Cannot capture video in ulead software will not show in source
I think i am connected up ok .this is the first time of trying
regards derek kinally
    Champion:
  • 203 Answers
Chek to see if you have driver from what are you capturing camcorde or video surse. try with WINDOWS MOVIE MAKER if you see the image from device wich you are try to capture the video the driver's are ok, the the software wichu use is not compatibile with your system but i doubt that.
Posted on Jan 30, 2009
I have an Easycap video capture device which I cant get to work. The drivers seem to be installed properly but when I connect my analogue camcorder using the s video or the video and audio jacks and have...
I believe that you have to instruct the software from where it should be receiving the video signal. Pls try in your video capture software (Ulead), pls go to the Options menu, click on the Capture Property Settings, Select yourInput Source (S-Video or the Yellow RCA). Other than that, it should be pretty straightforward.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 27, 2008 | HP Compaq Presario SR2150NX PC Desktop
Tip
Windows7 64bit & EasyCap directions
Ulead Video Studio SE DVD how to run on Windows7 64 bit systems by Not you. Drivers updated now has drivers for XP Vista and Windows 7 7/16/2010 Getting started,you will need another program its called USB-AVCPTSetup_For_Win7 you can get it here... download links are at the bottom of page.Do not install at this point save to your desk top! Ok your ready Do not plug in your Easy cap usb drive. 1. Put the EasyCap disk into your CD Rom When auto play starts click Run HAutorun.exe a window will open DO NOT INSTALL THE DRIVER !!!! 2. click Install Video Studio,complete the install adding your code with no driver reboot when asked. after reboot remove the disk you will not need this anymore. 3.DO NOT INSTALL THE EASYCAP USB DRIVE YET. 4. Install the software you saved to the desk top (USB-AVCPTSetup_For_win7) reboot your system. 5. Plug in the EasyCap USB stick and wate till the driver installs this will be done auto,in a few seconds. 6. Sorry to say but you need to reboot now. leave the USB drive in its port. You are now installed but your cam will only show a black screen at this point,its ok we are now going to resolve that. Start the Ulead Video Studio. During the start up you'll have the choice of VideoStudio Editor or Movie Wizard click the 16:9 ckeck box at the bottom then click VideoStudio Editor. New window will open click Capture,now look for capture video button on the right side of the black screen,click it Just to the right you will see an Options button click. A drop down will show,look to see if input source is in dark letters,if so open and set source to NTSC/M and composite video is checked. If the input source is greyed out,open Capture properties directly under the input source,a new box will open click properties a new box will open this box will have 3-4 tabs you only need the first tab called Image tab under video sources click ntsc/m and composite video click ok click ok again thats it you should now have video,After any restart you will need to reset ulead up again,you should be good to go...... Hope this helps :-} Here are some pic's to help.Note after the instalation,if you move the Easycap usb drive from the usb port it was installed in and input it into any other port it will not work,the driver will need to be reinstalled!!! 09c750d.pnge0aeff9.png78f955a.png New download links For Windows XP/VISTA/7 32-Bit, please download Windows 7 64-bit This web page I have not goten any link to open but thought I'd add it so you all can see it,if anyone gets it open please post any or all links for us all. Thats all for now I'll upload more as I get them. ps working with a company rep now,update for easycap d60 4 input style,If not getting a picture on input 1 move to 3 for setup and one camera setting.
on May 25, 2010 | DekCell EasyCap USB 20 Video Capture...
How do I get the recordings on the tape, to my computer? I plugged in in through a firewire but I still cant download it??
You will need: 1. A video capture software such as Ulead VideoStudio 10 2. firewire or USB cable
1.Connect your camera with the cable. 2.Start Ulead VideoStudio 10 3.Go to Capture tab 4.Select your Panasonic device as the input for Ulead 5.Hit the "capture" button.
Ulead will start playing your video as well as recording to the PC at the same time
Jan 21, 2011 | Panasonic NV-GS35 Mini DV Digital...
EasyCap - ''no input signal or signal is unclear'' Please Help!!!
In the ULead VideoStudio Application. Go to "Capture" tabbed panel. Select "Options" then "Video and Audio Capture Property Settings...". A window should pop up.
In the "Source" tabbed panel. Change the "Input Source" drop down menu to either "Video Composite" or "Video S-Video" depending on whether you are using the yellow or S-Video picture lead.
Change the "TV System" combo-box to PAL for colour and NTSC for black and white. On my computer S-Video option is showing black and white when using my Sky HD box, don't know why this is yet.
Try the above and you should get a picture. You can also change the frame rate and other compression techniques etc.
If it still doesn't work try changing your digital/sky/vcr/xbox picture settings to PAL for colour or others for picture preference.
Hope this helps.
Goodluck
OAC
Mar 06, 2010 | Ulead Videostudio 8 for PC
Easycap video adapter driver will not install on PC from the CD
Goto youtube.com. and search:How to get EasyCap Drivers or http://www.megaupload.com/?d=W64LW1DJ and type in the 3 LETTERS.Wait for the free download on the right side.After I installed the Syntek STK 1160 drivers I still could not capture.THIS STEPS SOLVED IT: 1.OPEN THE ULEAD VIDEO STUDEO PROGRAM 2.CONNECT THE EASYCAP USB DEVICE 3.ON TOP CLICK CAPTURE 4.IN THE MIDDLE CLICK CAPTURE VIDEO.5.UNDER THE WORDS:CAPTURE FOLDER, CLICK ON OPTIONS (THE LITTLE ROUND GEAR OBJECT) 6.CLICK VIDEO AND AUDIO CAPTURE PROPERTY SETTINGS 7. CLICK SOURCE 8. MAKE SHURE TV SYSTEM IS THE ONE IN YOUR COUNTRY 9.CLICK OK.10.A BLUE SCREEN APPEARED AND WHEN I PUSHED THE PLAY BUTTON ON THE DV CAMCORDER I COULD CAPTURE THE VIDEOIMAGE ON THE LEFT SIDE.
WHEN I INSTALLED THE ULEAD PROGRAM I DID SELECT THE TV SYSTEM IN MY COUNTRY(PAL) BUT WHEN I DID STEP. 7, I SAW IT WAS (NTSC).JUST FOLLOW THE STEPS.GOOD LUCK.I SOLVED MY PROBLEM IN 6 HOURS :p
Jan 28, 2009 | Ulead Videostudio 8 for PC
EasyCAP Video Adapter with no video
Ok, here is what is going on. The default video setting in control panel> scanners and cameras> syntek 1160 is pal-b it should be NTSC_M. Right click on the Syntek 1160 and click Video Decoder Property. Change it to NTSC_M from Pal. Do this with the unit plugged in or it wont be displayed in the Scanners/Cameras options box. Right away the signal line should rear 1 from 0 with video hooked up. Keeping that setting to stay is my issue right now. I was so excited to figure it out, I had to post. I was about ready to throw the unit away. Its a program driver error. Hope this helps!!!
Jan 09, 2009 | Ulead Videostudio 8 for PC
EasyCap Video Capture
Hi
I had the same problem. No picture and no sound.
Here is what I did to solve it.
1. I Un-installed the software and restarted the computer.
2. Placed the installation CD (that came with the product) back in the CD drive.
3. Click on "Install Driver" (this only installs the USB 2 drivers so that the computer can see the device)
Make sure you do not attach the Easycap Device before you have installed the USB Driver (as above).
4. Once USB Driver has been installed then plug in the Easycap USB Device, windows should then detect the new device, to make sure:-
5. Right Click "My Computer" "Properties" "Hardware" "Device Manager" check "Imaging Device" (which is where my STK1150 Driver was installed) and make sure it has no yellow exclamation mark next to it.
6. Go back to CD and "install the Uplead Software", you then have to Restart the computer.
Once all installed you can then connect your external device VHS Player/Camcorder etc to the Easycap device, using the Red/Yellow/White leads.
I like many before me, tried and I tried to get the image to play on the software "Capture" screen but all to no avail, I was pulling my hair out, I wasted two days on it, I finally decided that this product was a total load of rubbish and I had wasted my money and it had to go.
Then a major break through, some smarty pants made the comment about INPUTS & OUTPUTS, my prayers along with many others could have been answered ??....
I had actually plugged the Red/Yellow/White leads into the INPUT terminals of the external VHS Player, when they should be plugged into the OUTPUT terminals of the external VHS Player/Camcorder.
On a Camcorder the RED/Yellow/White terminals are usually Output terminals but on a VHS Player they are usually always Input only !!....
I tried running my Camcorder through the software and Hey Presto that worked a treat.
So in order to get my VHS to play through the software I ended up having to buy a Scart OUT (very important "OUT") Red/Yellow/White adapter (see link for product image)
http://www.maplin.co.uk/Search.aspx?criteria=scart%20out&source=15&SD=Y
Once all connected I pressed play on the VHS Player and I have to say that nearly fell off my chair "IT WORKED - IT WORKED - IT WORKED"
Sep 30, 2007 | Ulead Videostudio 8 for PC
Problem in Capture
I don;t know if this is the solution to your problem but it might work, as it did for me.
When you start ULead Studio click on the capture tab, then click on the camera icon named "capture video", then in the middle of the page you will notice the "options" icon (looks like a cog) go to Input source and then at the top of the window you will see "input source" again, click the dropdown list and select "video composite". Try that and see what happens.
Aug 01, 2007 | Ulead Videostudio 8 for PC
Computers & Internet Logo
David Payne
David Payne
