtain a copy of work done, the part number on the pump should give you what you need to call (or shop can call) and inquire about that particular part number as far as warranty goes. (I'd make the call myself, ahead of time, so I know.) That way, perhaps the shop who originally installed it may feel some kind of obligation to replace it at a reduced fee, as in labor only. ($27 for new pump) . Be nice, play a little dumb, it may help, and if they want you to pay the whole shot over again, go elsewhere for estimate.
Feb 21, 2009 | 1998 Plymouth Voyager
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
