Question about ASUS P4SP-MX Motherboard
Boot up ishue
Hello, I have a problem and hoping to solve it with your advice.
My pc started to giving me trouble a month ago-always when I tried to restart, it want do it and it was giving me bios erorr beeps (1 long and 2 short). In manual I find out that is video adapter related erorr. Well, only way to start normaly my pc I needed to shout it down completly and leave it be for some 30 minutes. When I started it again in bios was a message - during your last boot up your system hung for inpropriate cpu speed.
I was tring to reset my bios setting to default but it didnt helped, as soon as I restart the same problem with the beep codes occured.
In time it got worse, and pc neded more and more time to be left powerless to succesfully start again. Finaly, i could not even get him start because the beeps started even if I left it be and even start it on botun.
I replaced the motherboard battery, checked monitor, all cables, memory,conections inside and all works fine.
Now I am wandering what could be the problem: cpu, motherboard or psu.
I got p4sp-mx motherboard with onboard grafic SIS 651, intel celeron 1.7 processor.
Some guys on net forums told me they suspect that psu is gone.
I hope you allredy incounter problem like this and will help me.
Cheers!
  • Tom
    Tom Jan 23, 2009
    I tried running it without a cover and fans worked but beeps kept going on. So its got to be PSU. Thank you for your time, cheers!!!
  • kbuild Mar 08, 2009
    my computer is doing exactly the same thing. a month ago i changed the power supply which helped for two weeks and then winter storms started causing interruptions with the electric company and even with shut down on ups, the problem is worse than before !
    Sergeant:
  • 238 Answers
From the sound of it, the PSU is going. The long cool down time would indicate to me that is a rather large component that is not exposed to very much airflow. To help isolate this, you might want to try running the system with the cover off. If the problem stays about the same, I'd say it's the PSU. Check all the fans while you're at it.
Posted on Jan 23, 2009
Internal power error
Dear user,
Please elaborate more, if your laptop is new, do not try solving such issues on your own , take the dell showroom to task :) dell gives full replacement warranty if it is applicable in the country you life and you have opted for it while buying
if your laptop is old, try removing the battery, use the pc on AC adapter for some time maybe even a day and try the battery next day. if it does not work you need to give both of them to the service station for a check.
May 04, 2011 | Dell Studio 15 Laptop
Hello Sir,i am having Hp-compaq 8100 elite competable mini tower,Model:XYS173S-A2N,I INSTALL WINDOWS-7 PROFESSIONAL 64BIT,WHEN I AM RESTARTING WINDOWS DISPLAY IS NOT COMING,SO WHAT SHOULD I DO.PLZ GIVE ME...
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Apr 12, 2011 | HP PROMO 8100 ELITE SFF WINDOWS 7...
Battery Not Identified.
hello
I suggest you a few steps to solve your problem.
  • remove the charger and press the power button till all residue power is radiated.
  • then connect the charger and charge the battery fully and try booting the system.
  • if this don't work check the output of your charger and see if it is working fine.
  • if it is working fine then remove the battery and connect the charger and try starting the system.
  • if it works then there are two things possible.
  1. battery gone.
  2. IC responsible for charging is gone.
i hope you can figure out the problem through this.
Thank you
Aug 07, 2009 | Dell Inspiron 1525 Laptop
Trouble booting past the BIOS Screen
Remove the cmos battery and unplug comptuer for about 15 to 20 minutes. install battery working battery. make sure you didn't knock any cables loose
Check ram is seated
Check video and audio cards are seated properly
Then try booting pc.
Jan 22, 2009 | Dell Inspiron 6000 Notebook
Compaq evo-d510-boot problem
What have you recently plugged in as new hardware ? this F1 response indicates that a piece of hardware is not properly configured to run , and F1 is the offered option to go to CMOS to complete the installation.A most likely item will be a USB powered piece of hardware.
Nov 27, 2008 | Compaq Evo D500 PC Desktop
Slow process of pc
hello friend don't worry
please chnage ur memory all probelm will solve
Jul 22, 2008 | Microsoft Windows Server Standard 2003 for...
HP Pavillion Laptop
HELLO. HERE IS SOMETHING YOU CAN TRY. START UP YOUR LAPTOP. HOLDING DOWN ON YOURSHIFT KEY. WHILE TOGGLEING ON F8 F9F10 AND SEE IF IT START'S IF SAFE MODE,.? LET ME KNOW.OK GOOD LUCK
Jun 18, 2008 | HP Computers & Internet
My hp pavilion
No, that's a very nice machine. Sounds like software trouble. Can you backup all your files and restore from the recovery p[artition? That would be the easiest.
Good luck
Nov 10, 2007 | HP Pavilion dv6000z Notebook
ASUS P4SP-MX Motherboard Logo
203 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
