Light comes on but won't cool
SOURCE: Whirlpool refrigerator model ED5GTN cooling problem.
With the unit unplugged, take off the back cardboard panel. On the lt rear side you will find the compressor. On the lt side of the compressor you will see a white box mounted on the side, this is the relay, and it most likely will have a zip tie holding it on. Cut the zip tie or unhook the clip. Gently pry the relay from the side of the compressor. If it is badly burnt make sure there are 3 connectors on the compressor, sometimes they will burn one off or burn it so bad the compressor will need to be replaced $$$$ if not in warranty. If its not burnt thats hopefully what you will find, hold out your hand with the compressor side of the relay pointing down. Shake the relay like a salt shaker into your hand. If you get grey flakes/chunks in your hand the relay is bad and will need to be replaced. easy fix for about $45 - $50.
SOURCE: My whirlpool refrigerator (Model ET18DK) does not cool
Most likely one of two conditions are the root of the problem. Either the fan in the freezer is stalled or the defrost system has failed. The fan in the freezer should run any time the comressor is running; if it's not, there's your problem. If you can hear the fan, check for frost or snow developing across the back panel in the freezer. Local repair service could probably supply replacement parts quickly for defrost failures (most likely a bad terminator if defrost system isn't working).
SOURCE: whirlpool refrigerator stopped cooling. the
You have a bad overload/relay . This is the piece pluged onto the side of the compressor , with 2 or 3 wires going to it . The part number is 8201786 . It is easily replaceable and instructions come with it . Price is around $60.00 .
SOURCE: freezer not freezing but cools
is the freezer fan running? is there frost on the rear freezer wall if so it would be a defrost issue. if no frost on freezer rear panel it would sound like a bad compressor or sealedsystem leak.
SOURCE: my whirlpool refrigerator/freezer is not
Switch off the fridge for few hours then before you you switch on check the continuity of the main power cord to the compressor which comes thrrough the main relay. Now the relay is activated by the thermostat/pressure switch/defrost timer.
So you will be able to trace the path of the power to activate the compressor. however if the relay clicks and shuts off the the capacitor must be checked or replaced. However if there is a heavy drain of current- use a clamp tester meter- the compresssor can be a suspect.
Please check this link for a idea of the parts.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2/278/identifying-fridge-freezer-parts.html
Testimonial: "very helpful...not looking good for my refrig!"
