Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Ice thickness control - Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
    New Friend:
  • 39 Answers
The ice thicknes control is located on the bottom left. it has a wire going
to it and ha a black rubber bottom. depending on the position it is secured.
will determine the ice thickness. loosen the two screws and push it higher
for smaller cubes and lower for bigger. If you are having problems with it.
There is the possibility it is dirty and sticking.
Posted on Apr 18, 2013
How to adjust the ice thickness for Hoshizaki KMD-410MAH ice machine.
http://www.hoshizaki.com/docs/manuals/KMD-410M_H_serv_LTR.pdf
Try this site for a manual. The ice thickness is controlled by the float switch. Most all Hoshi machines have adjustable floats. It starts the harvest as the water level drops.
Jun 23, 2017 | Hoshizaki Freezers
Hoshizaki M# DCM-270BAH-OS runs for days then freezes up evap coil and stops water inlet to evap.
There is a thermostat probe sat on the front of the evaporator to tell the control board when to harvest. Check it is tight in it's holder. Check the condenser is absolutely clean and filters clear. You can adjust the thickness of the cube. set it on the thinnest setting and see if it harvests before freezing solid.
Jun 15, 2012 | Hoshizaki Freezer Commercial Ice Machines...
P-1 code is flashing on temperature display
P1 is almost always a fault on the sensing (control) probe. Check it's end is not wet or covered in thick ice, and check the connections at the controller. If you can, change the probe connections on the controller temporarily. If P2 then shows it proves the probe is faulty. If P1 still shows, it proves the controller is at fault.
Apr 20, 2012 | True 72 cu. ft. / 2039 liter Commercial...
All cycles work except harvest manitowac ice machine
Ice thickness probe on Manitowoc and float switch may be dirty or stuck if hoshi. Manitowoc sometime the thickness probe can get dirty and a film of algae and not sense ice properly but rare
Oct 06, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki KM-900MAH Ice Maker it sounds like it is making ice and is freezing it but its not dropping ice any solutions?
Do you hear the machine cycling like normal but just not dropping? Could be the hot gas solenoid. If you never hear it trying to drop that could be anything from a dirty condenser to dirty plates to bad ice thickness control. Run some ice machine cleaner through it and blow the condenser out.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 20, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Freezer had been working well for a month or more, then following it being moved possibly as a workman was checking my appliances for leaks, the top of the inside grew thick ice. I defrosted it but within...
Normally that amount of ice denotes a leak in the system, or possibly the thermostat not switching off. If the door does not seal correctly, you will also generate a lot of ice. Something tells me we are looking at a leak.
Oct 23, 2009 | Candy Freezers
I have a 7 year old Kenmore Upright Refrigerator/Freezer on top. I am losing the temp in the fridge part only. The back up the freezer gets a thick layer of ice buildup and when i remove the back panel the...
After you taken the back panel off and see a lot of ice forming on the coil before you use your hairdryer you should locate the timer and turn the center of the timer manually into defrost cycle. If you can see or hear the ice melting then your problem is the timer defective. Change the timer and that is all. But if it doesn't do anything then you will need a little bit more on electrical knowledge to deal with the rest on defrost temperature control and the element itself. Hope this help, God Bless.
Jul 13, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice maker will not eject ice. Sometimes it works, sometimes not.
These units need to have the evaporator coil cleaned routinely. A cleaning solution can be obtain at a refrigeration outlet. Another common problem is the ice thickness is out of adjustment and the ice gets too thick and will not come loose on the defrost cycle, check the thickness.
Nov 27, 2008 | Avanti Freezer Compact Ice Maker - 12 lbs....
Ice machine is not working after it was unpluged
check make sure water is turn on.
bin sensor stat might be open.
lastly on p.c.b board there is a rest button.
make sure ice thickness sensor is descaled and petrolueum
jelly smeared terminals of prons( if it a casade type)
Feb 21, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Ice machine
3 beeps. hoshizaki replacing txv
Dec 21, 2007 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
188 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
0duro
Level 1 Expert
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
