Question about Hoover Vacuums
I want to install a hoover sh 80540 central vac
Central vac windtunnel hush sh 80540
  • 126 Answers
SOURCE: Hoover self-propelled windtunnel belt pops off
The correct belt is a 38528035. If the belt does not have this number printed on it, it is a generic belt and probably the wrong one. The pulley on the transmission is "convex" because this pulley design keeps the belt running in the middle. (a belt will always try to "climb up a hill") If the motor shaft and the pulley are not aligned properly, the belt will constantly throw off. This can be a result of a bad motor mount (located inside the motor compartment.) The motor shaft end has a rubber cover that absorbs vibration and keeps the motor positioned squarely. The handle could also be loose on the pivot. It is held down by two metal clamps that screw securely to the bottom, holding the handle on to the base and allowing for the handle to pivot backwards. This problem can be difficult to diagnose and I have had many in my shop for repair. It takes a seasoned and experienced repairman to find a solution to this problem, in most cases. The disadvantage I have here is that I cannot see your machines to inspect all the various things that effect the belt alignment. I hope that some of this information will help.
Posted on Jan 20, 2008
reddevil6
  • 1673 Answers
SOURCE: Hoover Hush Series Central Vac won't turn on
If the low voltage wires are hooked up to it, then you probably have a stuck relay inside the cannister. It could also be the switch in the hose handle.
Posted on Feb 12, 2008
SOURCE: auto brush on hoover windtunnel doesn't spin anymore
I have a Windtunnel S3765 with the same problem - and it has very little use so I'm confident it isn't wear. I find that the wheels do not raise the agitator brush sufficiently high to reduce the drag caused by excessive contact with the carpet. If I raise the front a bit the brush spins as it should. It also works if I take the housing apart and use it without ..... but this is tricky.
Unfortunately I haven't figured out a way to hold it up efficiently. I am toying with afixing something to the bottom of the housing to raise the front enough to give the brush a little more room.
Posted on Jul 09, 2009
  • 8 Answers
SOURCE: Hoover Windtunnel shuts off
I found the following solution on this website. I have searched for hours and finally found this solution, it works! I HAD the same problem after cleaning the filter mentioned below, it is now working like it was new.
***by maverick_bea***
yes this machine has a thermal protector in it to shut off the machine if it gets to hot, this is normal. if there is no clogs in the hoses or in the machine then you will need to wash the filter at the top of the machine. you will have to remove the dirt cup and at the top you should see a half moon orange, well inside of this piece is the washable filter, clean and let it dry completly before putting back into machine. if this gets dirty and has not been cleaned, you can lose alot of suction. in some cases if this filter is not cleaned it can cause the machine to overheat so bad that it can damage the motor.
Posted on Oct 25, 2009
Vac Belts
  • 701 Answers
SOURCE: Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Posted on Dec 23, 2009
Testimonial: "Replaced the belts-- works GREAT!!! Thanks"
How to replace belts on windtunnel
THIS VIDEO WILL HELP YOU
Sep 24, 2014 | Hoover Vacuums
Hoover windtunnel dirt finder light stays red. We've cleaned the elbow the roller the hose and have a clean bag. The vacuum is new only had it for 3 months.
I'm not sure about a 3 month old vac, I'd probably go the warranty route. However, for the older vacs thy start getting false positives. The sensor is simply a microphone hooked to a computer chip detecting sounds of dirt entering the bag.
To rig it to start working, you'll need to remove the tool accessory tray and elbow that enters the back of the vac, and attached to the bag. This will reveal the microphone at the elbow, and wire that runs into the bottom area of the vac. When on, a large amount of air comes from the bottom screw and area where the wires enter. My fix was to clean up the microphone contact points a little bit with a screwdriver, and then leave the vac running while putting in dampering in the hole at the bottom, and around the back of the elbow. Cotton balls and electrical tape at the bottom hole, and napkins around the outside of the elbow (wedged between the back of the vac assembly and elbow did the trick). The schematic for the vac is here: http<colon>//www<dot>vacsrus<dot>com/CartGenie/pg_U6485900<dot>asp
Look for micrphone.
May 12, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
HOW DO YOU REPLACE THE BELT ON A HOOVER US140-900 WIDEPATH TEMPO VAC
To help you in your efforts to change your belt here are some good resources. This is the manual for your vacuum. It explains how to change the belt:
Manual for HOOVER U5140-900 WIDEPATH TEMPO VAC
Here you can get replacement belts for your models:
http://www.vacbelts.com/hoover-40201160-belt.htm
Oct 20, 2009 | Hoover S1410 WindTunnel Porta Power Bagged...
Hush - Insufficient suction
You need to approach this step by step. If you have insufficient suction at all locations you need to check as follows:
1. Hose, drop a coin through from the handle to the wall end, with the hose detached from the wall. If the coin goes through from one end to the other the hose should be clear. If the coin stops it will rattle inside where the obstruction is if you gently shake the hose you will feel it through the wall.Obstructions in hose or pie need to bee **** wards out of the hose or pipe.
2. Vac. Go to the vac itself and see if the onboard inlet has suction. If it does your problem is beyond the vac. If not your problem may be a leak, either a broken inlet, with a cracked or sagging door or jammed hinge, a clogged intake in the vac, or damage to the pipe within the house or a twisted gasket where the pail of the vac secures to the body, or an issue with the motor itself..
3. Take the hose, inlet to inlet and check all locations in the house. I mark a tissue with a number for each inlet and plug in the hose, one inlet at a time. If the tissue makes it all the way to the bucket from each location, that means the branch line for that location is clear. I work from the closest inlet away to the furthest checking for tissues one inlet a t a time. This will help pinpoint location of any blockage in the main line.
4. If you have had any renovations or painting done it is not uncommon to disturb the seal behind and inlet or pierce your piping with a nail or screw. Check for all these and post back to say waht you have found.
Sep 27, 2009 | Hoover S5636 Hush Central System Vacuum
How to install the belt on the hoover self propelled vac
Video Repair instructions on installation of Hoover Windtunnel Self-Propelled vacuum ;
If you found the video helpful, please be sure to rate it by clicking the thumbs up icon below. If you have any questions about this repair, please request a clarification below.
Thank you,
Chris
Jul 03, 2009 | Hoover U5753-900 WindTunnel Bagless...
Need to replace power cord on Hoover windtunnel need wiring help
without seeing this it would be difficult to describe. I would take it to a vac shop and let him show you. there are no real schematics for the wiring of these units. I usually would cut off the cable with a few inches of insulation to know where to install the new one and reuse the old terminals if needed.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Feb 24, 2009 | Hoover U5399-900 WindTunnel Lite Upright...
Hoover Commercial Windtunnel C1705-900
I do not know what price you have, but it depends on the condition of the vac, compared with new exact replacement.
Jan 23, 2009 | Hoover Commercial Windtunnel C1705-900...
Dec 03, 2007 | Vacuums
Vacuums Logo
191 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
