Question about Honda Tool Aid 36250 Multi Port Fuel Injection Pressure Tester For Domestic And Foreign Vehicles In Molded Plastic Storage Case
When performing injection timing setting what must you do first
Performance drop after first service to my 66 plate CX5 (175 diesel model)- "injector learn update" was run by dealers - could this have modified ECU settings and affect performance?
Hi. It is possible, part of the update could have been to lower fuel injection pressure to help solve other problems and that can affect your engine power.
Nov 07, 2017 | Cars & Trucks
What's The Main Factors Affecting the Quality of Injection Mold
There are many factors that may affect the quality of the plastic products in the process of plastic injection mold, and they can be summed up as follows:1. Plastic MaterialsThe complexity of plastic materials' performance determines the complexity of the injection mold process. The performance of plastic materials varies greatly due to their different varieties, grades, manufacturers or even different batches. Different performance parameters may lead to completely different moldings.2. Injection TemperatureThe melt flows into the cooled cavity and losses its heat due to heat conduction. At the same time, the melt generates heat due to shearing action, and this part of the heat may be more or less than the lost heat caused by heat conduction, which depends on the injection conditions. The viscosity of the melt becomes worse with the increasing of temperature. In this way, the higher the injection temperature is, the worse the melt viscosity becomes and the smaller the required filling pressure needs. Meanwhile, the injection temperature is also limited by the thermal degradation temperature and decomposition temperature.3. Mold TemperatureThe lower the mold temperature is, the faster the heat loses, due to the heat conduction; the lower the melt temperature is, the worse the mobility becomes. This phenomenon is particularly obvious when we adopt a lower injection rate.4. Injection TimeThe influences of injection time on the injection process are in three aspects:(1)When we shorten the injection time, the shear strain rate of the melt will increase, and the injection pressure which are used for filling the cavity should also be increased. (2) When we shorten the injection time, the shear strain rate of the melt will increase and the melt viscosity decreases due to the shear thinning characteristic. The injection pressure should also be decreased in order to fill the cavity.(3)When we shorten the injection time, the shear strain rate in the melt as well as the heat productivity will get higher, and meanwhile, the heat lost due to heat conduction is only a little. Thus, the higher the melt temperature is, the worse the viscosity becomes. And the injection pressure should be decreased so as to fill the cavity. As a result of the above three factors, the curve of the injection pressure which is required to fill the cavity presents in a "U" shape. That is, there exist an injection time when the required injection pressure is minimal.
Plastic Injection Mold Making Services Karo Plastic Injection Molding...
abs-plastic-computer-mouse-injection-molding-abs-ps-hdpe-bnyr3xtgg5rlepabk3q3a4ld-4-0.jpg
Oct 09, 2017 | Cars & Trucks
I have trailblazer 2008 4.2. p0014 and p1174
0014 = "B" Camshaft Position - Timing Over-Advanced or System Performance Bank 1
1174 =
Citroen/Peugeot:
Cam Sensor Fault
Daewoo:
ETS VALVE STUCK - CLOSED 1
Ford:
Cam Sensor Fault
Hyundai:
Electronic Throttle System #1 Close Malfunction
Jaguar:
System Too Lean - Banks 1 and 2 (Suspect HO2S)
Kia:
Lincoln:
Cam Sensor Fault
Mercury:
Cam Sensor Fault
Oldsmobile:
Cam Sensor Fault
Volkswagen/Audi:
Fuel Trim,Bank 1 Different injection times
Volvo:
Aug 19, 2017 | Cars & Trucks
Ford 6.4 diesel no power showing bad part filter, what do i do ?
Ensure nothing is strangling the intake or exhaust and then ensure nothing is limiting the free flow of a good supply of clean air-free fuel.
If nothing is found it will be time to delve into the engine conditions and settings, the performance of the injection system and any electronic controls.
Jul 10, 2016 | 2008 Ford F 250 Super Duty 4WD
Renault laguna 1.9 dci injection fault on dash but car performs fine
probally be a good idea to have a local shop run a fuel system check to eliminate alot of wasted time or money. its well worth the time to have it properly checked by a trained mechanic. alot of engine problems the computer picks up wont be noticed at first and can lead to expensive repairs
Jan 24, 2012 | Renault Laguna Cars & Trucks
I am not particular with this mitsubishi 4m40 engine, i just wanna ask, if how can we maintain and ensure if this is in perfect timing, we could'tn see any timing marks except from its pulley, so...
There is a special tool to put back the injection pump. MH063302 OR IT EQUIVALENT. On crankshaft gear mark 1, on idler gear mark 11 to match them. watch the timing chain marked and idler marking.
Aug 10, 2011 | Mitsubishi Montero Cars & Trucks
Honda cbr1100xx super blackbird 2000. it is using half a tank in about 20-25 miles running rough and coughing abit. had ned sprk plucgs new coil packs new lead reset ecu still remains the same please help.
This motorcycle has EFI Electronic Fuel Injection here is a clip I took from Total Motorcycle.com
· Electronic CPU provides two digital 3-D fuel injection maps for each cylinder and one digital 3-D ignition map for cylinder pairs, creating ideal fuel mixture and spark advance settings for superb response.
· Unique knock-control sensor monitors ignition advance and improves mid-range performance
· Slim-tipped NGK VX spark plugs offer high performance and minimal build-up for consistent operation
· 360-degree exhaust collector, combined with EFI and ignition settings, provides stunning mid-range power
Web site address is
http://www.totalmotorcycle.com/photos/2000models/2000models-Honda-CBR1100XXSuperBlackbird.htm
In short what all this means is you have in my opinion one or more "Map" sensors gone bad which will affect both the injection and the timing.
I say this because the bike starts and runs telling me that the CPU, plugs and coils are all doing there job, just not at the right time.
Once you get this figured out drop the oil in the crankcase and change your oil filter. With that amount of gas going through the engine it will no doubt have contaminated the oil making it thinner and you don't want that.
Apr 27, 2011 | 2000 Honda CBR 1100 XX Super blackbird
My 86 b 2000 is now 25 yrs old and doesn't require emission any more ,can i buy a different carb. and exhaust manifold and if i can whats the best carb and manifold do i use?
I didn't know anybody even used carburetors after 1982. By that time, it was cheaper and easier to meet clean air standards with fuel injection, and if done right, fuel injection provides better performance anyway. You can tweak performance with different manifolds, improved exhaust piping and possibly a turbocharger. There may be a "high-performance" ROM chip for your engine computer; this permits a greater fuel delivery under acceleration conditions.
Note: some smaller engines used a single throttle body injector rather than one for each cylinder. Theoretically you could replace this with a carburetor, but modifying the engine controls to work correctly with it would be a nightmare.
Apr 04, 2011 | 1986 Mazda B-Series
Error codes, oil pressure sensor and engine control moduale
Hello, It should actually be an oil sending unit, and is located on the back of the intake manifold to the left of the distributor. *The P0523 is Oil Pressure Sending Unit Voltage too high *P1693 Generic fault indicating a fault in the bus or PCM/ECM interface *P1682 - I can't find this code Anyways, I will post here all the error codes for future reference. Dodge Cummins Check Engine Error Codes Cycle Key on-off-on-off-on to read codes in odometer display P0002 ECM fuel calibration error P0016 Crankshaft/Camshaft Timing Misalignment/Out-of- Sync P0071 Ambient Temperature Sensor Performance / Rationality P0072 Ambient Temperature Sensor Low P0073 Ambient Temperature Sensor High P0088 Fuel Rail Pressure Too High P0106 Manifold Absolute Pressure Sensor Performance / Rationality P0107 Manifold Absolute Pressure Sensor Low P0108 Manifold Absolute Pressure Sensor High P0111 Intake Air / Charge Temperature Sensor Performance / Rationality P0112 Intake Air / Charge Temperature Sensor Low P0113 Intake Air / Charge Temperature Sensor High P0116 Engine Coolant Temperature Sensor Performance / Rationality P0117 Engine Coolant Temperature Sensor Low P0118 Engine Coolant Temperature Sensor High P0121 Accelerator Position Sensor (APPS) Signal Voltage Too Low P0122 Accelerator Position Sensor (APPS) LowAPPS Voltage Input Too Low P0123 Accelerator Position Sensor (APPS) Signal Voltage Too High P0128 Cooling System Error / Thermostat Rationality P0148 Fuel Delivery Error P0168 Fuel Temp Too High P0169 Water-in-Fuel Detected For Too Long P0192 Fuel Rail Pressure Sensor Low P0193 Fuel Rail Pressure Sensor High P0201 Fuel Injector 1 Circuit P0202 Fuel Injector 2 Circuit P0203 Fuel Injector 3 Circuit P0204 Fuel Injector 4 Circuit P0205 Fuel Injector 5 Circuit P0206 Fuel Injector 6 Circuit P0216 Fuel Injection pump Timing Malfunciton [new injector pump time] P0217 Coolant Temperature Too High P0219 Engine Overspeed P0230 Transfer pump circuit out of range P0234 Turbocharger Overboost Condition P0235 Turbocharger Boost Sensor A Circuit P0236 Turbocharger Boost Pressure Sensor Performance / Rationality P0237 Turbocharger Boost Pressure Sensor Low P0238 Turbocharger Boost Pressure Sensor High P0251 Fuel Injection Pump Mechanical Failure Fuel Valve Feedback Circuit P0252 Injection Pump Fuel Metering Control "A" Range/Performance P0253 Fuel Injection Pump Fuel Valve Open Circuit P0254 Fuel Injection Pump Fuel Valve Current Too High P0300 Multiple Cylinder Misfire P0301 Cylinder 1 Misfire P0302 Cylinder 2 Misfire P0303 Cylinder 3 Misfire P0304 Cylinder 4 Misfire P0305 Cylinder 5 Misfire P0306 Cylinder 6 Misfire P0335 Crankshaft Position Sensor Circuit P0336 Crankshaft Position Sensor Performance P0337 Crankshaft Position Sensor Circuit Low P0338 Crankshaft Position Sensor Circuit High P0340 Camshaft Position Sensor Circuit P0341 Camshaft Position Sensor Performance / Rationality P0370 Timing Reference High Resolution Signal "A" P0380 Intake Air Heater #1 Control circuit P0381 Wait-to-Start Lamp Inoperative P0382 Intake Air Heater #2 Control circuit P0460 Fuel Level Sensor A Circuit P0461 Fuel Level Sensor 1 Performance / Rationality P0462 Fuel Level Sensor 1 Low P0463 Fuel Level Sensor 1 High P0477 Exhaust Pressure Control Relay Low P0478 Exhaust Pressure Control Relay High P0480 Cooling Fan 1 Control Circuit/Open (Low Speed Fan Relay) P0483 Cooling Fan Speed P0500 Vehicle Speed Sensor 1 Circuit, or No Vehicle Speed Reference Signal 1 P0514 Battery Temperature Sensor Performance / Rationality P0516 Battery Temperature Sensor Low P0517 Battery Temperature Sensor High P0521 Oil Pressure Sensor Performance / Rationality P0522 Engine Oil Pressure Sensor/Switch Circuit Low Input P0523 Oil Pressure Sending Unit Voltage too high P0524 Oil Pressure Too Low P0532 A/C Pressure Sensor Low P0533 A/C Pressure Sensor High P0541 Intake Air Heater Relay 1 Low P0542 Intake Air Heater Relay 1 High P0562 Battery Voltage Low P0563 Battery Voltage High P0572 Brake Switch 1 Low P0573 Brake Switch 1 High P0576 Cruise Control Input Circuit Low P0580 Speed Control Multiplexed Switch 1 Low P0581 Speed Control Multiplexed Switch 1 High P0602 Control Module Programming Error/NotProgrammed P0604 Internal Control Module RAM Integrity Failure P0606 Internal ECM Processor P0607 ECU Internal Performance P0622 Generator Field Control Circuit P0628 Fuel Pump Relay Circuit Low, or Fuel Lift Pump Control Circuit Low P0629 Fuel Pump Relay Circuit High, or Fuel Lift Pump Control Circuit High P0630 VIN Not Programmed in PCM P0633 SKIM Key Not Programmed in PCM P0642 Sensor Reference Voltage 1 Circuit Low P0643 Sensor Reference Voltage 1 Circuit High P0646 A/C Clutch Relay Circuit Low P0647 A/C Clutch Relay Circuit High P0652 Sensor Reference Voltage 2 Circuit Low P0653 Sensor Reference Voltage 2 Circuit High P0698 Sensor Reference Voltage 3 Circuit Low P0699 Sensor Reference Voltage 3 Circuit High P0700 Transmission Control System (MIL Request) P0743 Torque Converter Clutch Circuit Electrical P0753 Shift Solenoid "A" Electrical P0837 Four Wheel Drive (4WD) Switch Performance / Rationality P0838 Four Wheel Drive (4WD) Switch Circuit Low P0839 Four Wheel Drive (4WD) Switch Circuit High P1488 Auxiliary 5 volt supply output is too low P1492 Ambient/batt temp sensor volts too high P1493 Ambient/batt temp sensor volts too low P1596 Speed Control Switch always high P1597 Speed Control Switch always low P1652 J1850 Communication Bus P1687 No Cluster BUS Message or No Messages from the Mechanical Instrument Cluster P1688 Internal Fuel Injection Pump Controller Failure P1689 No Communication Between ECM & Injection Pump Module P1690 Fuel injection pump CKP Sensor Does Not Agree With ECM CKP Sensor P1691 Fuel Injection Pump Controller Calibration Failure P1693 Generic fault indicating a fault in the bus or PCM/ECM interface P1757 Governor pressure is above 3 PSI when 0 PSI is requested P1762 Governor Press Sensor Offset Volts Too Low or Too High P1765 Transmission 12 volt supply relay control circuit P2121 Pedal Position Sensor 1 Performance / Rationality P2122 Pedal Position Sensor 1 Low P2123 Pedal Position Sensor 1 High P2127 Pedal Validation Switch 2 Low P2128 Pedal Validation Switch 2 High P2146 Fuel Injector Group 1 Supply Voltage Circuit P2149 Fuel Injector Group 2 Supply Voltage Circuit P2266 Water in Fuel Sensor Circuit Low P2269 Water in Fuel Condition P2502 Charging System Output Voltage P2503 Charging System Output Low P2504 Charging System Output High P2509 ECM/PCM Power Input Signal Intermittent P2607 Intake Air Heater Relay 2 Low P2608 Intake Air Heater Relay 2 High P2609 Intake Air Heater System Performance Hope this will help you. Cheers! Ryan
Jun 11, 2009 | 1999 Dodge Ram
Honda Tool Aid 36250 Multi Port Fuel Injection Pressure Tester For Domestic And Foreign Vehicles In Molded Plastic Storage Case Logo
27 people viewed this question
Top Honda Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Honda Measuring Tool and Sensor Expert? Answer questions, earn points and help others
