Question about RCA 12v Ac/dc Adapter Charger For Kenic Kd-627 Fits Dvd
What is this adapter used for
E305658
Using wrong adapter on my Gemmy Animated santa , What will this cause Because I am having problems but some things work? But the Hips won't move . I am using a 12v adapter but it is suppose to have a 9 v...
Using the wrong adapter will likely shorten Santa's life span. It is best to use the recommended adapter because using the wrong one may have fried his hips among other things.
Nov 08, 2013 | Gemmy Life-Sized Animated Santa
Can i use a Netgear WPN111 USB 2.0 Wireless Adapter with a xbox ?
No definitely not....
If you want your Xbox to be wireless, then you need to buy Xbox wireless adapter...
Bcoz the Xbox wireless adapter comes with a pre-built in drivers....
but other brand wireless adapter donot comes with a built in drivers, you need to install the drivers using a driver cd....But Xbox do not allow driver cd's to be installed on it... so you will not be able to use ordinary wireless adapter instead of Xbox wifi adapter...
Dec 10, 2010 | NetGear WPN111 RangeMax Wireless USB 2.0...
It does not connect
Wireless Adapter is a device that will receive the wireless signals and will make your computer wireless adapter. without the wireless adapter you can not use the computer to connect to the wireless network. Now a days all the laptops and desktops are equipped with the built in wireless adapters.
First check whether you have a wireless adapter on your computer ?
WIN XP
Right click on MY COMPUTER ==> properties ==> Device Manager ==>
you will see Network adapter ==> under network adapter you will see the wireless adapter ==> Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ?If it says working properly then that's great !
WIN VISTA/ Windows 7
Click START ==> Control Panel ==> In the right hand side at the top you will see " Classic View "
Switch to classic view ==> you will see Device Manager ==> Under Network Adapters you will find your wireless adapter listed . Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ? If it says working properly then that's great !
If you do not see wireless adapter in the Device manager , then either you do not have the adapter or the wireless adapter is not working .If you see "yellow exclamation mark" on the wireless adapter, that means the drivers are not installed for the adapter or not working. Reinstall the drivers.
Once your adapter is working properly , try to connect to the wireless network.
If you are installing the external wireless adapter to the computer and if you are using Windows 2000 or Windows 98 , ME, then you will have to connect to the wireless network using the utility of that adapter.
If you are using Win XP then you can use windows to connect to the wireless network or you can use other utility.
In case of Win VISTA, you will use windows to connect to the wireless network.
Click Here for more info
Dec 09, 2009 | Dell 1450 (D1450U) Wireless Adapter
The adapter to my Western Digital Book does not respond
The monitor requires a adapter with a current output of 4 amps. but the Western Digital Book adapter can only supply 2 amps (half the current required by the monitor).
This means using the WD adapter on the monitor will stress this adapter beyond its capacity and continual use of this adapter on the monitor will cause it to fail and/or switch off if it has overload protection.
If you are having problems with the 2 amp adapter on the WD Book, then the power adapter could be faulty or it maybe OK when the adapter cools down.
I suggest you get a 12 volt 4 or more amps adapter for the monitor.
You may need an adapter for the WB book too if the adapter is faulty.
Dec 06, 2009 | Western Digital My Book Essential Edition...
How do you connect WIndows Vista to Windows 7 through ADHOC?
Dec 04, 2009 | Computers & Internet
How does the pc wireless adapter work for laptops with embarq equipment. currently using dsl with embarq.
pc wireless adapter will work then if you have also another network like wireless router or another PC or Laptop with wireless adapter, if your going to use this wireless adapter network in pc to pc is you are going to setup by adhoc to adhoc connection, itself detect for sharing a network without any router needed, but if you do such simple network connection use wireless router, its definitely work easily. Aumatomaticall detect wireless router on your wireless adapter network.. Good luck!
Jul 18, 2009 | 2wire (1000-100016-002) Wireless Adapter
The 6T04 adapter and adaptec AIC wont start
Make sure u using proper adapter. If u need to use compatible adapter. If ur company adapter is with yellow tip means its 65w adapter or if its black tip than its 90w. Now u decide which u need to use.
Jul 15, 2009 | HP Pavilion dv6000z Notebook
Wireless USB Adapter
The adaptor can be any brand. You need to configure the connection, including the security passphrase or wepkey.
May 03, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Netgear router and microsoft adapter compatablity
You might try looking for updated drivers for your Microsoft adapter. Older wireless adapters often do not support newer wireless security methods like WPA/WPA2, so if your router is set to use something besides WEP, that may be the answer.
If you're not using wireless security and you still see intermittent connection issues, I'd consider using a different wireless adapter. In my experience, Microsoft wireless adapters do not have the range other brands do.
Jan 30, 2009 | Microsoft Wireless Network Adapter
Cant use wirelless g network adapter with alltell wireless intern
That's not possible, you need one adapter for each of your computers. Your only option without buying more would be to carry your adapter with you and plug it into whichever one you're using. Obviously this would get a bit annoying and it would be impossible to use more than one computer at once. Wireless adapters are pretty much meant to be left in a computer all the time.
Jan 08, 2009 | Linksys : WUSB54G Wireless-G USB Network...
RCA 12v Ac/dc Adapter Charger For Kenic Kd-627 Fits Dvd Logo
23 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
