Question about Breadman TR2200C Ultimate Bread Maker
Breadman tr2200 97
When plugged in attempting to use the various controls nothing happens and pressing restart does not work there is no preheat, kneading control inoperative it is sort like the keyboard controls are not working when pressing program, it does nothing
  • biglieri May 11, 2010
    Thank you for trying, but try all solutions and the battery has 4,7V. And the problem still, a few seconds of bake, beeps and the display shows '00. ¿May be an high temperature?. ¿Can anybody solution this problem? Thanks again
    Problem Solver:
  • 6 Answers
The microprocessor in the keypad probably needs to be reset. With the unit unplugged, remove the keypad housing (one screw in back, one on the left side, rock it up enough to get a small screwdriver inside, then push back the soft plastic fingers to release the housing -- force it a bit, you won't break it). You do not need to remove the bottom cover.
Remove the keypad cover (4 screws) and the PC board (one screw). You'll see a factory reset button near the middle of the left side. Press and hold that for a couple of seconds.
If you want to test the unit before re-assembly, hold the PC board so it doesn't short against anything (there's nothing more than 5v on the board, so you won't get shocked), and plug the unit in. The display should appear. Unplug the unit, re-assemble, and then bake some bread!
There is also the possibility that the backup battery on this PC board is bad. Check it with a voltmeter -- it should be about 5v.
Posted on Jan 26, 2008
Hold down the start button then switch power on.
It reset OK for me
Posted on Jul 08, 2008
I held down the start button and then switched on.
Hope this helps
GE XL 44 When preheating the temp only gets to halfway to selected temp then it starts to peep then F4 appears. after many attempts it will preheat. This happens every time I use it.
F4 Error
is an open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok
Oct 26, 2017 | GE Kitchen Ranges
Panasonic LiFi model number PT-50LCZ70. Have red lamp light flashing on front 2 times. Have tried to turn it on and get no picture and no sound at all. I checked and the fan is running. What now?
After the red 2 flashing starts, press the power button on the front of the TV and hold pressed down for ten seconds.
You will hear a faint click comming from the back of set.
After 10 sec release the button and wait 10 more seconds then press the start button and release right away.
The green light flashes and the bulb attempts to start.
I found my picture will turn on on the third attempt of the bulb restarting.
When you do this and the room is dark you can see the bulb attempt to restart, My bulb has restarted on the third restart every time.
(note: The three start attempt happen after I do the button pressing
1 time and I do not need further button pressing restarts.
I think panasonic needs to let us know what the problem is.
I called Panasonic and they told me to plug it into a wall plug by itself.
I have it plugged into a multi plug adaptor now and have not tried this yet.
Nov 06, 2009 | Panasonic PT-50LCZ70 50" HDTV
Whole wheat cycle no longer works!
Are you taking into account the preheating for whole wheat cycle? The machine preheats for 30 minutes before normal cycles start - only on whole wheat setting.
Oct 10, 2009 | Breadman TR875 Bread Maker
I can't get started.
We had the same problem. Turned out that if you have an original gamecube controller plugged in at the same time you are attempting to use the Wii remote it will only let you use the gamecube controller. Unplug the gamecube controller and you can now use the Wii remote. Or, you can choose to use the Gamecube controller. Both will work.
Jan 29, 2009 | Sega Sonic Riders: Zero Gravity for...
My Kenmore range model C970-628091 keeps beeping and flashing an F1 or F3 error code when I try to bake at 400 degrees and whenever I try to use timer for baking. When I press cancel the beeping and error...
Fridgetech is right. It's the temperature sensor. I had the same problem, but I was getting the F3 and F2 errors when attempting to preheat the oven.
A R Marshall said that he replaced the sensor but he still got the same F3 error. That happened to me too! It worked for a few weeks, then it began to malfunction again. It finally started showing preheated as soon as the oven was turned on, but never heated at all. One night at 3AM, the error code and beeper went off while we were sleeping! That happened on several occasions at various times of day, and it was necessary to kill the power to stop it. The power could then be restored and the error would stop.
Ours is a Hotpoint range (made by GE). It's my understanding that most ranges have the same or similar error codes.
The sensor was $85.00 at the parts store, but I got it on line for about $60.00 including shipping. The instructions said to strip the wires and then twist them together with wire nuts. But the new sensor had a plug that fit so I used it, and it worked for a short while.
As I looked through the problems and possible solutions, someone said look for burnt wires. So I opened it up and looked but there was nothing like that. Then I remembered the instructions that said to hard wire, so I examined the plug which seemed to have one short wire inside. I plugged it back in and tested with the same negative results. Now suspecting the plug I cut off both sides, stripped the wires and hard wired using two small wire nuts. It immediatly began working normally!
Something is wrong with the plug connector.
Try cutting out the plug and hard wiring before ordering a new part. But if you need a new part, eliminate the plug!
May God bless you and keep you safe!
Sep 01, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Breadman pro stopped working
it is defenitely a power problem some of them have internal resets and you should check. also you could have a malfunction of the power supply module on the circuit main board. if there is no reset then i suggest that you take it to a aplliance repair shop and have a tech replace the circuit module.
Aug 30, 2008 | Breadman Pro Dual Bread Maker
Breadman Pro TR900S does not begin kneading AT ALL!
I can't promise you that this is the solution, but some of the cycles have a relatively long preheat cycle where the bread machine just sits there. Make sure that you are on cycle #1 and it should start kneeding right away.
Jul 05, 2008 | Breadman TR900S Bread Maker
Model: TR2500BC breadman ultimate plus
Check the solder joints on the board inside the unit.
Take the top off and take a picture of where the wires go and then repair it if needed and hook it all back up it should then work I just di that today and all is fine now.
Nov 20, 2006 | Breadman TR2200C Ultimate Bread Maker
Breadman TR2200C Ultimate Bread Maker Logo
655 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
Steve Allison
Steve Allison
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
