Question about Champion International Champion& Small Engine Spark Plug 8 Pack
Snowblower Spark Plug Gap
I have a 1970 (7 hp) Bobcat snowblower. But because it was a gift, I do not have the manuals to go with it, so I am unable to find out the proper spark plug gap.
The new spark plug that I purchased at a small engine repair shop did not work until I enlarged the gap. While it now operates fairly well, I do not know if that is the proper gap.
Any ideas?
Don
  • donaldbacks Jan 24, 2009
    Excellent response time.
    Extemely helpful
    Don
4 Suggested Answers
  • 42 Answers
SOURCE: what is the gap for champion spark plugs
the gap you should have is .030". hope this helps you.
Posted on Mar 21, 2009
  • 1129 Answers
SOURCE: My riding lawn mower won't start. New battery
Spray starting fluid into the air box if it starts and dies out there is a fuel delivery problem if the mower has a petcock fuel shut of valve disconnect the fuel line after the petcock and hold a container under the hose turn on the valve to ensure gas flow to carb if there is no petcock valve I would still check the line to carb make sure gas flows through the hose to carb.
Posted on Jul 23, 2009
  • 33 Answers
SOURCE: my ariens snowblower only works in the choke
had same problem with a small 2 cycle outboard motor last year. I had run it during the summer, put it away for the winter and when I went to fire it up the following Spring it would only run with half to full choke. Old fuel had gummed up the carburater by letting it sit in there for a few months, had to disassemble and clean all the carb parts (including the jets) and it worked good as new. You could do it yourself or take carb to a small engine repair shop and have them do it. May or may not require a rebuild kit depending on how gummed up it is. Hope this helps.
Posted on Feb 10, 2010
Correct spark plug gap
correct spark plug gap for 4.3liter 6cylinder 1500 Vandura
Jan 04, 2014 | Tecumseh Snowblower Snow Blower Starter...
I need to know spark plug gap on murrays snowblower g2250030
.30 is usually a good standard if you can't find the manualHave you tried manuals on line ?
Dec 28, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Will not start /// Need Point Gap For Mag To flywheel on A Murray 4.5 hp snowblower. Had a Lot of Rust on it Cleaned It Up put back together Set at 0.016 ............ Is That The right gap HELP.......
That will work. Usually .015 to .020 will work ok.
But there are lots of reasons for a no start. Bad gas, gummed carb, bad spark plug, etc.
Dec 22, 2009 | Garden
Champion International Champion& Small Engine Spark Plug 8 Pack  Logo
100 people viewed this question
Top Champion International Garden Experts
JohnPaul Robertson
chuck ringwood
chuck ringwood
Randy Schumann
Randy Schumann
Are you a Champion International Garden Expert? Answer questions, earn points and help others
