Question about Nikon Coolpix L105 12.1 Mp Digital Camera - Black
Nikon coolpix l105 lens stuck
The lens gets stuck and the camera goes black after taking a picture
SOURCE: how can i fix a stuck lens on a Nikon COOLPIX L11?
It worked. I just gently nudgged the extended(stuck) lens to one side by hand. (the side which had the gap.) There was a click sound and the lense housing fell back in place. Sweitched off and switched on again and the lense started working fine. thanks.
Posted on Jan 26, 2008
SGNath
  • 170 Answers
SOURCE: Camera will not take picture with nikkor 105mm lens
Check if the lens is properly mounted. If still you get the error message, clean the electrical contacts between the lens and the camera using an eraser. Take care not to let any dust fall into the body. Attach the lens and try.
Posted on Feb 10, 2009
Rammsteins
  • 300 Answers
SOURCE: my 9 month old camera (Nikon s210 coolpix 8.0mp) that I
Hi!
It sounds like the lens focus is stuck. If you don't have experience in camera repairs, you should give it for a repair to your local Nikon service center or other camera service center.
Tom
Posted on Jul 31, 2009
pixeldawg
  • 71 Answers
SOURCE: nikkor 18-55mm lens on Nikon d50 locks up in autofocus mode.
The "err" is generally when you have the aperture set to something other than "F22" with the aperture lock on. As far as the lens, you should take a pencil and use the eraser end on the electrical contacts both on the lens and camera and ensure that they are clean. Often times, cameras will respond, but not fully, if some of the contacts have build-up on them. If this still doesn't work, take the lens to a camera shop or ask a friend to borrow their nikon and try using the lens on a different camera to see if it is indeed the lens or the camera. Doing this will help you determine which needs to go to the repair shop.
Posted on Oct 01, 2009
Testimonial: "Thanks for your help! I'm taking it in today to get it cleaned and checked out."
  • 149 Answers
SOURCE: NIKON D80; Nikon 18- 135 G LENS, Camera doesn not recognise lens
try to clean the contact of the lens & camera
Posted on Oct 16, 2009
I need to get a new shutter button for my nikon coolpix L105 and i cant find any anywhere
Did you say you searched all over well Some things you just have to get from nikon sorry
Jan 30, 2014 | Nikon Coolpix L105 12.1mp 15x Optical Zoom...
After inserting memory card in Nikon coolpix L105 the error 'this card cannot be used' has occured. what is the solution?
The L105 works with SD cards. Make sure you're not using an SDHC card. You need to use SD cards, 2GB and smaller.
Oct 29, 2012 | Nikon Coolpix L105 12.1 Mp 720hd Video 15x...
Nikon Coolpix L105 Camera won't read a memory card
Your camers is set that way change your settings go to menu
May 25, 2012 | Nikon Coolpix L105 12.1mp 15x Optical Zoom...
The camera takes pictures with flash, but then as you hit display the screen stays black and the picture was never taken. How can this get fixed?
Do you mean that no picture file was actually recorded, or do you really mean that the resulting picture file recorded a black picture?
If you mean that you're camera is taking black pictures, this sounds like a stuck shutter. A stuck shutter is a common failure mode for digital cameras, and it seems to be especially so for any of the Canon A6XX series (although these cameras are awesome otherwise). The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 28, 2010 | Canon PowerShot A620 Digital Camera
The viewer is "black". The camera takes pictures, goes through th motion, sound, but the picture is black, no image
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 12, 2010 | Canon PowerShot SD1000 Digital Camera
Camera opens normally, only takes black pictures
May 09, 2010 | Canon PowerShot A530 Digital Camera
Nikon coolpix s600 black screen or lines after taking a picture
Black screen after clicking a picture means aperture motor not working or lens flexible circuit damaged, it has to be checked by expert technician & is replaceable part.
Sep 30, 2017 | Nikon Coolpix S600 Digital Camera
Nikon Coolpix L105 12.1 Mp Digital Camera - Black Logo
73 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
