Question about Rancilio Silvia Espresso Machine
No Heat My Rancilio Silva is not making hot water or steam. I think the heating element is gone. Can I replace this myself?
  • 4 Answers
I disagree... I think its the thermostat reset switch. A little red button once you open up the machine. look towards the front of the boiler and bush the button. Same thing happened to my Rancilio Silvia.... I opened it up, hit the reset switch... and voila! Working again! Here's the YouTube Video on the details. http://www.youtube.com/watch?v=zQdJNm9RV68
Posted on Jul 29, 2010
  • 5,568 Answers
The element itself is not likely to fail for years.  All coffee-makers are provided with a thermal fuse located near the heating element and in series with the element itself.
This device is bullet-shaped with one lead connected to the case, the other insulated from it. If there was no protection of this kind, it could lead to a fire if the heating element fails to get turned off when reaching its design temperature and nearly impossible to buy as replacement parts.
These are not user replaceable and both the thermal fuse and the bimetal switch that controls the current for the heating element have become increasingly less reliable as they are made in China and since we have little alternative, we have to either keep track of our warranty or just throw it away when it fails.
The fuses can fail at any time and I have brought back three coffee-makers in a five day period, all with the same failure, before giving up and getting a refund.
Another type of failure, namely of the bimetal switch occurs over time and reveals itself by the ever-longer brew time that is unaffected by dissolving the lime in the system. The heat sensitive metal switch part becomes gradually less responsive causing the machine to just cough instead of pump as when new.  The last one I tossed had reached 40+ minutes per pot.
Posted on Jan 23, 2009
Descaling rancilio
Use Citric Acid.
  1. Dissolve about one tablespoon of citric acid in the water reservoir.
  2. Fill the boiler completely. Open the steam valve and start a hot water cycle until water comes out the steam vent. Stop the hot water cycle, close the vent.
  3. Let the boiler heat up about 5 minutes. Then turn off the power.
  4. Let the acid solution work for about 1/2 hour.
  5. Pull a 30 second shot to change the water in the boiler.
  6. Repeat flushing cycles (steps 3, 4, & 5) until the water looks clear. Refill the reservoir with water and acid as needed.
  7. Wash out the water reservoir.
  8. Pull 5 or shots to get the acidic water out of the boiler. Run a hot water cycle to clean the acidic water out of the steam vent.
  9. Let the unit come to temperature and look for leaks.
  10. Make some coffee and look for leaks.
  11. Froth some milk and look for leaks.
Jan 18, 2014 | Rancilio Audrey
Our rancillo silvia does not heat up water or make steam. the power light shows on.
Sounds like the heating element is fried, you will need to find a local person who understands basic electrical troubleshooting with a meter. Take the top off and have somebody meter voltage across the heating element electrodes if there is voltage ther,e but the machine is cold, your heating element positively absolutely has gone bye bye. We can repair this
WWW.DOLCEVITAESPRESSO.COM
Mar 04, 2011 | Rancilio Silvia Espresso Machine
The light on my rancilio silva expresso machine does not go on and the machine does not warm up. Last night it was fine - this morning dead. It appears that either the switch has gone or something else is...
There is also a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also another problem that you might have. If the brew thermostat is bad it won't heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
If none of these things work check the heating element with an ohms meter. The reading in the terminals should be from 12 to 16 ohms. If no reading the elements is bad and you have to replace the boiler.
Dec 11, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silva, after working well for three years, does not heat water when powered on. Suspect heating element bad. But is there a step I can take prior to replacing elements. Also, where can I get...
Remove the 4 screws on the top panel. Make sure machine is not connected to power. Check the thermostats on the boiler, there should be 3 of them, push in on the small red pin in the middle of them one of them should click in. Now fill up your tank plug machine in and turn on.
Oct 20, 2010 | Rancilio Silvia Espresso Machine
I've had my Rancilio Silvia Espresso machine for about a year and a half. I use it every day. Today, it won't heat up. It turns on but will not heat up. Is there a reset button? Help, please.
Hi
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also another problem that you might have. If the brew thermostat is bad it won’t heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
Jun 22, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia stopped heating up.
Hi
Check to see if it will heat in the steam position. If it does, then you have a bad brew thermostat, and just need to replace that. Its the one with the red dot. If not, run some water through the wand and see if it is milky? If its milky you have a blown heating element. You can also do an ohms check in the element. There should a reading between the element terminals of 12 to 16 ohms. If you have no reading, your going to have to replace the boiler.
Oct 26, 2009 | Briel Coffee Machine Multi-Pro...
5 year old Rancilio Silva with no heating of water
Hi
Do an ohms check on the element. With an ohms meter check the reading between the elements. The reading should be between 12 and 16 ohms for a 110v machine and 50 to 60 for a 220v machine. If you have no reading or a higher reading you have a bad element.
Replace the boiler
Jul 24, 2009 | Rancilio Silvia Espresso Machine
Super hot water out of the group head on my Rancilio Sylvia
My Rancilio Silva is not making the water or steam hot anymore. Is it fairly easy to replace the heating element?
Dec 29, 2008 | Rancilio Silvia Espresso Machine
New Rancilio Silva - steamed milk not perfect
please relay on your experience realizing that you now have new steam pipe(with different holes in the end of it and different pressure)
you will need to get use to them and get maximum quality of that steam pipe.
my advice:
  1. every time hold your hand in the bottom of milk container, so that you will prevent overheating which often gives the result you mentioned.
  2. every time you use cold milk.
Jul 22, 2008 | Rancilio Silvia Espresso Machine
Rancilio silva
Hmmm. It doesn't sound like a boiler problem. The heating element is controlled by a pressure or temperature switch. Either the switch is poorly connected or malfunctioning. Temp. switches are directly on the boiler with wires that go to a relay connected to the heating element. Pressure switches just have a tube connected to the boiler with wires to the relay.
Jan 25, 2008 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
327 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
