Question about Huffy Cranbrook 24Inch Cruiser Bike
How do i put the handle bars on the bike - Huffy Cranbrook 24Inch Cruiser Bike
How to adjust handle bar
Every bike has same way to adjust handle bar and that is pretty easy to adjust.
Please watch movies I attached.
Jan 16, 2014 | Genesis 29" Astra Mens Beach Cruiser Bike
I feel like I'm missing something. I can not attach the handlebars to the bike. I have one long screw, a bolt and some small black cylinder cut on an angle. The instructions are not helpful because...
the cylinder cut on an angle is what the long bolt should bolt to, put the cylinder below the handle bars, and drop the long nut down through the handle bars and into the cylinder, ( the hole in it should be threaded,) only start the bolt so it hangs onto the cylinder, then feed that into the top of the neck hole, where the handle bars slide into,, once the desired height is ok,, tighten that bolt, the cylinder will come up at an angle and tighten the neck and handle bars !! Good Luck
Jul 02, 2011 | Dynacraft Girls 16" Barbie Bike
I have a question about putting together a disney princess 12in bike, I put the handle bars in, but they don't seem to attch to anything. And the owners manuel is for multiple different bikes, so it is not...
If I understand your question, you put the handlebars into the front steering assembly but they don't attach.
On top of the handle bar is a screw that when it is turned in pulls a wedge shaped bottom piece up. When this is done once the handlebars are in the steering unit, the handlebars lock up and can't rotate or pull out.
If that doesn't answer your question, let us know.
Gary
Dec 21, 2010 | Huffy 12 in. Girls Disney Princess Single...
How do you raise the handle bars on a mongoose scorch bike?
there should be an allen wrench bolt on top of the handle bar shaft. loosen that but not to much because you dont want the tightening nut to fall off. now put the front tire between your legs and try to wiggle the handle bars back and forth while pulling up if it does not move try loosening it a little more and take off the first bolt on the shaft and that should work. i hope this helped you
SabiousOne
Nov 07, 2010 | Mongoose Exile 26 Men's Full-Suspension...
How do i raise the handlebars?
There are two bolts in the center of the handle-bars. One bolt (on some bikes this is actually 4 bolts) is used to clamp the handle-bars to the handle-bar-stem. You can see both ends of this bolt. If you loosen it, you can tip the handle-bars up and down, but not raise them. The other bolt you can only see the head of. Loosen this a couple of turns (don't unscrew it all the way) then give it a tap with a hammer. You will then be able to pull the handle-bar-stem completely out. Do this so that you can see the wedge-shaped nut at the other end of the bolt. You should also see a mark on the stem that indicates how high you can safely raise the stem. Put the stem back in to the desired height and tighten it back up. Good luck.
Jun 11, 2010 | Huffy 26 in. Cranbrook Cruiser Bike
Mongoose Handlebar adjustment
where the bars slide into forks there should be a allen nut on the top undo this slightly and adjust bar height then tighten up allen nut
Apr 03, 2010 | Mongoose Exile 26 Men's Full-Suspension...
How to attach hand brakes? how do i loosen handle bars to adjust?
The bolt you see right above where the handle turns is the handle bar clamp. And if it's been on a while you'll need to take a piece of strong wood and hold it on the bolt, when it's lossened a bit, and hit it with a hammer to fully loosen the handle bars.
Hand brakes should come with clamps to put on the hadle bars, and if you look at bikes that have hand brake, you'll see how to route the cable. The only problwem is if your bike doesn't have the part taht the brake would screw to at the wheel. Then you'll have to improvise.
Dec 22, 2009 | Mongoose 20 in. Boys Axe Bike
Bike gears
usually there are 2 levers on each handle bar, one lever lowers the gear while the other one raises the gear. usually the right handle bar has the shift for the gears on the rear wheel, while the left handle bar has the shift for the pedal gears
Oct 08, 2009 | Cycling
Tightening of handle bars on a bike. Never had a bike before and just got one off ebay and have had to bulid it. But the handle bars (the downward shaft part) keeps moving.
should be a counter sunk allan bolt on the back side of the handle bar facing downwards . set the handle bar as to were they fell comfortable and turn the bolt clock wise until tight.
Sep 10, 2009 | Cycling
Huffy Cranbrook 24Inch Cruiser Bike Logo
15 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
