Question about Kenmore 24032\24036 Top Load Washer
My kenmore washer wont hold water while trying to fill up?
The water just goes down the drain when its trying to fill up. does anyone know why that would happen? and what should i do?
  • 5,911 Answers
You may have a condition known as siphoning. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Sometimes, what appears to be a major problem, may only be a simple matter of placement of the drain hose. An easy test is to pull the drain hose out of the standpipe. If a sucking sound is heard while lifting the hose, you have a vacuum caused by lack of a proper air gap. If you still have questions, or require additional assistance, please let me know BEFORE you rate the solution. I hope this helps you.
Posted on Jan 23, 2009
I have a kenmore model 110 top loading washing machine that keeps draining and wont fill up but sometimes it does and sometimes it does not. Help!
Your drain hose is too far down into the pipe behind the washer. What's happening is your drain hose is actually siphoning water from th washer the same time its trying to fill up. Pull the drain hose up from the drain pipe and secure it so its doesnt fly out when the washer is draining. Check too see if the problem goes away. If not pull the drain hose out more repeat steps.
Feb 17, 2010 | Washing Machines
My washer wont hold water
Hi
Make sure your drain hose is not sitting on the floor.
You need to make sure the drain hose goes up to the hight of the tank and then back down to the drain.
If the hose is sitting low, then gravity will just drain the water out.
Let me know if this is not the case and I will dry and diagnose if there is a nother problem.
Ash
Nov 06, 2009 | GE WBSR3140DW Top Load Washer
417.43142300 Kenmore drains while trying to fill with water
try this the drain hose from the washer is stuck to far down the drain .allow only 8 to 10 inches down drain if the house drain is lower than top of tub it will do the same thing. raise the drain haundi24
Oct 27, 2009 | Kenmore 43142 Front Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Will not fill with water goes right down the drain,works sometimes
Your drain line is too low or there is a air gap blockage.
Remove the drain line from the drain and hold it up high while filling with water and see if it fills and stops.
If so, correct the drain line problem.The drain hose should be 36 inches from the floor.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
Washer fills up than starts draining while in wash cycle
Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
Phil
Jan 28, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 70 series Model: 22702 100 Series CL2738136 Type 111 will not hold water
the drain pipe in the wall needs to be as tall as the cabnet of the washer. if it is the see how much hose is going into the drain pipe. should only be about 9 to 12 inches into the pipe. any more than that will cause a syphon and suck the water out as it fills
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Water just runs through tub
The problem you are experiencing is called "siphoning". Check the drain hose going into the standpipe (drain pipe). If the hose is shoved down in the standpipe too far, or if you've sealed the top of the standpipe where the hose goes into, you have created a vacuum and are causing the water to continuously drain. The drain line needs an air gap to prevent this problem. Pull the drain hose back out enough to allow an air gap and make sure you don't have anything covering the top of the standpipe. Hope this helps.
Jun 15, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
112 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
