Question about Uniden D3588-2 - D3588-2 Dect 6.0 Bluetoothr 2-handset
D3588-2 I received this phone set for Christmas and tried to put it to use. I went through the manual that came with it and followed the setup directions. Everything seems to be working well with the exception of getting the hand held sets registered to the base unit. One hand held unit did not asked to be registered while the other did. Both these units were plugged into a power supply for two days meeting the 15 hour requirement and would assume charge the battery's completely. I've tried several times with no success to register this unit to the base. The only solution for this problem in the manual is to "charge the battery completely and try again". Because this is the only problem solution in the manual for this problem and I don't believe that "charging the battery" again is going to be the solution I'm looking for some help short of returning it.
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Posted on Apr 13, 2008
SOURCE: my Uniden cordless' handset and the base wont register Can it be bypassed or decoded
Here it is step-by-step: 1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it’s workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there’s no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Posted on Dec 13, 2008
  • 84 Answers
SOURCE: Trying to register used handsets
There are a couple of things that may be the problem with this. First, are you sure that the handsets are compatable with the base you are trying to register them to? Second, how many handsets are currently registered to the base unit? You may be trying to register more handsets than the base can handle. and lastly, try doind the de-registration of the handset this way, press and hold the "End" key, while pressing the "End" key, also press the "#" key. The lcd should show two options, select "Base Unavailible" and confirm. The LCD on the handset should then say to place it in the base to register it. If that doesn't work, post with the results of trying the above steps and I will try to help you further.
Posted on Apr 03, 2009
SOURCE: Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Posted on May 06, 2009
SOURCE: Reads out of range when I try to connect to base.t
call doesn't go through
Posted on Jan 18, 2010
Sony tv netflix register
I think you have to create an account on line and then connect your device to your account not sure but I think that's right hope that helps Merry Christmas
Dec 09, 2017 | Car Audio & Video
Systems setup
Hii,
Try this out:
Go to the display settings in the settings menu. Pick HDMI for your video output and follow the steps to set your screen resolution. When I accepted the video settings I was taken automatically to the audio settings options. If you’re not given this option just go to the set audio output settings and enter this screen. Pick the optical connection and follow the screens choosing the audio options that match your receiver. DD and DTS.
At this point you should have video to your TV through HDMI and audio to your receiver through the optical cable.
Goodluck,
please dont forget to rate me as fixya..
Jan 28, 2008 | Denon AVR-3801 Receiver
I received a vizio m370nv tv for christmas. The tv was set up and went through the setup wizard. The tv turns on then after about 5 seconds it turns off. Is there a reset button or is there a way to get...
You can reset to factory default with the remote. Menu button, then look for settings. Usually identified with little gear iconmoz-screenshot.png or tools icon.
Jan 03, 2011 | Televison & Video
When setting up my receiver the subwoofer is not putting out sound. It is connected and on.
hi,
first of all check ur sub woofer is it working or not. for that pull out its RCA connection from the receiver. power on the sub woofer and touch RCA's middle pin with ur finger. if its working it will produce a hum. if ok, go for the next,
do the following setup in ur av receiver
press menu and select manual setup and press enter
in manual setup select speaker setup and press enter
in the speaker setup select sub woofer and turn it on .
ok
Dec 23, 2010 | Denon AVR-2308CI
Can't receive fax's......how do you set it up to receive...thank you
In the HP Solution Center, click Settings, point to Fax Settings & Setup,
and then click Fax Setup Wizard.
After you have connected the phone cord to the port labeled 1-LINE, run the
fax test again to make sure it passes and the HP All-in-One is ready for faxing.
Try to send or receive a test fax.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
Scenario 2
If you are not using a distinctive ring service, check to make sure that the
Distinctive Ring feature on the HP All-in-One is set to All Rings. For
information, see Change the answer ring pattern for distinctive ringing.
? If Auto Answer is set to Off, you will need to receive faxes manually;
otherwise, the HP All-in-One will not receive the fax. For information on
receiving faxes manually, see Receive a fax manually.
? If you have a voice mail service at the same phone number you use for fax
calls, you must receive faxes manually, not automatically. This means that
you must be available to respond in person to incoming fax calls. For
information on setting up the HP All-in-One when you have a voice mail
service, see Fax setup. For information on receiving faxes manually, see
? If you have a computer dial-up modem on the same phone line with the
HP All-in-One, check to make sure that the software that came with your
modem is not set to receive faxes automatically. Modems that are set up to
receive faxes automatically take over the phone line to receive all incoming
faxes, which prevents the HP All-in-One from receiving fax calls.
124
HP Officejet 6300 All-in-One series
User Guide
Note Some digital answering machines might not retain the
recorded silence at the end of your outgoing message. Play back
your outgoing message to check.
If the HP All-in-One shares the same phone line with other types of phone
equipment, such as an answering machine, a computer dial-up modem, or a
multi-port switch box, the fax signal level might be reduced. The signal level
can also be reduced if you use a splitter or connect extra cables to extend
the length of your phone. A reduced fax signal can cause problems during
fax reception.
To find out if other equipment is causing a problem, disconnect everything
except the HP All-in-One from the phone line, and then try to receive a fax. If
you can receive faxes successfully without the other equipment, one or more
pieces of the other equipment is causing problems; try adding them back one
at a time and receiving a fax each time, until you identify which equipment is
causing the problem.
If you have a special ring pattern for your fax phone number (using a
distinctive ring service through your telephone company), make sure that the
125
If you have an answering machine on the same phone line with the HP All-in-
One, you might have one of the following problems:
- Your answering machine might not be set up properly with the HP All-in-
One.
- Your outgoing message might be too long or too loud to allow the HP All-
in-One to detect fax tones, and the sending fax machine might
disconnect.
- Your answering machine might not have enough quiet time after your
outgoing message to allow the HP All-in-One to detect fax tones. This
problem is most common with digital answering machines.
The following actions might help solve these problems:
- When you have an answering machine on the same phone line you use
for fax calls, try connecting the answering machine directly to the HP All-
in-One as described in Fax setup.
- Make sure the HP All-in-One is set to receive faxes automatically. For
information on setting up the HP All-in-One to receive faxes
automatically, see Set the answer mode.
- Make sure the Rings to Answer setting is set to a greater number of
rings than the answering machine. For more information, see Set the
number of rings before answering.
- Disconnect the answering machine and then try receiving a fax. If faxing
is successful without the answering machine, the answering machine
might be causing the problem.
- Reconnect the answering machine and record your outgoing message
again. Record a message that is approximately 10 seconds in duration.
Speak slowly and at a low volume when recording your message. Leave
at least 5 seconds of silence at the end of the voice message. There
should be no background noise when recording this silent time. Try to
receive a fax again.
Scenario 3
The HP All-in-One might be dialing too fast or too soon. You might need to
insert some pauses in the number sequence. For example, if you need to
access an outside line before dialing the phone number, insert a pause
following the access number. If your number is 95555555, and 9 accesses
an outside line, you might insert pauses as follows: 9-555-5555. To enter a
pause in the fax number you are typing, press Redial/Pause, or press the
Space (#) button repeatedly, until a dash (-) appears on the display.
You can also send the fax using monitor dialing. This enables you to listen to
the phone line as you dial. You can set the pace of your dialing and respond
to prompts as you dial. For more information, see Send a fax using monitor
dialing.
? The number you entered when sending the fax is not in the proper format or
the receiving fax machine is having problems. To check this, try calling the
fax number from a telephone and listen for fax tones. If you cannot hear fax
tones, the receiving fax machine might not be turned on or connected, or a
voice mail service could be interfering with the recipient's phone line. You
can also ask the recipient to check the receiving fax machine for any
problems
Dec 03, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I have a hp 2200 all-in-one printer. For some
if it sends ok, then it has probably been switched to "manual receive" form "automatic mode"
Apr 21, 2009 | Office Equipment & Supplies
Cant send faxes or recieve
Do you still have the problem?
Did you go through the entire setup procedure according to the manual including the fax/tel set up? Fax/tel setup tells the fax machine how you are using it. For example is the phone line used for just receiving faxes or is it used to receive phone calls AND receive incoming faxes OR is there a telephone answering device (TAD) attached to your phone line. If there is one, set it to 2 rigns. If you have it set to 4 rings the fax could disconnect before receiving the incoming fax. If you cannot send, then it has to be a line problem assuming you went through all the set up procedures correctly. Short of this you may have a bad unit and need to return it.
Apr 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
Fax doesn't recognize incoming phone call
Try this: using a cell phone, call your fax. Listen on the cell for a busy signal, fax tones, dial tone, etc. If the fax does not answer the cell, check the following: make sure the phone line is plugged into the LINE jack on the fax, NOT THE PHONE JACK. The phone jack is to connect a TELEPHONE to the fax. If problem still exists, press MENU on your MFC, and scroll to GENERAL SETUP, FAX. Scroll to SETUP RECEIVE, and, after writing down the settings, try changing the RING DELAY or RING TIME settings. If problem is still there, press CLEAR/BACK button until GENERAL SETUP appears on screen. Scroll down to INITIAL SETUP, and select RECEIVE MODE. Try changing RECEIVE MODE settings. Write them down before you change anything.
Sep 01, 2008 | Brother MFC-5840CN All-In-One InkJet...
How to receive faxes automatically
First this is a good machine, I use the same one and have my fax setup for the same thing. If you have a (TAD) Telephone Answering Device first you have to set up your phone to pick up before the fax, do this by setting the phone to pick up on three rings and the fax to pick up on four. Go to Menu/Fax/Setup Receive/Ring Delay. While there make sure Easy Receive is on. The machine itself will distinguish between regular calls and facsimiles and will display this info at the time of the call on its LCD screen, make sure you are using the line connection and not the phone connection. Hope this helped.
Jul 01, 2008 | Brother MultiFunction Center MFC-440CN...
No zone 2 sound coming from yamaha amp rx-v861
We had the same problem - I think it was reset when the power went off in a storm. Went to Yamaha website (http://www.yamaha.com/yec/faq/faqdetail.html?CNTID=206010&CTID=5009135) and found the following worked:
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control [SIDE SELECTOR SWITCH] to [AMP]. (Located to the right of the volume buttons on the Remote).
  2. Press the [SET MENU] button on the remote control.
  3. Arrow down to Manual Setup and press the [ENTER] button on the remote control.
  4. Arrow to the Sound Menu option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
Feb 16, 2008 | Yamaha RX-V661 Receiver
Uniden D3588-2 - D3588-2 Dect 6.0 Bluetoothr 2-handset Logo
55 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
