Question about PNY 4GB USB 2.0 Flash Drive - Grey/Black
Opening the flash drive case
How can I open the flash drive to reveal the USB plug
  • Roberta Smith
    Roberta Smith May 11, 2010
    shouldn't have to... it should slide out
    Robert
  • 86 Answers
Remove the protective cap on one of the sides.
Posted on Jan 26, 2009
My pen drive unable to show my data on it & aiso not detect in any pc or laptops.What can i do?
If the flash drive is not detected, it means there is damage to hardware.
Flassh drive hardware malfunction, there are two types
1. Cracked solder.
Solution: Open the flash drive casings, heat the tin solder.
2. Resistor (R) broken
Solution: Open the casing flash drive, flash drive instead of resistors.
Hopefully this information helps
Nov 09, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Tip
How to Download Files to USB Flash Drive
MS Windows Users<br /> 1.Connect the USB flash drive to an empty USB port on your computer. <br />Depending on your computer, there can be USB ports on the back, side or front. The flash drive can also be connected to an external port hub device. Once you connect it, the computer will automatically recognize it as a removal device.<br /> 2.Double-click "My Computer" on the desktop. You should see your USB flash drive's icon listed together with other removal devices on your computer.<br /> 3.Double-click the flash drive's icon to open the flash drive window and <br />reveal the contents saved on it. Locate the file you want to download to the <br />flash drive from its current location on your computer and right-click it. Click "Copy."<br /> 4.Right-click an empty spot on the flash drive window and click "Paste" to download the file to the flash drive.<br /> 5.Close the flash drive when you are done. Click the "Safely Remove Hardware" icon on the system tray. A new window will open. Left-click the flash drive and click "Stop." A message will pop-up indicating that it is safe to remove the device from the computer. Disconnect the USB flash drive from the computer (or external hub).<br /> <br />Mac Users<br /> 1.Connect the USB flash drive to an empty USB port on your computer. The computer will automatically recognize the device and display its icon on the desktop.<br /> 2.Double-click the flash drive icon on the desktop to open its window and <br />reveal the contents on it.<br /> 3.Locate the file you want to download to the flash drive from the location <br />where you have it saved on your computer and right-click it. Click "Copy."<br /> 4.Right-click an empty spot on the flash drive window and click "Paste" to download the file to the flash drive. Close the flash drive window when you are done and drag the flash drive icon to the trash can to safely eject it from the computer.
on Feb 01, 2011 | Computers & Internet
Transcend jf v30/64gbmy pen drive is not detected in my computer
Flash drive not detected, it means there is damage to hardware.
Damage to hardware, there are two types
1. Cracked solder.
Solution: Open flash drive casings, heat the tin solder.
Solution: Open flash drive casings, replace the resistor.
Nov 04, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to fix not recognized USB device?
USB device not recognize it means there is damage to hardware.
Possibilities and solutions
1. Cracked solder.
Sep 23, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Extern HDD doesnt do anything when plugged in. I would like to open the case and check whether its a problem with the hdd itself but i cant open the case. I pushed two pins on the bottom part of the case...
Hi
Start by checking if the power cable and power adapter work. Test the cable on another device. The adapter may have a unique or unusual connector that prevent it being testied with other devices but may also have a power light that confirms whether it works or not.
Factory Built Hard Drives are designed to be non user repair friendly. Often, this is achieved with hidden screws.
Check carefully if the end or side panels or strips on the side panels slide or peel away to reveal hidden screws.
I would expect there to be 4 lateral screws to hold the hard drive fast to minimize vibration during use. Check those coloured side strips carefully to see if the lift up, slide up up down or peel off to reveal hidden screws.
The cap end on the top may clip in and might need force (not too much) to unclip.
Look if any warranty or other labels underneath cover hidden screws.
Hope this helps.
Aug 24, 2011 | Buffalo Technology (HD-CE500IU2) 500 GB...
How to install a USB flash drive
Just plug your USB flash drive into the USB port of your computer or other USB-equipped device and drag the files you want to take with you into the folder that appears on your screen. Your files are instantly transferred to your USB flash drive. To transfer the items on your USB flash drive onto another computer, simply plug your USB flash drive into the computer that you want the files transferred to, open the folder that appears on your screen, and drag the desired files onto the computer's desktop.
1.) Insert Flash Drive into the USB Port of your computer.
-Where is my USB port? It is usually found in newer model computers in a hidden compartment on the front of the hard drive and in the back of the hard drive on older computers. The port for laptops is found on the side or back of the computer.
2.) Wait for the hardware to automatically install on your computer.
After the hardware is installed, it is ready to use!
3.) In most cases, an Options Window will automatically open. Select "Open folder to view files" Click "OK."
Jul 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My sandisk cruzer 8gb was stepped on while in my xbox 360 and i wont light up nor come on when i hook it up to my computer how do i fix it
You could crack it open and resolder all the broken connections in it.. but.. your better off buying a new one. their a pita to repair.
Apr 11, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Cant open case
you must remove the tip. it should come off easily. look for it better. it is a protection cap.
Jan 23, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I have no idea how to use this
remove the protection cap. it will reveal the usb connector.
then plug it to your usb port on your pc.
it should appear now a dialog asking if you want to open it. or check My Computer for the new drive. it should be listed there.
Jan 12, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Flash drive got bent while plug into the usb ****
try plugging the flash drive into another pc and see if it works.. or if the usb hub is the problem try another flash drive or usb component on the same plug and see if your computer detects it.
your question was not very clear.. but if your concern is about the flash drive been broken there's probably not much you can do if you're the one to blame for the accident. flash drives are solid state memory that can't be removed for the case and put into another case without risking damaging the chips inside and the data with it... but if you need to try make sure you protect the unit from electrostratic discharge so get another unit just like your's that is not bent, try to open the broken one and see if your memory stick inside the flash drive is still intact and just replace the casing if possible (i never done it myself but I guess it's worth to try if you really need that data)
Oct 02, 2008 | Computers & Internet
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
300 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
