Question about Franklin Machine Products FMP 151-7500 7 inch Countdown Digital Timer
Purchased new pressure washer via e bay au. new have no back up or support. can any body help
  • 10,865 Answers
Your power washer may be from the following address. Franklin Power Equipment LLC Lebanon, CT 06249
860-642-6330
If not, give me whatever info you may have such as name, model, model # etc. so I have more to go on. Good luck.
Posted on Jan 23, 2009
Where can I find parts for this Tornado Pressure Washer P/N 36010?
Salvation Army, Craigs list, E-bay but even better, if you find out the cost is too much, buy a new one from amazon, they have an awesome sale on it:
2000LB Pressure Washer
Apr 28, 2014 | Tornado 2000LB Pressure Washer
Back pain all the time even on my cockxis
I get lower back pain and I use small magnets placed on specific pressure points on the body. They basically increase blood flow to affected area where discomfort https://www.magneticexperience.com.au/index.php?route=product/category&path=5 normally stems from.
and they also have new back belt.
www.magneticexperience.com.au/index.php?route=product/category&path=2
Feb 25, 2013 | Health & Beauty
Back whels broken whear i can bay new???
You can purchase replacement wheels via your local Quinny retailer or direct from the customer service department on 01284 413 141 Mon-Fri 8.30-4.30. RRP is 30GBP each wheel with 8GBP if ordered direct.
Oct 19, 2011 | Quinny Buzz Jogger
Where can this item be purchased? it seems that no one carries it any longer. DESPARATE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Avon discontinued the Soft & Sensual product line as of December 2010 (from my understanding). I did find a seller on E-Bay who has 4 new/unopened 33.8 fl oz. bottles of the lotion. The link is listed below. Hope it helps.
http://cgi.ebay.com/Avon-Skin-So-Soft-SOFT-SENSUAL-Body-Lotion-33-8-fl-oz-/290580783096?pt=US_Skin_Care&hash=item43a7f6dff8
Aug 17, 2011 | Avon 5 X Whipped Body Oil Soft & Sensual...
Ford taurus 2002 diagnostic says p0191 and p1506 light comes on check engine car runs then after time it will die off. had a button in back trunk to switch if car gets bump thought might be cause started...
Hello! the P1506 is indicating a defective Idle Air Control (IAC) valve,,,P0191 is indicating a fuel rail pressure sensor (FRPS) fault...I suspect a cause and effect on the two codes...
Cause= IAC...Effect= FRPS....See photo below...Remove and clean with throttle body spray cleaner before you purchase a new one...It may only be blocked with carbon...Guru..Saailer
saailer_146.jpgACDELCO Part # 2171810 Cost $70
Mar 04, 2011 | 2002 Ford Taurus
Back in summer wiper washer stopped coming out of nozzles,replaced with new ones,still no pressure squirts about halfe inch from nozzles,iremoved hose from passenger side nozzle,no difference in...
pull minihose off near one nozzle and cycle the washer motor(if it's limpy pressure, blow compressed air down the hose. If possible blow compressed air (via its tube) into the nozzle from the top. Do the same for the other nzzle. You can determine from these steps if your problem is with the pump or not.
Dec 22, 2010 | 2006 Pontiac G6
Hi My karcher k3.65 jubilee is leaking water when the pump is switched off from underneath
Hi This could be just the water inlet channel broken or split. You will need to remove the yellow cover via the screws at the back of the unit and then connect the water hose to see where the leak is coming from. If the water comes from underneath the pump then you will need a replacement pump seal kit of which you can purchase on the Internet.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
The high pressure lance has sprung a leak can i purchase a new one
If we're talking about a pressure washer, then yes, you can purchase a new lance. Companies usually sell replacement parts, and there are also after-market parts available. You didn't state the brand or model # of the pressure washer, and depending on the brand and model, you may be able to repair the leak. It may be a matter of a worn O ring. If you purchased the washer locally, go back to the store and ask for a repair kit or O ring (s). They will also have lances as well.
Was this helpful?
Aug 08, 2009 | PowerBase Car Audio & Video
KARCHER HDS 1000 de
Hi Jim,i have the same unit to,can you tell me are you connecting to mains water via the small black header tank at the back next to the boiler or is it connected straight to the pump head inlet?
Theres more than one reason i'll just start with this one 1st.
chris
Aug 08, 2008 | Karcher 2500 PSI Pressure Washer
Franklin Machine Products FMP 151-7500 7 inch Countdown Digital Timer Logo
Top Franklin Machine Products Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Franklin Machine Products Hardware and Accessory Expert? Answer questions, earn points and help others
