Question about B&K Plumbing
I have a b and k nsf 61-9 need new stem and repair kit... it is a freeze proof 12 inch...only one year old and went bad
Cannot find it....am asking your help to find it
5 Suggested Answers
  • 30 Answers
SOURCE: Looking for parts breakdown picture for DANZE NSF
NSF 61(-9) is a standard rather than the model number (it's often very difficult to identify the model number. If you are able to find the model number, the link attached has all the technical specs for Danze products (even discontinued ones). http://www.danze.com/tech_specs.asp
Otherwise, I suggest browsing their faucet section until you find yours.
Good luck.
Posted on Sep 18, 2009
SOURCE: My Danze NSF 61 9 makes a loud howling noise.
You don't say how old your unit is. I have had the same problem with calcium buildup in my tankless heater. Pump vinegar into the unit and let is set for about and hour, then flush the unit.
Posted on Feb 26, 2010
ExHandyman
  • 86 Answers
SOURCE: freeze proof faucet dripping
It does have a serviceable washer. Use a 12" crescent wrench on the collar. unscrew the head and pull out. You may ALSO need to unscrew or "open" up the faucet to unscrew the threading in order to put the shaft out of the body. The spray and work the rust off with WD40.
Posted on Mar 20, 2010
  • 102 Answers
I assume that you are refering to a wall mounted hydrant. If that is the case, most do have a bibb washer at the end. You have to remove the packing nut and then the stem to get to it. Some brands you can do this while the handle is still on. Hope this helps.
Posted on May 14, 2010
The hinges on the sun canopy for my Quinny Zapp have bent and become loose; therefore, the sun canopy slowly inches closed as I walk. The problem is especially bad when I try using the raincover. Is...
Good Morning
If the Zapp is under 2 years old please contact your retailer with your proof of purchase to discuss making a warranty replacement claim for a new sun canopy.
If it is over 2 years old or you do not have proof of purchase you can order a replacement sun canopy from your local Quinny retailer.
Jul 22, 2011 | Quinny ZAPP Stroller
I have an American Valve M72AS Frost Proof Sillcock that is leaking around the stem when turned on. I replaced the packing under the handle with no fix. Is there another packing/seal deeper inside? How...
AMERICAN VALVE 1/2-in Dual Pattern Brass Sillcock Valve M72AS...
Do NOT purchase this product... Mine lasted about four years for me before the internal stem/rod cracked. This caused a constant leak when it was turned on. Doing research for parts... I've noticed a lot of reviews on the internet about this same problem as to it leaking through the handle. I thought it was a gasket problem but after analyzing it, it turned out to be the "Integral Vacuum Breaker" system malfunctioning after a few years of use. The tip of the stem is a moveable item loaded on a spring and if it gets stuck closed, the water in the stem/rod does not drain out causing water to stay in the center stem/rod and of course freezing during the winter. When Spring comes and you turn on the system, that's when it leaks in and around the handle.
Another important note: I could NOT find replacement parts i.e. center stem/rod therefore causing me to buy another new Freeze-Proof Sillcock. It doesn't stop here yet....The newer ones are mostly made of aluminum and the center stem/rod is all aluminum...NOT copper!!! This part being all aluminum which I believe will be a major problem to come!!! As you know aluminum creates lots of oxidation with layers of white aluminum powder. This will now be going through your hoses that might feed your garden/food, your pets water bowls outside and your pools!! This is not good. They need to keep this stuff copper or CPVC but NOT ALUMINUM.Look up "Aluminum poisoning"
I have pictures of this (center stem/rod) and how I fixed the old copper center stem/rod for a back up when my aluminum one I just bought from Lowes fails in a few years. I tested it and it works (my old copper stem/rod)!!! I fixed mine by removing the spring in the tip and putting the tip back in the stem and filling the center of the stem/rod with Liquid Nails adhesive. If I was to do it again, I would use a Rubber Silicon via a tube gun.
My suggestion is to go to the old type of Frost-Free Sillcock "BRASS" NOT ALUMINIUM and doesn't have a hollow center stem/rod for water to freeze in and also doesn't have the anti-Siphon design. It might be a neat design but when the parts start to oxidize/rust etc. it then will stick and keep the water from being aloud to leave the stem/rod therefore causing a crack and WILL leak when opened during the Spring.
Jun 10, 2011 | Home
Leaking frost proof hose valve, 12".
They make a repair kit with new washers and seals available at plumbing supply stores
Jun 05, 2011 | B&K 12" Lawn Faucet By Muellerbk 108013
The pullcord works sometimes but usually just pulls out without any tension. Just went to try it today and this is the first time I've had this problem. The generator is about 12 years old.
the catch 'pawls' are worn and bad and need to be replaced,, or the catch 'pawls' spring is broken.
you can buy a rebuild kit for this at you local generator repair shop,, this will restore the pull function to normal.
c...
Feb 02, 2011 | Sport & Outdoor - Others
Freeze proof faucet dripping badly (hardly used 6 yr old) bolt holding plastic handle seems pretty well rusted on. I'm trying toi figure out if there is a servicable washer that needs replacement.
May 12, 2010 | Plumbing
I pulled the stem out completely trying to reset time.
if you broke the stem and its left a peice inside the movement then i would ask your repairer for a module exchange this is cheaper than servicing and a new crown 55.00 or send it back to seiko they are very good with there prices.you wont have the tools you need to replace it yourself..
Mar 25, 2010 | Seiko SUJ051 Wrist Watch
MY RCA R61WH76 61 INCH TV IS BLURY AND LOOKS LIKE IT HAS 3 PICTUR
RCA Scenium Profiles HD61 TV IT'S AT 480i how I get at 1080i or 720i please help....thanks...
Jul 02, 2009 | RCA R61WH76 61" HDTV
I have a flourescent green vertical line about 12 inches
This is a problem that should be looked at by a local svc co. It could be the logic board, a buffer board or worse case scenario a bad plasma panel which is very costly.
Mar 04, 2009 | Pioneer PureVision Pro-1410HD 61 in....
Need a new stem. Can I purchase on and get it put on myself
You have to open your watch and find movement number. Use an eyeglass as the numbers are very tiny. Number is pressed onto one of movement plates and shoud be letters ETA+number.
When this is done, visit your nearest watchmaker shop and ask for stem for movement ETA+number. Do not tell this is for Ebel or you will be charged accordingly to brand name.
There should be no problems for supplying ETA stem.
Dec 04, 2008 | Ebel Classic Wave 9090F249725 Wrist Watch
Plumbing Logo
130 people viewed this question
Top B&K Plumbing Experts
Tom Chichester
Bill Boyd
Daryl Gleaton
Are you a B&K Plumbing Expert? Answer questions, earn points and help others
