Question about Microsoft Windows XP Professional for PC
Bsod 0x0000007b when i format my hard disk. - Microsoft Windows XP Professional for PC
  • Ron
    Ron May 11, 2010
    Please clearly describe when it happens and how you get there.
    This could be due to bad harddrive, or because you do not have the appropriate IDE, SATA or RAID drivers on your windows CD.
    What system or motherboard are you using, are you using the CD that came with your system, what Windows Version CD are you using?
  • DEKR
    DEKR May 11, 2010
    did you format with boot from cd
    President:
  • 814 Answers
Check out this web link for information on your problem and possible solutions. http://pcsupport.about.com/od/findbyerrormessage/a/stop0x0000007b.htm You can also google the error code and find lots of information on the causes and possible fixes for the problem. The real problem may be that the harddrive itself is corrupted beyond repair. In that case the only fix is to replace it. I hope this information helps you with you problem
Posted on Jun 01, 2009
I try to load windows xp or 7 and as it starts to copy files i get the bsod. ive tried to reinstall over 5 times and while its loading it come up with the bsod
Have you done a disk scan of the hard drive? Did you set a partition and make it active? Have you tried letting the software partition and format the drive?
What error codes were provided with the BSOD?
Mar 09, 2015 | Computers & Internet
When i am trying to instaling win xp .getting a error message like stop 0x00000007B in a blue screen
hello Shameeralipk,
The most popular Blue Screen of Death error in Windows is the STOP 0x0000007B error, sometimes called the 0x7b error or the "INACCESSIBLE BOOT DEVICE" BSOD.
This BSOD (which is actually the common name for a STOP Error) could mean that there's a serious hardware problem with a hard drive controller, a driver issue, or even a boot sector virus.
thansk.
Sep 06, 2011 | Acer Extensa 4230 Notebook
Hi there! i just bought a new acer aspire m5641 (the rep told me that the computer doesnt come with an OS but when i booted it, linpus is installed) on my CPU there is a sticker that states...
Stop: 0x0000007B error code refers to memory issues
You need make some changes in your computer before installing XP
1. On start up, press F2 to enter BIOS 2. Expand the "Drives" section 3. Go to "SATA Operation" 4. Change this from "RAID Auto/AHCI" to "RAID Auto/ATA"
You will be able to install XP now
Jun 30, 2011 | Acer Aspire M5641 PC Desktop
Im trying to install windows 2003 on Dell optiplex 780. During installation BSOD occur stating that STOP: 0x0000007B
its simple start by fixing the disk with woindows 98 then u can now install windows 2003
May 26, 2011 | Computers & Internet
I own a dell optilex gx50 with original windows xp, seagate st320014a 20 gigabyte hard drive which might having a possible virus issue because i get a bsod that has the following. *** STOP: 0x0000007B...
dmacduff1443
Just because you get a BSOD message does not mean you have a virus. Granted if you have a virus this can cause problems with your system files which cause a BSOD.
The easiest way to clean your system would be to go to this link and run a scan on your computer.
http://housecall.trendmicro.com/
However this still may not fix the BSOD issue. If you keep getting it please reply with the error message that is in the BSOD. The link below will show you what is needed if you are not sure. With the error message and stop code i can tell you where the problem is.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Issken
http://www.fixya.com/users/issken
Jan 16, 2011 | Seagate (ST320014A) (st320014a-25tpk) 20...
I bought a ep43-ud3l mobo that I installed with windows, after moving some files from my old hard drive windows became corrupted , boot up resulted in BSOD, erased windows bsod, formated HD BSOD, removed...
pls check the cpu compatibility. one time I tried to install 64bit , but could;t install. 32 bit was ok. check the video adapter and remove it and try it with on board vga
Jul 17, 2017 | Gigabyte GA-EP43-UD3L Motherboard
Hello, My laptop will not start the windows set-up/Fresh Install scenario. after the drivers get loaded and says starting windows it goes to the BSOD error Stop 0x0000007B, I figure this to be a MBR virus...
In Figure 2-2 you can also see that the Windows service SPCMDCON.SYS has failed. From the BSOD, you should be able to gather the following information:
•The stop error number, which uniquely identifies the error
•The stop error parameters, which provide additional information relating to the specific stop error number
•Driver information is available if the source of the problem relates to drivers
Armed with this information, you are able to search online to establish the problem and hopefully a resolution.
In addition to the information available on the blue screen, if the system is able to be rebooted after the BSOD, either normally or using Safe Mode, it is useful to take a look in the System Event Log and view the error message. For example, a faulty driver during boot up usually has the stop error code STOP: 0x00000050 and an Error EventID of 1003.
If your system refuses to reboot successfully, or is trapped within a perpetual BSOD that restarts over and over again, you should take the following steps. Press F8 after the BIOS screen appears. From Advanced Boot Options, select Disable automatic restart on system failure, as shown in Figure 2-3. This allows you to read and make note of the information contained on the BSOD. You can then allow Windows to attempt a reboot. If the perpetual loop reoccurs, select another option, such as Safe Mode, from the Advanced Boot Options menu.
To disable the system from automatically rebooting, take the following steps:
1.Click Start, right-click Computer, and select Properties.
2.Click Advanced System Settings.
3.In the System Properties dialog box, click the Advanced tab. Under Startup and Recovery, click Settings.
4.In the System Failure box, clear the Automatically Restart check box.
These steps can also be configured if the system is booted in Safe Mode. There are over 300 unique stop codes, and most are quite rare. The full list
can be found on MSDN within the Bug Checks (Blue Screens) reference at
https://msdn.microsoft.com/en-us/library/windows/hardware/hh994433(v=vs.85).aspx.
Jun 11, 2017 | Sony VAIO VGN-NS140E/S Notebook PC
After formatting my pc is unable to run
(1)When you power up the computer press F8 key thne if you are able to see safe mode and other menu then enter in safe mode.Then go to start menu->run type in run "chkdsk /r"
thne press "y" then scan your computer with antivirus. uninstall that antivirus because sometimes it conflict to windows.
then restart computer thne wait untill it check disk and fix errors.
Then you can see desktop screen.
(2)But if you are not able to enter in safe mode then you need windows disk or recovery disk.
Then boot computer with that disk.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot option and set frist boot device as your cd or dvd drive.
Then save and exit settings.
Then insert disk in rom then it boot with that disk.
then follow the procedure and enter in recovery console .
Type in console prompt "chkdsk /r"
the press "y"
then it fix error on disk.
Then check in normal mode if still not load windows then follow above procedure again but this time select repair previous windows option so it repairs old windows and you get your old windows .
Let me know if you need further assistance.,
Thanks
Nov 06, 2009 | Computers & Internet
BSOD
This error means that the system is unable to access the boot device...for info on the causes and resolution of this error plz follow the following links
http://support.microsoft.com/kb/316401
http://support.microsoft.com/kb/324103
Jun 24, 2009 | Seagate Barracuda 7200.10 ST380815AS 80 GB...
How to chkdsk/0x0000007b
Go into your BIOS when you first turn on the laptop. Look in there and see if it is seeing the hard drive. If it sees it, then I would suggest try using a boot disk, to format the drive. If you can format the drive, then try installing Windows XP from there and it should do it then. If you BIOS doesn't see it then you'll need physically take the hard drive out of the laptop and reseat it and hope the BIOS sees it. If it doesn't see it then you need to get your hard drive replaced.
Jan 13, 2009 | Acer Aspire 4315 Notebook
Microsoft Windows XP Professional for PC Logo
257 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
