Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Slow Ice maker
I have a top freezer Fridgidaire and the ice maker is extremely slow at making any ice. Any Ideas of what I can do to fix this? I have to use the Old tray system to have Ice.
    President:
  • 1,214 Answers
How much ice does it make per day?
There are several things that affect ice making capability, such as -
1) How often the doors are opened
2) Leaky door gaskets
3) Bad ice mold thermostat
4) Light in refrigerator does not go off when doors are closed (easy to test).
Posted on Jan 23, 2009
LSC27926ST REFRIG/freezer. Ice maker is leaking water that freezes on items in freezer, ice is messed up and had to unclog ice maker. Still a logjam of ice around ice maker. has been churning out ice...
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn't take much to eventually block the fill tube.
Sep 10, 2011 | LG LFX25960ST Stainless Steel French Door...
Ice Maker is making ice but at an extremely slow pace. The Ice Maker has been in the "On" position for approximately 48 hours and the pan is only 1/4 full.
HI,CHECK FOR UNIT TEMP FACTORY SETTING,CHECK FOR CLEAND CONDENSER COILS ,GOOD WATER FILTER, AND FOR A GOOD WATER PRESSURE ...
Jul 05, 2011 | Frigidaire IM501 FRIGIDAIRE IM501 ICE...
Icemaker has always been slow. It produces ice, just a couple or 3 times a day. We have to keep our old fridge running just to get enough ice... Cubes are full size, freezer is 0 degrees, not much...
The main reason behind an icemaker to make ice slow is the freezer temperature. It needs to be below 10 degrees. Also check the water inlet valve. Water is controlled by a timer and if its obstructed or slow filling, it will not make ice. You could also have a bad motor, defrost heater, or sensor. If these items fail, it usually won't make any ice. Check to be sure the electric plug from the ice maker is plugged in and check the water flow. However if it is filling up with water or if it just has a small amount in the cube maker. If it's making some ice, it's probably not a defrost problem. Check the voltage to the fill valve. Also replace the freezer's water filter, as clogged filters block water flow. Set the ice maker arm to "Off," and then twist the hanging filter cup counterclockwise to remove it. Rinse the cup under running water and discard the old filter cartridge inside. Slide a new filter cartridge into the cup and reinstall the cup assembly in the freezer.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 27, 2011 | Kitchen Ranges
Ice maker is extremely slow. it will take days to
change the cooling contro indicator to freezer max ..... that will increase the speed of cooling in ur freezer ....
Jan 03, 2010 | Kenmore 52632 / 52634 / 52639 Side by Side...
The icemaker in my freezer has a slow drip. The water then freezes in the ice bin. Why is it dripping, and how can I fix it?
Good day,
The most common reason is the ice maker is overfilling because the water valve in the bottom rear of the refrigerator leaks on the off cycle, and needs replaced.
Make sure the machine is level and the ice maker is mounted in the freezer properly to keep it level.
Also, make sure the fill pipe going into the back of the ice maker is properly positioned.
The Ice maker body could have failed but is very rare.
Nov 08, 2009 | Kenmore Refrigerators
Six hours to make eight cubes???
when you first hook up an icemaker it sometimes takes a couple of days for it get up to speed. there may not be a problem give it some time.
Sep 30, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
We have a GE Profile refrig, circa 1995. The ice
If you are sure it is caused by the ice maker or if it is not it can be fixed. The only way an ice maker would leak like that is if ice is blocking the inlet tube and when the water comes on the water is spewed in a different direction than the ice maker. Most times this is caused by a slow leak in the water control valve for the ice maker side at the rear of the refrigerator. You can stop the problem by melting the ice in the fill tube with a hair dryer and keeping an eye on it until you see ice beginning to build up there again. That would indicate a slow leak in the water control valve that is not closing all the way when off. The other reason for large pools of ice in the freezer is a frozen over defrost condensate drain behind the cover in the rear of the freezer and would require you to unplug power and remove the rear panel. I will try to get some photos and a link shortly that covers that problem a lot more in just a few minutes. Sea Breeze
Aug 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
ICE MAKER.
ADJUSTING WATER FLOW WILL CHANGE THE ICE MAKING TIME UP. TO DO THIS PULL OFF COVER ON FRONT OF ICE MAKER AND ADJUST SCREW ACCORDENLING. HOPE THIS HELPS
Sep 25, 2008 | Frigidaire 20.6 cu. ft. Top Freezer...
Water leak
IF THE ICE MAKER AND DISPENSER ARE BOTH OFF, THE WATER VALVE IS THE PROBLEM. THERE SHOULD ONLY BE WATER RUNNING WHEN THE ICE MAKER CALLS FOR IT, AND THAT SHOULD ONLY BE ABOUT 7 SECONDS WORTH,
(4 OUNCES).
THE ONLY THING THAT PUZZLES ME ABOUT YOUR DESCRIPTION IS THAT YOU SAY ICE FREEZES OVER THE COMPRESSOR. THE COMPRESSOR IS THE HOT ROUND OBJECT LOCATED UNDER THE REFRIGERATOR OUTSIDE THE COOLING COMPARTMNTS. FREEZING ONLY TAKES PLACE IN THE FREEZER COMPARTMENT. ARE YOU TALKING ABOUT THE EVAPORATOR COILS? IF THERE IS WATER THERE, THE ICE MAKER COULD BE STUCK IN THE FILL MODE AND THE BACK OF THE ICE MAKER FROZEN SO THE WATER CAN'T REACH THE MOLD OF THE ICE MAKER.
CHECK THE FRONT OF THE ICE MAKER BEHIND THE COVER FOR A BROKEN GEAR. IF IT HAS WRITING ON IT THAT SAYS DO NOT ROTATE MANUALLY, YOU NEED TO REPLACE THE ENTIRE MODULE ON THE FRONT OF THE ICE MAKER.
Apr 08, 2008 | Frigidaire GLRS267ZA Side by Side...
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
277 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
