Question about Maytag PDB3600A Built-in Dishwasher
Maytag Dishwasher was working well, then next morning went to start and set dishwaher and closed door and dishwasher would not start. Cirtutes are working and washer is plug in. Hand holder on door appears loose.
  • Anonymous Mar 24, 2014
    when I close door and try to start the dishwasher it wont come on at all and wont even light up
  • 5,911 Answers
If the door handle appears loose, you could have a broken door latch which will prevent the dishwasher from running if the door is not able to latch properly. The latch usually has two micro switches that are pretty delicate. Not to accuse you of abusing your appliance, but if you're in the habit of slamming the dishwasher door shut, you could inadvertently break the switches in the door. The switch assembly and handle are sold separately, so you may need to purchase both. Let me know if this helps.
Posted on Jul 09, 2007
SOURCE:
HOW TO RESET MY DISHWASHER
All you can do is turn the power off at the power point, leave it for a few minutes and then switch the power back on.
Jan 11, 2016 | Dishwashers
Maytag dishwasher wont fill with water
Hi Mingsten 1) check the water valve under the sink make sure it is open. 2) check if the water line is pinched or twisted 3) if you have a meter you can check if you get power to the dishwashers water valve ( it is under the dishwasher. behind the kick plate.) you will have to remove 2 or 4 screws to get to it. hook up your meter and close the door. wait for the pump out and check for 110-120 volts when the dishwasher should fill.. 3) if you have power at this time you will need a need dishwaher water valve.. 4) if you get no power then you may have other problems ( let me know and we can go deeper) I hope this helps let me know...
Sep 29, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
MAKING A STRANGE NOISE WHEN STARTING THE HOT START
try re-setting it. unplug power. visually see if d/w looks clean. re-connect and run an empty short cycle ensuring door properly closed. good luck
Jul 26, 2013 | GE GSD3200J Dishwasher
Dishlex 300 blobal dishwasher. have set dishwaher for normal wash as usual. All lights are one but dishwaher will not start. help please
It is likely the door switch is not engaging properly. Check the gasket is set properly and the door is closing when you shut it. Also confirm if it is not on delay start.
Feb 13, 2011 | Electrolux Dishwashers
I push start and my dishwaher wont turn on. I have checked the other buttons and they work. I also turned off my breaker to see if that will help and it still doesn't turn on,
either:
  1. something blocks the door from latching or closing. Check, if anything is stuck behind a dishrack. try reversing lower rack. check if the door aligns properly and dishwasher is installed correctly
  2. latch switch failed/latch mechanism is broken. Disconnect dishwasher from power. Disassemble door, check latch, check latch switches for continuity
  3. touch panel or control board (less likely) is failing. replace if none of the above is working for you.
Good luck,
Vlad
First Choice Appliance
Sep 14, 2010 | Magic Chef CDB1500AW 24 in Builtin...
Dishwaher detergent dispenser is not opening
go to searspartsdirect.com and put the model # in they will ship the part to you.
Mar 02, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Sprung the door now it won't close was emptying it and tripped over a dog
You probably need a new dishwaher. I have seen a few sprung door hinges repaired which worked OK, but most still leak after a costly repair. Your call and good luck. Ken
Apr 06, 2009 | Maytag PDB3600A Built-in Dishwasher
Maytag Dishwasher: MDB/C-2 Suddenly Stopped Worked
I have had this dishwasher since 2003 and haven't had a problem whatsoever. This is one of the best dishwashers I have purchased out of the 4 I have had.
Jul 21, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Programme will not run , starts beeping after 5 minutes into cycle
turn your dishwasher on the first thing it should do is a quick drain then fill after the fill open the door and see how much water is in it hold my rating till we are through
Jan 31, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag PDB3600A Built-in Dishwasher Logo
364 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
