Question about Jabra BT350 Bluetooth Headset Headset
Using bluetooth. what is intermittant ringing? time to recharge
Is it
  • 25 Answers
Hello. i belive its a pause in between rings and when answared it stops, go into your tools on phone and pull up rings and you should find inermitant rings, than shut that turkey off. ( dont look for turkey, it aint there) i had same problem once took me most of the night to figure it out. good luck.
Posted on Jan 25, 2009
Big blue speaker repair
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
If the speaker is under warranty get it replaced.
Taking the speaker apart to replace the battery will compromise or even destroy the acoustic properties of the speakers. Big Blue Live Wireless Bluetooth Speaker
Mar 09, 2015 | Brookstone Big Blue Studio Wireless...
Bluetooth ear phone
please say the name of the manufacturer
Feb 07, 2008 | Radio Communications
I have a G'zOne S series phone. In my line of work the phone is great. But, I've tried 3 different bluetooth devises and a couple of verizon ear pieces and I have the same problem with each one, LOW...
The best bluetooth headset for ur phone will be BLUEANT X3 MICRO BLUETOOTH HEADSET.
Here are the PRODUCT FEATURES:
  • High quality, Full duplex audio makes a natural conversation on your cell phone or computer!
  • All these recharging options are provided in the box: USB charging cable for computer, AC travel charger for 110-120 volt AC, and a 12 volt DC car charging cord (SAM460CLA).
  • Use with VoIP programs, and handle calls between both your cell phone and VoIP if Bluetooth enabled!
  • Supports Bluetooth Profiles of Hands-free, Headset.
  • LED lights can be switched off for night time driving.
  • Tiny Ergonomic Design provides a Very small size of only 52 mm x 26 mm x 28mm, and weighs only 13 grams!.
  • Rechargeable Lithium Ion Battery lasts for more than 7 hours talk time, or 180 hours of Standby time.
  • Stores Bluetooth pairing information for up to 3 different Bluetooth devices, one at a time.
  • Bluetooth Version 1.2 for Fast connectivity & security, and Bluetooth Class 2 for range up to 30 feet.
Goodluck,
Don't forget to rate me as fixya..
Jan 12, 2008 | Cell Phones
Blue tooth phone conversations are not heard well from my truck. Poor quality speaker? Poor location? I don't make calls from my truck cuz they can't hear me well. What's up with this?
there are alot of variables for bluetooth. Type of phone, phone service and provider etc... what type of phone are you using here is just one of the latest post from gm.
#PIC5504: Intermittent Bluetooth Issues With Apple IPhone 4 - (Jul 13, 2011)
999999995.gif Subject: Intermittent Bluetooth Issues With Apple iPhone 4 Models: 2008-2011 All GM Passenger Car and Light Duty Trucks with RPO (UPF or UWE)
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:A customer may report of intermittent Bluetooth issues with their Apple iPhone 4.
Recommendation/Instructions:An issue with intermittent Bluetooth disconnects between the iPhone 4 and some GM vehicles has been identified. You may experience no audio in the vehicle for incoming and outgoing calls. When this occurs the Bluetooth system will say "Unable to place call on your Bluetooth phone". GM and Apple engineering groups are currently working on a resolution. The PI and GM Bluetooth website will be updated as soon as more information becomes available.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Jul 29, 2011 | 2009 GMC Sierra 2500HD
2004 Jaguar XJ8 with 60,000 miles. A/C was working intermittently, so took to dealer to fix. They found a "leaky" o-ring, replaced it, and recharged the system. No other problems found. Problem still...
sounds like you have a blockage in the system the fans come in to cool the condensor, have you had the system flushed and the receiver/drier replaced? or there maybe moisture in the system which will create ice in the system and cause a restriction or the ext. temp sensor is faulty
Jun 08, 2017 | 2005 Jaguar XJ-Series
Audio on radio and bluetooth dissappears.
The bluetooth and radio are located in the radio itself. I would suggest having the radio replaced at you local toyota dealership
Oct 19, 2009 | 2009 Toyota Camry
Aerobird 3 power cutting out intermittently
the substance in the rechargable batterise is exhausted afet a long time of recharging.
time for new Fresh rechargable battereies.
Apr 27, 2009 | Hobby Zone Aerobird 3
Ring 3 times then goes to Voicemail
Does the phone actually ring 3 times. I was having the same problem I was informed that it was not even going to my phone. When I had this same problem T_Mobile could not fix the problem using the 3 g network. If you shut off the 3g feature your problem will go away
Jan 12, 2009 | HTC G1
Ring tone
This information is from the Motorola Customer Help web pages.
To connect your phone via USB to computer and access your phone's memory card:
On your phone:
  1. Press the Center Select Key
  2. Scroll to and Select Settings
  3. Scroll to and Select Connection
  4. Scroll to and Select USB Settings
  5. Scroll to and Select Default Connection
  6. Scroll to and Select Memory Card
    This directs the USB connection to your memory card. Attach the Motorola Original USB cable to the accessory port on your phone and to an available USB port on your computer.
question.gif How do I use my own ring tones on my phone?
space.gif space.gif answer.gif To put ring tones on your phone using Motorola Phone Tools 4.36c and higher:
  1. Start Motorola Phone Tools.
  2. Choose your phone's profile or create a new profile.
  3. Click OK to wait for a picture of your phone to appear or for your phone to be setup for the first time.
  4. Once the image of your phone appears in the lower right of your computer screen select Multimedia Studio.
  5. On the screen that pops up select Melody Studio.
  6. Select a tab at the top of the screen to find a source for a ring tone. (Samples, My Melodies, My PC, My CD, My Phone).
  7. Select an audio phone you wish to transfer or edit.
  8. Edit the file to your taste or simply choose Transfer to phone.
  9. The file will be put in your ringtone folder.
To transfer music to your phone via Bluetooth(The computer must have a Bluetooth Profile that supports OBEX File Transfer ):
Note: The steps you may need to use to transfer music via Bluetooth may differ from the steps used below. A PC and a Motorola PC850 Bluetooth Adapter were used in the steps seen below.
  1. On your computer
    1. Go to My Bluetooth Places
    2. On your phone
      1. Push Menu
      2. Scroll to and Select Bluetooth
      3. Scroll to and Select Setup
      4. Turn Bluetooth Power On
      5. Push Back (right softkey)
      6. Scroll to and Select Find Me
      7. Press Back several times to return to the home screen
    3. Double click Find Bluetooth Devices
    4. Let your computer search and find your device
    5. Double Click on Motorola Phone (Phone's default name is "Motorola Phone" unless you have renamed it in Bluetooth>Setup>Name
    6. Double Click on OBEX File Transfer on Motorola Phone
    7. Computer will be prompted to enter a Passkey
    8. Enter 0000 on your computer and press OK
    9. Phone will ask if you want to Bond with your computer. Select Yes or No
    10. Phone will then prompt you to enter the 0000 Passkey then press OK
    11. Phone will then prompt to Grant or Deny OBEX File Transfer
    12. Double click on audio Folder
    13. Phone will then prompt to Grant or Deny OBEX File Transfer
    14. Computer will now display a conversations and voicerecords folder. Copy and paste or Drag and Drop your m4a (AAC) or MP3 ring tones to the audio folder and NOT into the conversations or voicerecords Folders.
    15. Phone will then prompt to Grant or Deny OBEX File Transfer to complete the transfer
Note: By putting ring tones on your phone using Bluetooth or Motorola phone tools, you may not be able to remove the ringtone from your phone. Motorola is aware of this and in the future removing the user added ringtones
Regards,
Worldvet
Jun 10, 2008 | Motorola Mobility RAZR V3
Motorola h500
Delete it from your Razr, turn off the bluetooth and recharge it to full. Try pairing it again. Make sure you enter the passkey correctly. Check the manual for the bluetooth if you dont know what it is. It is usually 0000.
Dec 30, 2007 | Motorola Mobility Bluetooth Hands Free...
Jabra BT350 Bluetooth Headset Headset Logo
52 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
