Question about Fuji FinePix S304 Digital Camera
Lens Jamming Anyone had problems with the camera lens jamming a soon a you switch on. This is the second time the problems has occured the first time the camera was just out of warranty so I paid £100 to fuji for an extra warranty plus repair. Fuji said they replaced the complete lens mechanism. Now a year later I am having the same problem just as the repair warranty has expired, I am reluctant to pay another £100 as you can now buy better cameras for less. Any ideas would be appreciated.
    Genius:
  • 2,985 Answers
Buy the better camera. Really -mending cameras is a big No No
Posted on Jul 10, 2007
Lens error restart camera is the msg i am getting , I restarted and nothing resolved
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them. These steps include tips for lens errors occurring from a dropped/damaged camera.
But if this problem just randomly occurred (i.e. you did NOT drop your camera), then also see this video. It's likely that just some sand or other particles are jamming the gears or lens of your camera. The simple steps in this video can overcome that problem.
Dec 27, 2011 | Canon PowerShot A630 Digital Camera
Nikon coolpix s3000 lens error
Remove battery replace and switch on as you tap on the lens hood, repeat to see if the lens jamming is released. If not you will require the help of Nikon service for the estimation and spare.
Sep 28, 2010 | Nikon Coolpix S3000 Digital Camera
Sony cybershot dsc-w55
Problem is in the lens assembly. My friend at www. f16camera service.com.au has shown me where this camera can have problems with gears jamming in the stepping motor gearset & other times the lens drive assembly. Best taken to a specialist as the pieces are just so small.
Jun 19, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Lens Error
This message appears when a malfunction in the lens occurs. It could be a grain of sand jamming a gear or a barrel out of alignment. In any case, the lens is not serviceable, you would need to take your camera to your nearest repair centre to have it looked at.
Apr 15, 2009 | Canon PowerShot A560 Digital Camera
System Error
I had the same problem. It was because the lens had just begun to retract and then jammed. I tried pushing back it in to no avail. I was considering it was time for a new camara anyway. Hoping to get a little more life out of it, with nothing to lose I was about to take it apart to see if I could clean out any obstruction as other posts had reccommended. Before I did that, I let my Mr. Goodwrench cousin take a look at it. Instead of trying to force the lens back in, he pulled it out. Apparently the slight play in the lens allowed him to do so and whatever was jamming the lens from retracting must have fallen out. Suddenly, the lens retracted and the camara is working fine. So before you throw the camara away or take it apart, try pulling out on the lens housing. You may also have to move it slightly back and forth while pulling out to get whatever is jamming the lens to move out and away releasing the lens to retract again.
Oct 25, 2008 | Nikon Coolpix 775 Digital Camera
Canon 20d - lens stuck / jammed
HI BRIAN ,,I AM SAGHA CAMERA REPAIRER,I THINK UR PROBLEM OCCURS DUE TO JAMMING OF PLASTIC MOUNT ON THE METAL BODY OF 20D.TRY THIS
1} LUBRICATE THE JUNCTION WHERE LENS GET ATTACHED TO THE BODY WITH KEROSENE THEN TRY TO RELEASE THE LENS.REMOVE THE BATTERY FROM CAMERA ,TRY AND HEAT UP THE JUNCTION WITH HAIR DRYER A LITTLEBIT THEN TRY TO RELEASE THE LENS.
2}IF THIS THING ALSO DOESN'T WORK THEN YOU HAVE TO SACRIFICE THE LENS PLASTIC MOUNT PUT SOME SHARP KNIFE LIKE OBJECT IN THE JUNCTION OF LENS & CAMERA & THEN PUSH IT UPWARDS WHICH WILL BREAK ONE OF THE PLASTIC LENS MOUNT COLLOR AND LENS WILL COME OUT WITHOUT DAMAGING YOUR CAMERA .LATER YOU CAN GET REPLACED THE LENS MOUNT FROM SERVICE PERSON. BUT NOW ATLEAST YOU CAN USE CAMERA WITH OTHER LENSES.
Sep 29, 2008 | Canon EOS-20D Digital Camera
Telascopic lens will not move out
here are the tips you need to be followed
#1:
Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on.
#2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
#3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens.
#4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
#5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum
#6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand.
Sep 05, 2008 | Cameras
Casio ex-z500 jammed with lense stuck in out position; gears grinding when power applied
I have just experienced the same problem with the lens jamming. I bought it for my wife having been impressed with the EX-Z500 my daughter bought. She had the same problem last year and paid for an expensive repair, then I found that her partner's sister had also bought one and.......you've guessed it...the lens jammed on that one too.
So that's another three Casio EX-Z500 digital cameras to add to your list of Casio generic lens jamming problems.
Apr 07, 2008 | Casio Cameras
Zoom problem
Ive seen this three times and everytime its been something differant. Fist was the rocker switch was jammed. easy fix as dirt was in there. Second was a small serface maounted capacitor in the zoom interface circuit. An third never found the problem as we thought it was a limit switch in the lens itself but the customer never paid for a new lens assy so we didnt order it. Good luck
Jun 21, 2006 | Canon XM1 Mini DV Digital Camcorder
Fuji FinePix S304 Digital Camera Logo
55 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
