Question about Minolta Di3510f Bizhub Copier
Shows error code CO900
Minolta Di3510f
says to contact tech for support
  • Minolta Expert
  • 1,326 Answers
A C0900 is a paper tray problem. Try to check your paper trays and make sure that there is not any paper in the paper tray wrong or doubled up in the paper tray, it may hender the paper tray from liftting in time.
Posted on Jan 24, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 3 Answers
Also look behind the tray as it might block the connection to lift the inner paper tray
Posted on Nov 26, 2012
How to fix a cobao error on a DI3510f multifunction printer
COBAO - Elevator motor ascent/descent drive failure.Remove the finisher unit and work without.
Jul 08, 2014 | Minolta Di3510f Bizhub Copier
No message c0070 error but the motor does not move
There is no such code for the Di3510F. What is the correct model?
Jan 14, 2014 | Minolta Di3510f Bizhub Copier
ERROR CODE C0860
DID you mean C-0960!!! C-0860 does not exist in the service manual. Check your bypass tray right side. For something jammed if no need to get a tech out for Konica Minolta. I believe there was a technical bulletin issued in regards to that error several years ago.
Mar 26, 2013 | Minolta Di3510f Bizhub Copier
I can't print with my di3510f
Is this a network printer? Can other computers print? Are the drivers installed? go to below web site to ensure you have the correct drivers
Self Help Product Support Konica Minolta Business Solutions Inc
Mar 16, 2012 | Minolta Di3510f Bizhub Copier
Shows code C0BA0 and will not operate It's a minolta bizhub di3510
The out tray elevation motor failure, did some leave a trash can or some boxes below the output tray and they hit them:(:(:(. STORE NOTHING UNDER THE OUTPUT TRAYS!!!!. Rear cover of the finisher need to be removed, then the elevation drive motor assy removed BE CARE FULL THE TRAYS WILL FALL HARD FAST, so you most now how to that correctly Recommend a Konica Minolta Tech come out or the motor is bad worse case the control board for the entire finisher is bad!!!!
May 17, 2011 | Minolta Di3510f Bizhub Copier
Minolta Di3510F indicated malfunction error with code COBAO. Can anyone help?
COBAo = Elevate mechanism malfunction.
The exit tray home position sensor is not blocked even after the lapse of a given period of time after the tray has started moving up.
An encoder clock input is not detected within a given period of time during operation of the tray.Check the sensors,motors and his connectors.
How to reset:
1. Press the trouble reset switch on the Tech.Rep.Setting Switches Board to reset the following malfunctions:scanner,fusing,exposure related malfunctions and C3FF.
2. For any other malfunctions open and close the front door or turn OFF and ON the power switch.
Aug 07, 2009 | Minolta Di3510f Bizhub Copier
Error code C0820 Call for help
This code don`t exist in Minolta .C0920 is first drawer lift up motor failure.Open and close the front door or set the power switch to OFF then ON.
Mar 19, 2009 | Minolta Di3510f Bizhub Copier
Minolta CS Pro Error Code C0070
Turn on and off WITHOUT toner bottle inserted to reset to home position. If message comes back, the toner motor/drive gears are busted. Time consuming repair, be warned!
Dec 07, 2007 | Minolta Di3510f Bizhub Copier
Error Code C0960
That error code usually indicates a problem with the bottom paper tray. Make sure the paper is loaded properly and that all the paper is aligned properly. Take all the paper out of the tray and reload it.
Dec 06, 2007 | Minolta Di3510f Bizhub Copier
485 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
