Question about HP iPAQ RX3115 Pocket PC
IPaq won 't respond to screen calibration.
I have an iPaq rx3115 and it won't respond or go past the calibration screen after a soft or hard reset. It does respond to the touch screen commands after a hard reset to start the reset process but stops at the cal. process. It has been doing some flaky things mostly in relation to the bluetooth and the wi-fi not working right preceeding this area. Is it done for? I hope not.
  • 1 more comment
  • Anonymous Nov 16, 2007
    Same problem as this entry. I used it one morning, worked fine. Got to work and turned it on and no reponse by touching the screen or any other buttons. Tried soft reset and didn't make any difference. Did a hard reset and then a soft. The alignment screen comes up now, but goes through process over and over of screen alignment, but nothing else.
  • Hiep Tran Dec 19, 2007
    I had the same problem,any one can help please.Thaaaaaanks.
  • mauriciobp May 11, 2010
    and the solution???
    please write me......maurybp@gmail.com
So far no fixes. It's just been collecting dust. I think it's a screen response issue, and will probably cost more to fix than to replace (at least for me) in my situation. I'm thinking iPhone....
Posted on Feb 27, 2008
IPaq rx3115 screen unresponsive
Bad screen if the driver was bad they would tell you that you are having a problem with the driver
Feb 07, 2009 | HP iPAQ RX3115 Pocket PC
Ipaq rx3115 frozen
Red LED light means a major problem at the charging of the battery.
You have several options to repair it:
1. Leave several hours the PDA with not battery and unplugged from the AC power adapter, then put the battery and leave charging it.
It's more likely that the red light will appears again, but leave plugged it. Sometimes will start charging and blinking with orange color after 30 minutes or so. After that, it will work normally.
2. Use other good working battery to test it.
3. If the above two steps fail, then there is a good chance that the mainboard has a problem, and needs to be fixed or replaced.
Best regards,
Jan 25, 2008 | HP iPAQ RX3115 Pocket PC
Ipaq rx3115
If I understand correctly your problem, the touch screen of your PDA is not working.
Well, this is a common IPAQ failure. When happens, the only options to repair it are:
1. Soft reset of the PDA. If still does not work, then go to next step.
2. Replace the top digitizer glass.
It requires a very skillful person to do it. If you have not experience with fixing electronic devices, then I do suggest you to send it to repair.
Besides that is necessary to open it, you will require a soldering iron, and desolder the digitizer part and remove it from the LCD screen, which if is not done properly with the right tools, it's easy to damage the LCD screen assembly.
Also, if it's not opened right, is possible to damage permanently the mainboard if is bent or warped.
Also, even though there are a lot of cheap digitizer replacement parts on-line (mainly from China), they have a compatibility issue that prevents to use them in the RX3715 (or RX3115) PDAs.
I have nothing against Chinese manufactured parts, but after buy around 10 digitizers in the last couple of years for different Ipaq PDAs, I found out that only 3 worked fine, so I know what I am talking about.
Best regards,
HP rx3115 hard reset
Had the same problem with my hp rx3115 . Worked fine, then the next day dead. power button, lower buttons, or outter reset button didn't work to turn it on. Okay so, i thought it just needed to recharge. Used computer cable for active synchronizing that also recharges, still dead. Then cable just for recharging. Finally comes on. Charged it all the way up, synchronized it, unplugged it, few minutes......dead. The battery is no good.
Nov 16, 2007 | HP iPAQ RX3115 Pocket PC
Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
Sep 27, 2006 | HP iPAQ RX3115 Pocket PC
Ipaq rx3115 doesnt turn on!
I am guessing that you have made sure that it is fully charged. If it is, since you have only had it a week I would try a hard reset. I don't know if the 3115 has them but check to make sure that any battery door lock switches are locked.
Sep 14, 2005 | HP iPAQ RX3115 Pocket PC
Soft Reset
Just loaded a safe mode program to my iPAQ, and now it seems to reset without any problems, even when not connected to the sync cable.
Sep 12, 2005 | HP iPAQ RX3115 Pocket PC
IPAQ rx3115 would not bypass the screen aligning
I experienced the same problem with my rx3115 after having it for 3 days. It is working again, fortunately. I removed the battery from the device and left it alone for 24 hours. I then reinstalled the battery and connected the charger. When it powered up, it went through the initialization process in the same way that it did when I first used it. I hope this helps you out with your iPAQ.
Sep 08, 2005 | HP iPAQ RX3115 Pocket PC
Rx3115 locking up
To execute a hard boot on the iPAQ rx3115, the manual says to "while pressing the two outside buttons on front of iPAQ, press the recessed reset button on bottom." Hope it Helps... Wirzan
HELP Rx3115 today screen help
Did you try doing a soft reset? Switching off and on again does not reset your ipaq. You will not loose any info.
HP iPAQ RX3115 Pocket PC Logo
340 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
