Question about Sony VAIO L Series SVL24112FXB - Core i5 3210M 2.5 GHz - 24" LED
Factory restore command for sony svL24112FXB - Sony VAIO L Series SVL24112FXB - Core i5 3210M 2.5 GHz - 24" LED
Hello, how do i do a factory reset with command prompt. the ususl method does not work as only optionsrepair and recovery ect are there. no reset option. dell latitudee7240 win 7. rstrui.exe. gets is
The instructions are:
  1. Turn on the computer.
  2. Press and hold the F8 key.
  3. At the Advanced Boot Options screen, choose Safe Mode with Command Prompt.
  4. Press Enter.
  5. Log in as Administrator.
  6. When Command Prompt appears, type this command: rstrui.exe.
  7. Press Enter.
  8. Follow the wizard instructions to continue with System Restore.
Restore To Factory Settings - Guide for Windows XP, Vista, 7, 8, 10..
before you try this go to this link and have a read up first.
factory reset with command prompt Google Search
Oct 29, 2017 | Command Computers & Internet
Factory restore using command prompt?
Holding the F11 key at startup will bring you to the factory restore prompts for Lenovo PCs. The factory reset is driven from the ROM BIOS and not the command prompt.
Oct 13, 2013 | IBM ThinkPad Computers & Internet
What is the command prompt in the HP Pavilion a6037c Vista recovery partition that allow me to type the command to recover to the factory settings.
You can access the HP Recovery Manager software using the "F11" command during the boot-up process. The Recovery Manager is a preinstalled utility that can help you resolve issues on your computer system that affect its proper function, such as viruses, system errors or hardware corruption. Restore your computer only as a last resort, since all the files stored on the hard drive will be lost during the process. The restore process can also be helpful in wiping the computer clean before passing it along to another user.
Restart the computer. Press the "F11" key when the "BIOS" messages appear during the start-up process to open the "HP Recovery Manager." This step must be completed before Windows has a chance to load. Click "System Recovery" and click the "Next" button. Click "No" in the Microsoft Restore window that appears and click "Next." Click "Next" in the "System Recovery" window to initiate the restore process. The hard drives will be reformatted and the computer's software returned to the factory settings. Click "Finish" to restart the computer with the original operating condition in place.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&product=18703&docname=c01895783 - RecoverOS
Jan 27, 2013 | Computers & Internet
I want to restore my dell inspirion 1721 to factory settings i try the f8 key option but in the advanced boot options there is no "repair your computer" option. what can or should i do?
Your laptop should of come with a disc to restore it back to the factory setting what windows are you running?There should be a restore point you can go back to
Jan 12, 2013 | Dell Inspiron 1721 Notebook
How to reset zebra p4t ribbon cartridge?
Below are the command sequences that can be applied to default the parameters referenced above:
Examples:
! U1 do "device.restore_defaults" "bluetooth"
! U1 do "device.restore_defaults" "ip"
! U1 do "device.restore_defaults" "wlan"
! U1 do "device.restore_defaults" "power"
! U1 do "device.restore_defaults" "display"
The zpl parameters can be restored to their factory defaults on the P4T series, RW series and QLPlus series by deleting the ZPL_CFG.CFG file. This binary file contains the zpl settings and will be recreated automatically when restarting the printer. The newly created file will contain the binary equivelant of the factory zpl default settings.
The ZQ500, QLn series and the iMZ allows the ^JUF and ^JUN command to be sent to restore parameters to their factory default condition.
Example: ^XA^JUF^XZ^XA^JUN^XZ^XA^JUS^XZ
Please note that the iMZ uses line print mode by default. The command ! U1 setvar "device.languages" command may need to be adjusted to se the iMZ back to ZPL if necessary.
! U1 setvar "device.languages" "zpl"
Zebra Technologies Restoring Factory default settings with Mobile Printers CCTV Networking Technical Support
Feb 04, 2011 | Zebra 05555bk110d 4.33 X98' Tt Wax/resin...
Set is stanby for ashort while
Try this... via remote commander ,go to menu then settings then scroll down to restore factory settings then press enter to restore factory settings... if it doesn't work it needs repair..
Nov 05, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How to restore to factory setting from command prompt
Turn on computer and tap F8 key till you get to the options screen(black screen).You will see "restore my computer to factory settings.
Apr 11, 2010 | Toshiba Satellite A215-S4747 Notebook
Command mode change disabled remote
According to Sony, if you turn the power on and hold the Enter key and the #1 key down together for at least 3 seconds, everything will default back to factory settings.
Mike
Feb 01, 2009 | Sony RDR-VX515 DVD Recorder/VCR
How To reset to Factory deffault NBX V3000 from Console Cable
NBX runs on VxWorks. Goole for the command on VxWorks to restore the FD settings.
Nov 18, 2008 | 3Com NBX® V3000 (3C10600BUS)
Lack of responce of DHG-HDD250 to command when recording scheduled program
Restore unit to factory defaults. Use the remote control, go to MENU, SCREEN, enter 9012, then select factory defaults.
Mar 18, 2008 | Sony DHG-HDD250 200-Hours Video Recorder
Sony VAIO L Series SVL24112FXB - Core i5 3210M 2.5 GHz - 24" LED Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
