Toyostove Laser 53, Not blowing air
I have had this heater for couple years and we started it up yesterday after not running it for 6 months. It worked great all day yesterday with a lil more than 1/4 full on fuel. It ran most of the night and today but for some reason about an hour ago it stopped blowing air. There is still some fuel in the tank, no error sign has appeared, i tried raising the temp setting, lowering the temp setting. I am not the best handyman but would like some help on diagnosing a problem if there is one. Thank you.
  • 3 Answers
SOURCE: toyostove laser 30 has error code EE22
EE22 is a lock out code that keeps you from continuing to try to start the heater. This code usually pops up as the result of a problem with the fuel supply (i.e. no fuel, fuel sys obstruction, clogged filter, water frozen in line, faulty igniter), but could be more serious. To clear the code the easy way, unplug heater for at least 30 minutes. While you are waiting, check your fuel tank to see if you have fuel. Then check filter to make sure the element is not clogged and that there is no air or water (or ice) in the fuel line. If you find a problem with any of these things, correct it before trying to start heater again.
For the rest email me at
Posted on Nov 21, 2007
  • 625 Answers
SOURCE: Toyostove laser 73 heater with a EE 2 error
replace the flame rod. or it could be the computer board for the flame rod. flame rod detects the presence of a flame.
Posted on Dec 02, 2007
  • 126 Answers
SOURCE: Does not extinguish
If your fuel was yellow it was #2 home heating oil. Toyotomi Laser heater run well on #1. Since yours in giving you a EE10 message you are going to have to open the burner and clean it, the blower and the heat exchanger. The air holes are blocked on the burner and it takes too long to burn the fuel up, EE10.
This is a dirty job but not that difficult. Try and use their dealer locator. You should find a dealer in South Dakota that will be able to get you some gaskets you might need.
Good luck,
Tom Hawkins
Posted on Jan 29, 2009
  • 126 Answers
SOURCE: Toyostove Laser 56 EE 2 error
I have been working on Toyo's for 14 years now. During this time I have never seen a flame rod that was bad except ones that people have broken themselves. The rod is just a piece of heavy wire that is insulated against the pot. It is almost impossible to mess it up. Now, that being said, you can have a problem with the flame rod being dirty or sooted. Since your stove is so new I would look at the fuel system. If it is clean I would go after the burner mat. There have been mats lately on new stoves that have caused them to soot up. When this happens the flame rod gets covered with soot and gives the EE2 message. A new stove that has a burner mat problem would be covered by the warranty. Bad fuel that causes a problem will not be covered. The other thing that is not covered is a stove that has had an iced up the exhaust pipe. A good dealer should be able to help you get the stove going and explain the warranty.
Tom Hawkins
Posted on Feb 13, 2009
SOURCE: Dayton Salamander Heater - Blowing Unburnt Fuel/Smoke Randomly
I have seen this before, you need to replace the nozzle.
Posted on Mar 03, 2011
After having our toyostove laser 30 serviced it started building up a large icicle below the exhaust (this was hardly noticed before). It also generates an ee6 code when it runs on high. It ignites and...
How long is the exhaust pipe on the inside of the house? Is it covered with a cloth sock? The EE 6 is probably from air in the fuel line. I am a little confused by the term "our downstairs heater". Do you have a lifter for the L30?
Dec 02, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Brand new mpi 2200 heater...runs fine with front off....when we put the front back on unit...goes out with code E14-help this is my folks in their 80s 6 hrs from me?
Make sure the circulation fan is running. That is the one you can see on the back. Also look at the black grill. One side is open and one side will be blocked. You want the open side on your left if you are standing in front of the heater looking at it. Also look inside the heater and make sure nothing is blocking the air flow. Let me know what you find.
Oct 15, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
My toyo 73 has started making a loud vibrating noise during startup but gets quiet after running a little while...the fan is not on during start up....
The fan blowing air to the room might not be on but the flue fan would be. I reckon this is where the noise might be from. Fan impellors get coated with dust and this throws the balance out (similar to a car wheel if you loose one of the balance weights). Highly recommend getting it serviced by a good technician. Always good practice every year or so and might fix the problem.
Sep 20, 2010 | Rinnai Toyostove Direct Vent Heater:...
My Laser 30 keeps getting a ee 12 code ans shuts
The screen for the circulating fan has lint on it. Remove it from the back top panel and wipe it off. The lint keeps the air from be able to blow over the stove and it overheats.
Good luck,
Feb 03, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Heater keeps shuting down and displaying EE 6
Check for air leaks in the fuel line. Push the red reset button only once. It's usually a fuel problem. Contamination, air, mixed fuel.
Nov 26, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove Laser 73 EE2
Not having a cleaning in the last couple years may be the problem. Carbon build up in the burner pot and on the flame rod (a chain of carbon) will cause the flame to not be sensed. Then the flame will burn out. A temp solution would be to unplug the stove, then unscrew and jiggle the flame rod to break the chain. When tightening the screws do not over tighten. You could also try hitting the edge of the pot to see if you can knock the carbon loose. You could also have a warped burner ring which would cause problems keeping the stove running.
Nov 03, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyo 73 don't work
Take a look at this...
This site says there is a problem with the blower motor assembly.
Apr 28, 2008 | Rinnai Toyostove Direct Vent Heater:...
Dec 01, 2007 | Rinnai Toyostove Direct Vent Heater:...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
