Question about Plantronics M50 Bluetooth Headset
Why won't my plantronics m50 stay paired to my cell phone?
SOURCE: Blue tooth pass code
Typical pairing code for PLT Voyager 510 is 0000
Posted on Jan 03, 2008
SOURCE: Pairing Plantronics-E220 Bluetooth w/ my Pantech Matrix C740 Cell
Hold down the call button on the headset and wait for it to flash slowly blue. Make sure your phone is in "discoverable" mode. You should see your phone asking to connect to the plantronics headset. When it asks for a code, enter 0000.
Posted on Jan 03, 2009
  • 12 Answers
SOURCE: need plantronics 320 pairing code
it's either OOOO or 0000.
Posted on Feb 18, 2009
cyberguru4u
  • 90 Answers
SOURCE: pair 3xx plantronics with my phone
turn on blue tooth on mobile first..then press and hold the power button on plantronics untill the light flashes red and blue alternatively...then search for bluetooth from mobile and pair and if asking a code enetr 0000..
Posted on Feb 26, 2009
SOURCE: phone won't connect to the plantronics 222. When
I had that problem too. I finally realized that I had to press the enter key on my phone.
Posted on May 08, 2009
I want to pair my new cell phone with my headset 3xx plantronics but I need a passkey I don't have the instruction What can I do ?
Once you make your phone discoverable, then put the headset into pairing mode by pressing the call control button until it flashes red and blue. The passkey is " 0000 " (four zeros). Here is a link for the pairing instructions:
Plantronics Explorer Pairing Instructions
Good luck from Headsets Direct!
Oct 16, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How to make a call
The first step after charging is to pair the headset to the cell phone, you may also have to turn the Bluetooth or headset function "on" in the menu of the cell phone (depending on the individual phone). Here is a link for the Plantronics 200 series user guide, this will walk you through the pairing and calling process.
Plantronics 200 Series User's Guide
Sep 16, 2011 | Plantronics Explorer 240 Bluetooth Headset
Need to pair my nokia5310 to plantronics explorer 210
You don't mention if this is your first time pairing the headset, you will need to turn on your blue tooth on your cell phone, the light on the headset should come on flashing red/blue. If it does not refer to sub pairing instructions below. The cell phone should find the headset. 2XX Plantronics in your list. If the pass key is needed it is (four zeros). Second time pairing or more than one device, turn on bluetooth feature, headset turned on, press and hold the call button for about 5-6 seconds. Release button and set headset aside. On cell phone hit bluetooth menu, search for add device. The cell phone should find the headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 17, 2011 | Plantronics Explorer 220 Bluetooth Headset...
MY VOYAGER PRO .. LIGHT FLASHES BLUE RED BLUE RED ... CAN'T TURN OFF, CAN'T RESET, CAN'T RE PARE
If you manually turn the headset off, make sure that it is by itself, no other phones in the area, no WiFi hotspots. Once this is done make sure that there is not a bluetooth already installed on the phone itself, if there is, delete it. Make sure that the headset has a full charge. Try the pairing again. If this still won't work, you can try Plantronics Tech service line 800-544-4660.
Here are two links that may be helpful:
Plantronics Voyager Plus User's Guide
Plantronics Voyager Plus Pairing Instructions
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
Voager pro plantronics how to use with my cell phone set up connection
The pairing instructions are found in the link below for the Plantronics Voyager Pro+. Follow them closely, and you phone's pairing instructions, and you're good to go.
Plantronics Voyager Pro+ User's Guide
Bluetooth device Plantronics not pair with my e63 Nokia mobile. what I have to do to solve this problem. thanks
Make sure there are no other bluetooth devices interfering with the pairing process and remove the Plantronics headset from the phone, if it's showing up. If possible, remove and re-attach the battery of the phone. Power off the headset. Try pairing the headset to the phone again.
Jun 03, 2011 | Nokia E63 Cell Phone
I have a samsung rogue and I all I hear is mostly static with the Plantronics Voyager PRO
Make sure that it has a good connection, try to re-pair the headset to your phone. Before running through the pairing process, be sure to totally delete the headset from the phone's menu. You may want the headset turned off for this process.
Once you make your cell phone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Dec 25, 2010 | Plantronics Voyager PRO Bluetooth Headset
Cutting in and out. best described as sounds like i am talking into a fan.
Once you make your cell phone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions:
Plantronics Voyager Pro User's Guide
http://www.headsetsdirect.com/plantronics-voyager-pro-bluetooth-pairing-instructions
Also if you have a different phone available just to test, see if it does the same thing.
Sep 15, 2010 | Plantronics Voyager PRO Bluetooth Headset
Music
The Plantronics Explorer 330 doesn't have the A2DP technology (Advanced Audio Distribution Profile) for streaming music, you need to look for a headset that has the A2DP Bluetooth profile built in like the new Plantronics M50. The Plantronics M50 is a new model which is now available and is in the $47 range.
Below is a link to the M50.
Plantronics M50
Oct 06, 2008 | Plantronics Explorer 330 Headset
Plantronics M50 Bluetooth Headset Logo
158 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
