Question about Sewing Machines
How to pull out hand wheel on janome 1022 - Sewing Machines
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
I have a Janome 7933. The hand wheel turns but the needles don't. Looked in the manual but nothing about changing a belt or anything pertaining to this problem. How can I fix it?
Is the hand wheel properly engaged ? A hand wheel often is used when you wind bobbin. When you wind a bobbin, you want to disengage the clutch to prevent the needle going up/down.
On a lot of machines, either the entire hand wheel will pull out, or a smaller middle dial will pull out. You pull it out to wind the bobbin, push it back in to reengage the clutch so the needle goes up/down again.
So giving it a good push IN might solve this.
Oct 27, 2014 | Sewing Machines
Hand wheel not moving
sounds as though the hand wheel at the right end of the machine needs tightening by hand to engage inner workings. Hold the larger wheel with one hand tighten the smaller wheel.
Dec 07, 2013 | Janome Memory Craft 3000
The hand wheel is not moving the needle at all
Check the hand wheel. There should be a smaller wheeel in the center of the hand wheel. Make sure it is locked in(turn center wheel clockwise or could be counter clockwise til snug)
When turning the wheel the needle doesn't move, I am trying to pull the bobbin thread up but when I turn the hand wheel everything moves except the needle
Ya, that's not good. Sounds like a set scew on the shaft has come loose (hopefully), other wise, could be looking at broken gears and that is more extensive. Take it to a service tech, or your Janome dealer
Sewing Tech
Oct 25, 2013 | Janome 1600P-DB Mechanical Sewing Machine
Janome 644D hand wheel stuck machine has never been used
See if you can free it by gently pushing the wheel back and forth ...is this a second hand machine bought as seen ? I am also wondering if a thread might be caught inside and making things stick ...
Mar 16, 2013 | Janome MyLock 634D Mechanical Sewing...
Oiling my Janome Gem Gold
Janome Gem are self lubricating. Silicon is embedded in the gears and releases as it runs. If the machine is put away and not run every so often it will lock up. The hand wheel may have thread caught up around it. The Gems aren't assembled to be dissembled except to change the light bulb.
Jan 16, 2009 | Janome Jem Gold 660 Sewing Machine
Sewing Machines Logo
21 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
