Question about Dryers
HE3 electric dryer only gets warm
1 week ago the dryer stopped getting hot. No matter what setting, it was warm at best. The inside is clean and free of lint. The venting is under 5 feet with 1 turn. I tried the diagnostic test for the thermistor and did not get any E1 or E2 displays. The coils in the dryer do not glow red anymore. They do not glow at all, though I can feel some heat coming from them. Any ideas? Are the coils shot/
  • papione Jan 30, 2009
    This is an electric dryer. The drop in coils are for a gas dryer correct? If so, what is the next thing to do
    Problem Solver:
  • 3 Answers
Your dryer igniter, and or coils are shot.. change the drop in coils first...
Posted on Jan 23, 2009
How do I repair my dryer?
Hi Is two sample resolution:
1 the out taken pipe is clog
2 the limit cycle sensor is broken
Clean pipe disconnect from dryer, open back dryer cover exchange the sensor.
Oct 15, 2014 | Kenmore Elite HE3 Steam 8676 Dryer
Electric dryer getting way too hot
3-5 ACCESS TO THE BLOWER WHEEL OR THERMOSTATS
To get to the blower wheel, remove the back of the dryer.
The blower wheel is under the bottom of the lint screen duct to your left, as you look at the back of the dryer.
The operating thermostats are at the blower wheel outlet.
In electric models, the hi-temperature cutout thermostat is mounted to the heat riser.
3-6 TEMPERATURE CONTROLS AND HI-TEMP SAFETIES
These clothes dryer machines use operating thermostats to control the temperature inside the drum, and hi-limit thermostats to prevent overheating of the dryer drum.. Many machines also have extra temperature controls, such as bias thermostats and heaters, hi-temperature cutoffs, and thermal fuses.
Bias thermostats are just like regular operating thermostats, except that they are mounted inside a bias heater. When the bias heater is energized, it generates a small amount of heat, which causes the operating thermostat to open sooner, keeping the dryer drum cooler inside. Thus a bias heater allows a single operating thermostat to act like both a hi-temp and a lo-temp operating thermostat.
A thermal fuse is found on the blower outlet, right next to the operating thermostat(s.) This fuse will blow when too high a temperature is sensed at the outlet; usually when one of the operating thermostats has failed. If it blows, the motor may not start, or you may get no heat (no voltage to the burner.)
A thermal cut-off is mounted on the clothes dryer heater box. It is a back-up for the hi-limit thermostat. Whenever you replace it, you should replace the hi-limit thermostat, too. A high-temperature condition causes it to open, an overheated grounded heat element may also cause it to open.
Dec 01, 2013 | Kenmore Elite HE4 Electric Dryer
I have a whirlpool dryer and the heating eleiment is getting hot but the dryer inside is barley warm
Inside of the dryer gets warmed up when the drum rotates as there is circulation of air. Hope your clothes are drying. If it takes long time then clean the screen filter as it gets clogged with the flint from clothes. As a matter of routine clean this filter every time you use it before starting the drying process.
Sep 16, 2010 | Whirlpool LER4634J Electric Dryer
My electric dryer is becoming extremely hot during the drying cycle. I replaced a blown thermal fuse several weeks ago and the dryer was extremely hot at that time. The dryer runs but becomes so hot you...
Clothes will get very hot in the dry cycle, especially when the dryer is set to the warmest or hottest setting.
There are controls built into the unit to prevent it from overheating to the point of causing a fire. The thermal fuse you replaced is one of them (and I assume you replaced a perfectly good fuse with a new one as you said it was very hot.).
You might want to check the following if you feel the unit is getting too hot -
1) Make sure the lint screen is clean.
2) Make sure the hose between the back of the dryer and the exhaust duct at the wall wall is not kinked or full of lint.
3) Make sure the exhaust duct leading to outside of the house is clear and not full of lint.
Let me know what you find.
Dec 14, 2009 | Kenmore 62602 Electric Dryer
This is an electric dryer. Over the past week when
one of 3 things could be wrong/1)dry,tight motor bearings/2)drum bearing bad/3) bad motor windings,remove belt off drum and see if anything turns hard i.e. motor,drum each one isolated then run motor w/o drum belt on drum and see if motor gets overly warm or hot especially around the bearing ends
Nov 15, 2009 | Kitchen Ranges
I have to run the clothes through several cycles before they are dry
It sounds like you have a plugged dryer vent. Clean the vent from the dryer all the way to the outside of the house.
Aug 11, 2009 | Roper RES7646KQ Electric Dryer
Dryer turn on, heats up but doesn't get hot
I just had the same problem with my electric dryer. Check your exhaust vent (dirty/clogged). I have seen brushes designed for cleaning the vents at many hardware stores. I replaced mine because it was pretty bad (it's was over 10yrs old). Hope this helps.
Jun 14, 2009 | Kenmore Dryers
Back of dryer gets extremly hot!!!
put hand at the outlet to see if the warm air is freely coming out. if not there could be a blockage in a pipe inside or the propler fan on the motor has failed.
May 12, 2009 | Frigidaire GLER642A Electric Dryer
Dries clothes but runs too long & clothes VERY hot
Fixable and possibly a warranty claim. The timer is bad. You will need to get behind the control panel and remove the timer and replace the timer. First I would call whoever it is that yall bought the dryer through and see how long your warranty is. Most of the warranties are only 1 year. But if you bought a extended warranty then you are covered. The part can be found at repairclinic.com
Feb 17, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer kenmore model# 11076512695 is not drying all the way it gets warm not hot it all just started about two weeks ago
Check that the vent duct leading to the outside of the house is not partially or fully restricted.
Reply back what you find and I will help you more.
Jan 23, 2009 | Asko T701 Electric Dryer
Dryers Logo
96 people viewed this question
Top Dryers Experts
