Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
Everything!! Have had mine for 4 years. Replaced just about every part imaginable! This morning it decided to leak onto my kitchen floor and all the water in the tub is still in there....with bubbled up soap. I spent $400 fixing this maching back in August, now this. Never again.
  • 1,543 Answers
There should never be bubbled up soap in your dishwasher. That is a sure sign of using dish soap instead of dishwasher soap. That will cause leakage. To remedy, cut open 3 or 4 pyhzeme (spelling?) capsules (usually used for stomach gas problems) and run for a 10 seconds or so, (which will knock down the suds) then pump out. This should fix your current problem. Please remember, I didn't build, sell, use, or repair your dishwasher in the past, just gave you free advise on how to solve your current problem. Please don't rate if you don't think this is a Fix-Ya for you, as any other rating will lower my score.
Posted on Jan 23, 2009
Too much sink water causes flooding from dishwasher.
If you let it sit with vinegar and it worked after for a while that tells me it may be plugged up with grease. Might be worth while trying to clean it out with Drain O a drain cleaner. Make sure its washed clean after. Grease and dirt builds up after a while in all machines. If vinegar works might be worth cleaning more often.
Mar 14, 2017 | Maytag PDB4600 Built-in Dishwasher
I have a Frigidaire dishwasher that I have had for a year and a half - 8 months ago it broke and leaked into my kitchen ruining my wood floor which had to be replaced. Shortly after that the top sprayer...
I would check to make sure that the top spray arm wasn't over tightened when it was installed. That spray arm threads onto a plastic supply tube which is easy to strip, which will cause it not to tighten properly and leak down the side of the dishwasher and acros the floor.
Mar 24, 2010 | Dishwashers
Kitchen floor
You have to replace the floor joists. This is accomplished with bottle jacks to raise the floor high enough to fit new floor joistsalong side of the old ones.
Its best left to somebody who is experienced in construction
Sep 07, 2009 | 2006 Eagle Talon
Leaks when being unloaded
I may not have the full solution here, but to avoid (expensive) sub-floor damage, I recommend you do the following.  Assuming that the water is not coming from some dripping between the opened door at the hinge....
-Remove the kick plate that is in the bottom, front of the dishwasher.
Use a flashlight to look for wet flooring.  Run the dishwasher with the kick plate removed, watching for leaks/dripping.  It is possible for a leak to seep under the floor.  If leaking is found, do not ignore it.  Pull the dishwasher, fix the leak or replace the dishwasher.  Remove the first layer of sub-floor under the dishwasher, looking for deeper damage.
You should probably do the same with the carpeted area.  Pull the carpet back and decide if the sub-floor needs to be replaced.  A flooring expert should probably inspect.
Sorry to be such an alarmist, but I have been around floor damage that was unnoticed and ignored.
Apr 14, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Water leaking out bottom of dishwasher door onto kitchen floor.
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Mar 02, 2009 | Kenmore 15762 Dishwasher
Water on my floor
Is it the bottom or coming out the door at the bottom? When your seal is bad it will leak, mine leaks only on handwashables and delicates. I have had to have my seal replaced twice in the three years i have had one, and the last seal was not put on right and leaks.
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Cannot shut off the kitchen aid stove with the "Off" button, model # KESA907PSS01
i had the same problem with mine.. i overboiled some water and it leaked down the front onto my panel (inside).. i had to replace the whole thing.. (i did it so i added a silicone bead inside so water cannot get to that same panel area)..
3 years and it still works..
replacement panel is about 120.00 CAD
Jun 26, 2008 | KitchenAid KESC307 Electric Kitchen Range
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
97 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
