Question about Texas Instruments 8930 Printer
TI8930 display has alot of astericks and i cant read it
Removed powercord and rebooted system no luck
The problem is a bad control panel. Order part number 2557821-8002.
Posted on Jun 08, 2009
How to reset errorcode sc546, i removed carbonbuildup on heatsensor, its the ap410n bl/wh laserprinter
go to service mode press up and down button for about 5 sec and then press ok. .Enter engine SP mode 5810 and press "#". When 'execute' is displayed, press "#" again.Then press 'Escape'. Then
turn the main power off/on.
Sep 19, 2015 | Ricoh Aficio AP410N Laser Printer
Power on password on I bought this used. Have removed CMOs battery without luck and entering wrong password only displays asterick no codes. Please help
You don't say who the manufacturer of the computer is. I would google the manufacturer and model number of the laptop with the words power on password reset, and see what you can find. You might have to call the manufacturer, and see if they can give you a suggestion.
May 06, 2015 | Computers & Internet
I cannot figure out in the RS6 menu how to delete a device program. I have two programs for my cleaner and want to delete one. Anyone know?
The best thing you can do is to clear the memory for the system this should be done once in awhile it is like rebooting your computer.
Here are the steps;
1. Press the menu button
2. Now press < button till System Setup is displayed
3. Press enter
4. Press < till "Clear Memory" is displayed
5. Press Enter
6. Press Enter
You will get a message saying " System Memory is being Cleared"
Once it is done the display will go back to scrolling mode
Now reprogram the system as you normally would
You should do this "rebooting" once a year it will make the system run alot better.
Aqualink systems can get a issue called "Ghosting" which is equipment will get programed to run all on it's own. We see it alot in the bigger systems (RS8 and up) for some reason. We are a Jandy warranty center have been for 10 years now.
Hope this helps
Jan 08, 2011 | Jandy AQUALINK RS TELELINK KIT
When i enter my activation key it always display that studio is unlocked but it cant
Here is what to do :
Just uninstall it and reboot your system , then install it again and reboot your system again . that will solve the problem .
rate if useful please !
good luck
Feb 03, 2010 | Pinnacle Studio Version 9 for PC
Got power, frozen machine
okay what you need to do is if you have the system restore cd use that , it will reformat your lap top even if it cant reboot just put in the cd when you start up the computer and it will restore everything you may lose alot of things but atleast your lap top will work after , if not then Reply to me at Jonk3y at Aol.com and i will gladly help you with your problem
Sep 23, 2009 | HP Compaq Presario CQ50-103NR Notebook PC
NAD CD PLAYER NOT RECOGNISING DISCS
Try this:
1) Disconnect the powercord from the plug!!
2) Remove the cover
3) Reconnect the powercord, turn on the power and press eject.
4) Turn of the power - beware, there is still power on the trafo!!
5) Now you have to carefully clean the laser (round glas-like item in the middle of the drawer) with a cotton swab filled with isopropyl alkohol.
6) Then wait at least 1 minute.
7) Turn the power on again and try to play a cd. If it works as it should then you have succesfully repaired your cd-player :-) Otherwise you may try again.
8) Now disconnect the powercord and replace the cover.
If this doesn't help I'm affraid you have to turn it in to your local shop for further invistigation and repair...
Good luck :-)
Sep 16, 2009 | NAD C521 CD Player
Problem with booting my A205-S4577 with the powercord on
Have you tried a new power AC/DC convertor ? make sure you have the correct spec...see manual for power adaptor needed. Cost less if you can get a loan of one. other than this i would be looking into checking the power jack. hope this helps
Feb 15, 2009 | Toshiba Satellite A205-S4617 Notebook
Turning on, crashing ans screen
hi sounds like your laptop will need to be checked inside it needs a good service new thermal compound on the processor make sure everything is plugged in sounds like you got a few loose connections there do not attempt it yourself it's a professional job sorry i can't help unless i can check the laptop myself but good luck anyway.
Aug 08, 2007 | Acer Aspire 5100-5022 Notebook
42 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
