Question about NetGear WG111 802.11g/b Wireless Adapter
My netgear adapter sometimes cant find my 2 wire dsl signal
I installed the adapter and confifured it to read my 2wiredsl signal and got online. but a lot of times it wont/cant find the signal and i have to go in to reconfigure the adapter.
  • trnman65 Jan 26, 2009
    intermitently wont connect/find my dsl signal,its in the next room living room from kitchen no door blocking path.vista home premium.it will go to other signals in the area rather than the one i entered in it when i set it up.
  • Mark Egan May 11, 2010
    When it will not connect, are you within range of the router?
    What Operating System are you running?
    President:
  • 1,214 Answers
What signal strength do you get when you connect?
Is the router buried underneath or inside a cabinet or anything?
Consider relocating the router away from other objects (particularly metal items), or on the outside of any type of cabinet.
Posted on Jan 27, 2009
How to Install Netgear Router Using the Wireless Device
hi john.
To install your NETGEAR wireless router using your wireless device:
  1. Get the preset wireless settings of your NETGEAR router. It is written on the back or at the bottom of your device.
  2. On your wireless device, open the WiFi connection manager and find the SSID or WiFi network name of your NETGEAR router.
How do I install my NETGEAR router using a wireless device ...
https://kb.netgear.com/.../How-do-I-install-my-NETGEAR-router-using-a-wireless-devic...
How to Install Netgear Router Using the Wireless Device Google Search
Nov 06, 2017 | NetGear Computers & Internet
Router is connected, when i go online it disconnects from the router. i have DSL that it is connected to. So it picks up the ip address automatically.
Is the DSL you are connecting too a router and modem as well? If so, then you do not need the NetGear. If you have for example a AT&T Router called a 2-Wire it is also a router.
Mar 19, 2011 | NetGear Computers & Internet
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    Not receiving n-type signal from router
    Put the laptop next to the router and see what signal you then get. do the following
    ---- start>control panel>system and maintenance>system>device manager on lefthandside> network adapters click on the +sign>right click on the wifi adapter>properties>now in there there maybe a TAB for advanced which allows you to select the type of signal the adapter is set for - check its not set to G. ----- loss of signal in room, wifi signals can be reduced, if they pass through walls etc - sometimes just a small change in the routers position or aerial alignment can make a big difference ------ download and install - http://www.xirrus.com/library/wifitools.php - you can then monitor on the graph the signal strength and see when it drops off -------- also a change in the wireless channel used on the router can helpp - Use channel 1 or 6 or 11 as they do not overlap - have a look at the other signals being broadcast and what channel they are on - then choose one that is free or also on a very weak signal to minimise interference
    Mar 17, 2010 | Broadcom BCM5705 Network Adapter
    Xbox 360 connection withthe netgear WGR614v9
    This is beacuse there is NAT on the router for which you need to open certain TCP/UDP Ports on the router . but firtstly you need to Bridge the Verizon DSl Modem set up the internet connection as per same .
    Feb 13, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
    NETGEAR WPN111 not working
    please download latest driver for adapter and install on computer that can fix it
    link for driver
    http://kb.netgear.com/app/answers/detail/a_id/12520
    regards
    prakash
    Dec 04, 2009 | NetGear RangeMax WPN111 802.11g/b Wireless...
    Yesterday we subscribed to a DSL service (Hughesnet) and also had a TrendNet wireless router installed in our PC so my Mac G5 could use the service, too. Come to find out, my Mac doesn't have a wireless...
    Connect the modem directly to the Computer first and try n go online.If everything works fine then this is the no. for the
    • Netgear Tech Support 1800-211-2069
    • Netgear Tech Support 1-888-638-4327
    It's a toll free number call them and they will guide you step by step in a proper way.
    Good luck.
    Nov 04, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
    Cant connect wirelessly
    Yes u have to buy a netgear N dongle ...
    Because N works on 5 ghz and G works on 2.4 Ghz
    You can buy netgear WN111v3
    Nov 19, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
    Connection problem
    if it's going offline, then it's losing the signal, or is recieving a low signal, it should be at 54mbps but when it gets below around 24mbps, it will disconnect and look for a stronger connection in your area, or disconnect from the net altogether.
    Put your router in a higher and better line of sight to your adapter, walls and floors can block the signal and check that it's not your router that is losing the connection.
    Oct 16, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
    Help needed with WG834g & usb adapter
    Sometimes a hard wire cable whether lan or usb is needed to set up the router first before going wireless. If not it maybe your pc needs a ip/dns flush from the last allocated numbers from your bt router. To clear this:- Click Start>Run, then type ipconfig /flushdns then press enter.
    Jan 21, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
    NetGear WG111 802.11g/b Wireless Adapter Logo
    120 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
