Question about Electrolux Cleaner Lux 6000 Vacuum
Replace powercord for lux 6000 - Electrolux Cleaner Lux 6000 Vacuum
My daughter cleaned up the babys ***** with vacum now it smells lie throwup everytime we use vacum.we cleaned the hoses still smells .I thinits in the motor .can i clean the motorany suggestions before i...
SInce the damage is done we cannot but think of a solution. It seems the internal filters , the hose and possible the linings within can be slightly clogged.
The only option left to us is to get the above sections cleaned, the filter replaced, the motor flushed with a wash of kerosene-- you must remove the motor and carefully wash and dry all the parts, the hose and replace the filters.
I am sure you can use surgical gloves and mask in case the odour is annoying but it is worth trying before you need to dump a good machine.
Good Luck
Aug 19, 2011 | Electrolux Cleaner Lux 6000 Vacuum
Need the schematic for the 6000
You can down load it on line at the electrolux site. Just google that name and it will come up. Or call their number on the site and they can send you one.
Nov 30, 2009 | Electrolux Cleaner Lux 6000 Vacuum
How do I replace the Powercord on a Fantom XT64K Vacuum. The powercord shorted where is comes out of teh housing. I need to open up the unit & replace but need a service manual of instructions. Thanks...
I have done this several times, it's some what simple just take the unit apart and use the old diogram to replace the new one. Or take a digital photo of it opened so you have your own scematic. You should be able to purchess the cord at your local hardware store "be sure you get the same insulated cord" the numbers will be located all down the old cord. Also very important. If you have never done this before I recomend you have someone with this type of knowledge. For safty reasons. good luck and hope you save some $$$$$
Nov 14, 2009 | Vacuums
How can i unclog a Lux 6000 vavuum
The Lux 6000 has a bad record of getting clogged. When it is clogged it will make a high pitch sound . First thing to do is turn the machine on and take the hose out of the top of the vacuum. If the noise changes, the hose is the part that is clogged. Take the hose out and use a broom handle to push the blockage out the other end. You can unscrew the flexable hose from the metal part to make it easier.
If the noise dosen't change when you take the hose out UNPLUG the cord and stand the vacuum up on the handle. You will need to do this against a counter. The black duct hose that is between the main body and the part that has the brush will pull out from the bottom part. You can see into the bottom part and into the duct hose. Use some needle nose pliers to pull the trash out. If the hose is blocked, unscrew it by turning it clockwise. If the blockage is up into the main body, use a coat hanger to try to clear the blockage. You can also insert the hanger into the top where the hose wand goes.
If all fails, take it to your Elux. dealer.
It's a lot easier to do than tell how.
Jul 20, 2009 | Electrolux Cleaner Lux 6000 Vacuum
Lux 7000 Power Nozzle bulb replacement
There should be some screws that you remove from the bottom. Then pry up from the back and the top should come off.
May 11, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Replace Powercord
It has a cord relief to hold the cord in near the bottom, you will have to pull that out, the cord goes in there and comes out by the motor where the the wires connect. So you will have to pull the motor cover off to get to where they hook up to.
Apr 15, 2008 | Hoover Company Wind Tunnel U53019 Upright...
Aerus lux 5500
Hi.
Check & replace any filters that are fitted to machine.
Replace bag with new,
Clear hose of any foriegn items & check floor tool for blockages.
http://dysonmanuals.llc.nu/
Chris..
Dec 18, 2007 | Electrolux Lux 5500 Canister Vacuum
Vacuums Logo
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
