Question about PNY 4GB USB 2.0 Flash Drive - Grey/Black
Cant open case
How do I open up the flash drive unit from its case? Is tthis necessary to get to the USB plug?
  • raymond innes Jan 26, 2009
    OK from Ray..but did not mention two locking screws to turn before pulling off tip.
Slide the base from the top by holding the edges and pulling apart, then turn the base to expose the plug. Tricky when there are no instructions, but a good system when you know how it works.
Posted on Jul 26, 2009
  • 86 Answers
You must remove the tip. it should come off easily. look for it better. it is a protection cap.
Posted on Jan 26, 2009
Need to put system recovery disc's 2 disc set on flash since dvd drive has quit on me.
http://www.computerhope.com/issues/ch001366.htm
How to create a bootable Windows USB drive. A common use of a bootable USB flash drive is to use it to boot into Windows. Booting from removable media such as a USB drive allows you to perform diagnostics on a computer that is having trouble booting from the hard drive. You can also use the flash drive to install Windows, instead of using the Windows installation CD.
This guide will outline making a bootable USB flash drive with Windows XP, Vista, or 7. Before we begin, it is important to note that the computer you want to use your bootable USB drive must be able to use a USB drive as a boot device. Most computers built since Windows Vista was released are capable of booting to a USB device. Prior to the Windows Vista time frame, it is hit or miss with motherboards.
To determine if a computer is capable of booting to a USB device, access the computer's BIOS and check the bootable device list. If a USB device is listed, set the USB drive to be the first boot device. If you do not see a USB device in the list of bootable devices, your BIOS is not capable of booting to a USB device.
Note: You may need to have your USB flash drive plugged in when you access the BIOS).
Windows Vista and Windows 7 users To make a bootable USB drive for Windows Vista or Windows 7, you need to have Windows Vista or 7 installed on your computer. It is recommended that you have a flash drive of at least 4 GB in size, to store all the necessary files.
Tip: Before you start, plug in the USB drive and backup any files you have stored on the USB drive. The drive will be formatted during this process and all files on it will be deleted.
Note: You need to have a Windows Vista or Windows 7 DVD for these instructions to be successful.
1. Open an elevated Windows command line window by clicking Start, typing in cmd in the search text field, then pressing CTRL + Shift + Enter on your keyboard (at the same time). You can also access this by navigating to Start, All Programs, Accessories, right-click with your mouse on the Command Prompt menu item and select Run as Administrator.
2. At the command prompt, type cd c:\windows\system32 to change the directory to the Windows system32 directory. Ensure your USB drive is plugged in, type DISKPART, then press Enter. Type LIST DISK and press Enter.
3. You will see a listing of the disk drives connected to your computer. Find the disk number of your USB drive and type SELECT DISK [USB disk #], where "[USB disk #]" is the disk # for your USB drive. It should now state that your USB drive is the selected disk. If you're not sure what disk is the USB disk, eject the USB drive, perform step number 2 again, connect the USB drive again, and compare the results. Usually the USB drive will be the last drive.
4. Type in the following commands, one by one, pressing Enter after each command.
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(may take a couple minutes, depending on the USB drive size)
ASSIGN
EXIT
Keep the command prompt window open, but you can minimize it for a little bit.
5. You will now need your Windows Vista or 7 Installation DVD. Put the DVD in your computer's DVD drive. Open up My Computer and note which drive letter is assigned to your DVD Drive and your USB flash drive.
6. Go back to the command prompt window and type in D: CD BOOT (substitute your DVD drive letter for "D:", if necessary) and press Enter. Type CD BOOT again and press Enter. Lastly, type BOOTSECT.EXE /NT60 H: (substitute your USB flash drive letter for "H:", if necessary) and press Enter.
7. The last step is to copy the entire contents of the Windows DVD to your USB flash drive. To do this, in the My Computer window (opened in step 5 above), right-click on the DVD drive and select Open to view the contents of the DVD. Copy all the files and folders on the DVD to the USB flash drive.
Your USB flash drive is now set up to be a bootable USB drive for Windows Vista or 7.
How to or can boot from CD or DVD
Good luck.
Jan 12, 2016 | Compaq Presario CQ60-220US PC Laptop
Transcend jf v30/64gbmy pen drive is not detected in my computer
Flash drive not detected, it means there is damage to hardware.
Damage to hardware, there are two types
1. Cracked solder.
Solution: Open flash drive casings, heat the tin solder.
2. Resistor (R) broken
Solution: Open flash drive casings, replace the resistor.
Hopefully this information helps
Nov 04, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to fix not recognized USB device?
USB device not recognize it means there is damage to hardware.
Possibilities and solutions
1. Cracked solder.
Sep 23, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to install a USB flash drive
Just plug your USB flash drive into the USB port of your computer or other USB-equipped device and drag the files you want to take with you into the folder that appears on your screen. Your files are instantly transferred to your USB flash drive. To transfer the items on your USB flash drive onto another computer, simply plug your USB flash drive into the computer that you want the files transferred to, open the folder that appears on your screen, and drag the desired files onto the computer's desktop.
1.) Insert Flash Drive into the USB Port of your computer.
-Where is my USB port? It is usually found in newer model computers in a hidden compartment on the front of the hard drive and in the back of the hard drive on older computers. The port for laptops is found on the side or back of the computer.
2.) Wait for the hardware to automatically install on your computer.
After the hardware is installed, it is ready to use!
3.) In most cases, an Options Window will automatically open. Select "Open folder to view files" Click "OK."
Jul 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Drive wil not allow coping with 1.8 GB open
Not sure why it won't copy anything to the drive, but you can try formatting it and then copying to it once the format is finished.
Plug the device in, then open "My Computer" and right click on the drive letter that is assigned to the flash drive, then click "format" and leave all the options alone.
A quick format should be all that's necessary. If this doesn't work, I'll have to let another Expert take over.
Dec 31, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
My 3660 does not recognise my DVD/CD write/rewrite theough the connections are all fine. Same too with my new Sony Walkman when plugged into any of my USB drives
Do any devices work in any USB ports on that laptop (Flash drive, mouse/wireless mouse, USB keyboard)?
USB support may be disabled in the BIOS.
Boot into the BIOS and check the built-ins and enable, if necessary.
(just in case, disable and then enable)
USB controller driver messed up:
Right-click [My Computer]
[Manage]
[Device Manager]
Look for any "marked" errors on devices
open the +USB Serial Bus Controllers
Pick a faulty one and "disable" then "enable" it.
If it still fails, then "Uninstall" it (Windows will find it and re-install it automatically.
That should do it.
Sep 22, 2009 | Acer Computers & Internet
Ethernet
If you have access to another computer with internet (friend, relative, neighbor, etc...), get a USB flash drive or thumb drive (2 or 4 GB can be found for around $10 - $15), then follow these steps:
1. locate your express service tag code, usually found on a sticker somewhere on the computer's case, and write it down.
2. go to Dell's support website: http://support.dell.com
3. Click "Drivers and Downloads"
4. Choose "By Service Tag"
5. Enter your Express Service Tag and click GO
6. Scroll down to "Network"
7. Download the "Recommended" driver and save it to the USB flash drive.
Take the USB flash drive back to your computer, open it in Windows Explorer, then double click the downloaded file and follow the installation directions from there.
You could also do the same with a CD-R if you don't have a thumb drive, but it's a bit more involved.
Feb 01, 2009 | Dell Optiplex GX60 PC Desktop
Opening the flash drive case
remove the protective cap on one of the sides.
Jan 23, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Flash drive got bent while plug into the usb ****
try plugging the flash drive into another pc and see if it works.. or if the usb hub is the problem try another flash drive or usb component on the same plug and see if your computer detects it.
your question was not very clear.. but if your concern is about the flash drive been broken there's probably not much you can do if you're the one to blame for the accident. flash drives are solid state memory that can't be removed for the case and put into another case without risking damaging the chips inside and the data with it... but if you need to try make sure you protect the unit from electrostratic discharge so get another unit just like your's that is not bent, try to open the broken one and see if your memory stick inside the flash drive is still intact and just replace the casing if possible (i never done it myself but I guess it's worth to try if you really need that data)
Oct 02, 2008 | Computers & Internet
Computer does not recondnize unit.
what new unit are you plugging in
Jan 12, 2008 | Electronics - Others
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
168 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
