How to replace screen on inspiron laptop 5120
Trying to replace the screen on my 5120 laptop not sure how to do it
  • 81 Answers
It is very simple look behand in your portable computer you have a place when you bronche a cable in... look this picturehow to replace screen on inspiron laptop 5120 - 7dddf0b.jpeg
Posted on Jan 24, 2009
It start beeping until XP window come up,
It could be a bad memory module. Try removing and reinstalling them. Try one module at a time to see if beeping stops . Check all other connections to make sure they are properly connected. Hope this helps.
Jan 01, 2014 | Dell Inspiron Mini 10 10v 1010 1011 PP19S...
Dell Inspiron 3520
What you have is a cracked screen. The LCD panel is cracked and is leaking fluids to the rest of your screen, those dots will spread too. This happens when u pick up the computer from the screen. You could try finding a replacement laptop screen, or get a new computer. They aren't that expensive. Make sure you save your hard drive tho!
Jun 30, 2013 | Computers & Internet
The screen in my dell inspiron 1545 broke. when i tried to replace it, it stopped working. the old one used to light up and doesn't anymore. I'm not sure if the new screen is the correct one or if...
1. Its very technical thing to replace a screen and you should know the appropriate model of screen.
2. Take it to computer repair shop and get it replaced.
Apr 04, 2011 | Dell Inspiron 1545 Notebook
I have recently changed the LCD screen on my Dell 1545 Inspiron laptop and having carefully refitted the new screen- LTN156AT01 (same as original) refitted the battery and turned on all we get is a...
Are you sure the new screen was working before you fitted it? What was the fault with the original screen? Have you tried connecting an external monitor to see if the Laptop is otherwise working correctly?
Feb 16, 2011 | Dell Inspiron 1545 Notebook
Dell Inspiron mini10
check if keyboard works during dell logo - try to press F2 or F12 - if no response need to replace keyboard
Feb 19, 2010 | Dell Inspiron Mini 10 Notebook
New screen not working
It would be your crappy intel 915 GMS display card.
Get the card replaced
Dec 31, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
My dell inspiron 700m inspiron screen cracked so I replaced it. I purchased the new one from Laptop LCD panels (Dell Inspiron 700M 12.1 Inch Glossy 1280 x 800 Laptop Lcd Screen) to connect it I used the...
The flat cable simply trasfers visual data to the screen to be displayed. The power for the backlight comes through the inverter which takes the low voltage DC power and converts it to high voltage AC power for the backlight. I am not sure what the usual thermal range is for that cable. Just make sure that all connections are tight. Loose connections can cause thermal conditions and shorten the life of all the components. If that flat cable was bad in any way, it most likely would not even carry a signal.
Nov 29, 2009 | Dell Inspiron 700M Notebook
Dell inspiron 6400 screen is fading
Sounds like the backlight is going out. Youĺl need to replace the LCD screen. You can find them on ebay. Just make sure you purchase the correct one for your laptop. You will need to take out the screen to see who makes it and the number. Go to dell.com/support to find your manual, if you feel like you can do it yourself.
Good Luck!
Apr 04, 2009 | Dell Inspiron 6400 Notebook
In need of replacement screen not sure if getting correct one
You'll have to take the screen out of it's housing (involves taking the screen entirely off the laptop, and then removing the bezel around the glassy area by removing the screws under the little circles of plastic) and remove it from the hinges and then finally, you'll be able to see a sticker on the back that has the actual model number of the screen. be sure that it's an exact match to the exact model number. Even if the connector fits, the controller might be different and it won't work at all. Compare pictures, compare model numbers, try to see if they'll guarantee it working on your exact model of laptop (unlikely, but it's worth trying).
See this document by Dell about how to take the screen out. Be sure to follow the instructions carefully.
Jan 18, 2009 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
371 people viewed this question
David Payne
David Payne
