Question about Innovage Jumbo Remote Control
Programming tv Trying to program a toshiba tv
    Top Expert:
  • Innovage Master
  • 74,377 Answers
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
These are the general proceedings to synchronize a universal remote control to a device. If you wish to get more details, check this link. It has setup proceedings and setup codes list to may brands of universal remote controls .
Posted on Jan 28, 2013
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How do i program my channels
Hello
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
"PROGRAMMING NOW-PLEASE WAIT" appears.
6. When channel programming is complete, the message "COMPLETED"
appears.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
Dec 14, 2010 | Toshiba 26HF85 26" TV
Remote control does not work on my Toshiba 36AF42
Try programming the universal remote control specifically for your Toshiba TV, then trying again.
Sep 02, 2017 | Toshiba 36AF42 36" TV
Comcast remote won't work with TV
i can tell you how to make it work, hit the tv button, then hold down the setup button untill it blinks, then try thease codes one at a time 0154, 0156, 0060, after trying the first one, if it turns off, hit the setup button again, that will lock it in
Jan 10, 2009 | Toshiba REGZA 46RV530U LCD TV
Programming a remote
Here's the RCR450 Manual =>
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr450-manual.zip&area=other
The codes for Toshiba TV are Toshiba 1000, 1048, 1072, 1105, 1109, 1118, 1160, 1190, 1241 and are listed in back of the manual.
Nov 14, 2008 | RCA RCR450 Remote Control
Programming remote to toshiba Tv
Depending on the universal remote you can usually program the remote without knowing the codes. One way is to turn on the television, then follow the basic programming instructions for the remote, but instead of entering a code, hit the power button over and over again until the television turns off.
I hope this helps.
Ken
May 27, 2008 | Toshiba 27A34 27" TV
Innovage Jumbo Remote Control Logo
29 people viewed this question
Top Innovage Televison & Video Experts
Computer Repairing
Computer Repairing
Electro Med Services...
Are you an Innovage Televison and Video Expert? Answer questions, earn points and help others
