Question about GE 30 in. JP340 Electric Cooktop
GE profile performance electric cook top is not producing enough heat in the front burners.
  • rickmarooney Jul 05, 2010
    The burners were working when we first purchased and for up to a year or so after. Then the right large burner comes on but the heat is not sufficient to do anything other than produce a little heat and turn the red light on indicating a burner is on.
    President:
  • 1,214 Answers
Confirm there is 240 VAC powering the unit (make sure a breaker has not tripped or a fuse blown.).
Did the burners ever produce enough heat?
If yes, then we can look deeper. If no, then the burners may not be adequate for your cooking style. Burners are like light bulbs. A 60 watt bulb will put out more light than a 40 watt bulb. A 100 watt bulb will put out more light than a 60.
Typically, a small burner will provide less cooking heat than a large burner.
Posted on Jan 23, 2009
How to replace a radiant burner element wb30t10062 on a cook top not a combo, oven and cooktop
Search for my solution for a replacing the element on a JP939/JP969. That should help for similar GE models.
Sep 10, 2011 | GE 30 in. Profile JP939 Electric Cooktop
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Ge profile electric counter top stove
I did not receive instructions with my G E Profile cook top Model No. 80030750434). There is a build up on the elements which I am having problems removing. Should the top be scraped while the stove is hot or cold? What is the best cleaning product to use?
May 01, 2008 | GE Profile JP930 Electric Cooktop
We have a 5-burner GE cook top/ The igition for the center burner continually fires.
the spark modual is bad in the cooktop. you can just leve it unpluged and light with a match until you can get it replaced
Nov 22, 2007 | GE 36 in. Profile JGP962 Gas Cooktop
GE 30 in. JP340 Electric Cooktop Logo
304 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
