Question about HP Office Equipment & Supplies
New ink cartlidge won't go back into the printer
I replaced the ink cartlidges but they won't go back in the printer
  • 21 Answers
Make sure that the cartridges that you are putting back in match the ones that you took out.Make sure that they are the right part number for what you are replacing.Try putting the old ones back in and see if you are having a problem doing that if not than look real close to the new ones and make sure that the notches are in the right place.Hope that this will help you some..
Posted on Jan 14, 2013
jackboy
  • 2985 Answers
SOURCE: printer will not print
Down load the Epson utility from www.ssclg.com When you have installed the program double left click the task bar icon and select your printer model. New right click the icon and a control panel comes up, this enables you to reset counters and many other service tasks There is also a Forum on this site.
Posted on May 09, 2007
  • 66 Answers
SOURCE: Just put in a new Cartlidge and it says left
try cleaning the contacts of the printer with rubbing alcohol of that doesn't work return the carterage
Posted on Jun 28, 2009
SOURCE: my printer wont print after i put in new ink
My printer will not print after I put in a new cartidges it is a Canon
iP1700.
Posted on Sep 13, 2009
pineworks
  • 4041 Answers
SOURCE: plastic ruhlatec strip broken
Hi thereThis is only some thing you can try it may work.
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
1. Press the On button to turn the printer off.
2. Unplug the power cord from the back of the printer.
3. Remove all the ink cartridges.
4. Wait two minutes.
5. Plug the power cord into the back of the printer.
6. Press the On button to turn the printer on.
7. Install the ink cartridges when prompted.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 12, 2010
kornho
  • 781 Answers
SOURCE: How to replace ink cartlidge
find the the instructions to replace with your cartridge here
hope that helps!
Posted on Apr 17, 2010
How do I fix my ink cartlidge when it is stuck on the right side?
If catridge is in reach of your fingers then pull it back otherwise you have to open the chasis screw of the printer and pull out upper cover and rotate the belt and you can then make printer workable
Jul 23, 2014 | Canon Pixma iP2600 Photo InkJet Printer
When i was taking the black ink cartlidge out the knob broke and now i can not get the cartlidge out
Sorry Dear , But Now You need any technical Asst. B'coz now you have to open the cabinet and than only you can remove the cartridges.
May 07, 2010 | Brother DCP 165C Compact Color Inkjet...
hope that helps!
Apr 17, 2010 | Canon PIXMA MX310 All-In-One Printer
Does blackink cartlidge go on right or left side
yes, the black ink cartridge is on the left side, you can go on to fix it, there is nothing to worry about.
Wish you best of luck.
Apr 05, 2010 | Lexmark X4270 All-In-One InkJet Printer
I changed my ink cartlidge on a 6110 office jet printer but it still keeps saying Remove and check cartlidge
Have you checked that you've removed any tags fully. Sometimes if you remove a tag and there is some left that you haven't spotted they will cause problems.
Failing that, you may have a faulty cartridge. Do you have another cartridge to try?
Feb 02, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My printer wont print after i put in new ink
iP1700.
Sep 13, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Just put in a new Cartlidge and it says left Cartlidge missing. Does not print.
Jun 28, 2009 | Lexmark X6575 All-In-One InkJet Printer
Printer won't print
My printer will not print black ink. The color ink is very light. I replaced a new color cartlidge, cleaned the printheads and tried to callibrate, but the printer could not identify the callibration page from my scanner. Can you help me resolve my problem?
Thanks,
Carol
May 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer will not print
Apr 06, 2007 | Epson Stylus CX1500v Printer
26 people viewed this question
Seeker5211
Seeker5211
