Question about Car Audio & Video
Fitting my old sub from my last car all wired up where it worked in last car but when the sub is on the front speakers just sound like fuzz turned the bass right down but its like they are loseing power maybe?
  • 63 Answers
If you havnt got an amp then yes...
if your powering a sub off a headunit then your going to have problems!
let me know...
Matt
Posted on Jan 23, 2009
Logitech Z506 Speakers
Go into the Control Panel and identify the sound card. Make sure you have the most up to date drivers and also software if there is a software package. Deep into Sound Card Properties there is a setting that asks what the Profile of your Sound Speakers, twin at front, 2 plus 1 Bass, or Surround Sound, Theatre System etc. I think your answer is in there.
Also in Sounds, you can assign sounds to Programs. Or, from the QuickBooks program, assign the sound card.
Nov 29, 2017 | Logitech Audio Players & Recorders
Fader/sub/speaker not working properly
I'm not an expert but often people connect subs to normal speaker wires in back of the radio. You need a dedicated subwoofer line so high frequency sound doesn't go to the subs. Only bass. Sounds like it wasn't wired properly.
Aug 26, 2017 | Pioneer DEH-P6000UB Car CD/ MP3 Player
Radio on but no sound after installing after market subs
to create a spark you must have had power connected somewhere. Did you have your radio turned on when you connected? if yes you may have blown the amp in the radio. If no then you have other issues with wiring and possible damage.
It's one of those instances where I'd need to be there to diagnose it.
Start by double checking the stereo is working, check its wiring is correct try each speaker connection in turn. If the stereo works and all the outputs work then double check the amps wiring and try a normal speaker connected to it. You must get the picture by now, you need to identify the source of the fault. to help you better I'd need a wiring diagram.
Dec 20, 2011 | 2003 Toyota Camry
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
The tuner works fine, all the speakers play including my sub. When I put in a cd, only my sub makes sound, and when I go to the ipod no sound comes out. However When I go to the zone control and select the...
are you using more than one amplifier? it sounds like you may be using the blue wire to turn one amp and and the blue/white to turn the other one on. use the blue/white only. the blue wire is antenna remote and turns off when not in tuner mode.
Jan 09, 2011 | Kenwood DDX516 Car Video Player
I just bought the car last week, and only the right front speaker is working. I thought the stereo was bad and replaced it with a new one only to find the same issue. Is it possible that they may have a...
Every stereo has it's intricacies, once you learn the controls then you can adjust the sound. if you have adjusted the balance to equal, then you may have a broken by door swing ground or positive, sometimes the ohms are split by a common positive connection (front and rear) contained with in the circuit of left or right. This crappy circuit could kill 3 of your 4 speakers, but then with the addition of an after market sub, who knows what kind of monkey business has been committed. Start from scratch in stead of chasing down electrical gremlins. Run new wires to all the speakers, dump the sub. Rebuild what should be there in the first place. Verify manufacturers connections and your interpretation of said, in the harness. Verify that the radio or amp can handle a sub without some goofy mono marriage of rear channels to obtain required ohms for crappy walmart sub Bazooka.
On second thought go to best buy, apply for credit card, and tell them that you want to bump down the road.
Jul 31, 2010 | Car Audio & Video
Channles are going out one by one. Fixable?
Plug one of those speakers into a different channel. Like if you plugged the center or rear channel into one of the front channels and vice versa. This will narrow down if the actual speaker is bad or the channel on the amplifier inside of the sub is going bad. If the speaker is bad, you can see if AL sells replacements, if the amp is bad, a repair shop will probably charge more to fix it than what it's worth. I use a 5.1 Logitech that goes for $69 that's great. It might be time to check into another setup.
Nov 20, 2008 | Altec Lansing ADA995 Speaker
No sound from Sub.... from my Denon AVR-2700, not AVR-3300, Yeah its old!
if the subwoofer is on in the reciecer settings then maybe the amp is not getting the signal or the amp is not amplifying
try unplugging the output of the sub then turn off the reciever for a min. then turn it on wait , then plug the sub in
if that don't work then test the sub output with a stereo that has a audio input
also test the subwoofer with a audio output to it( only a positive and a negitive wire for sub)
Oct 26, 2008 | Denon AVR-3300 Receiver
Wiring Advice
they are to adjust output levels. yes you can hook up the sub to the amp. it is not wise to hook up the front speakers with the sub though. just get a less powered amp to drive the front speakers.
Oct 28, 2007 | Infinity 475A Car Audio Amplifier
Klipsh Promedia 2.1
I was face the same problem 2 year's ago.This problem occur when you move the speaker's here and there.at that time speaker's wire diconnected in inside...please check the whole wire by electricians for where exactly it is disconnected...
Sep 10, 2006 | HP ProMedia Computer Speakers
Car Audio & Video Logo
56 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
