Question about LG 19LG30 19 in. LCD HDTV
Green vertical stripes down right hand side of screen, no picture
Problem persists no matter which av mode is on
    Scholar:
  • 87 Answers
Single color vertical stripes are an indication of a defective panel or panel control.
Posted on Jan 23, 2009
    Problem Solver:
  • 7 Answers
Unfortunately this means that your TV may be damaged. I would suggest talking to a professional or consider replacing your TV depending on the cost of fixing it.
What it means is that the power to that line of LCDs in your screen is 'stuck' and it is generally not user-serviceable.
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Thin green vertical lines
if its only one channel its your cable service, if its constant try unpluging your tv from the wall for 30 seconds to reset it, also try reconnecting any AV cables for the source you are using, If you are using a Coaxial cable unscrew it and check to see the copper needle is not bent or damaged.
Dec 19, 2013 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My RCA L42FHD37YXII has dark green and light gray vertical stripes on left side of tv it is on all connections
the screen might be broken. when that happened to one of mine i found a crack on the edge of the screen in the glass/plastic? type stuff but it only affected the aria right near the crack. found out my roommate chucked his glasses at it. if not idk
Sep 30, 2012 | RCA L42FHD37 42 in. LCD HDTV
Coloured lines on screen
Make sure first that the picture is centered by using the remote control to move the picture vertically and horizontally. Use the round pad towards the center of the remote and push the button according to which direction you want the frame to move.
Sep 10, 2009 | Philips 42 in. Plasma TV
Blue vertical line at reght side of screen
This is normal. Depending on what you have connected to it the lines could be white, black and white specs, or green. Just mode will show the entire picture event the parts that aren't supposed to be seen. I would not recommend that setting. Full is the best mode if you want to see the entire picture in the correct ratio.
Apr 24, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
Aug 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hi. i have an LG 42inch plasma, approx 18 months old. about 2 months ago, a green stripe developed down the right hand side of the screen, approx 1.5 inches wide. last week a 2nd stripe the same width...
Sadly, the plasma screen is failing. The green strip is no longer functioning properly and the failures will continue to progress.
If still under warranty, get it exchanged.
Jun 12, 2008 | Computers & Internet
Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Jun 09, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Philips 300wn5 green stripe on screen
I have a similar problem, what is the fix?
Mar 23, 2008 | Televison & Video
LG 19LG30 19 in. LCD HDTV Logo
544 people viewed this question
Computer Repairing
Computer Repairing
