Question about LG NB2020 Sound Bar
Sound from LG 55LS4500 TV and NB2020A sound bar are not in sync
bshldn
  • 736 Answers
SOURCE: I have a Samsung hw c-451 sound bar.I have it
Dish doesn't appear to have a code for Samsung receivers but try the Sharp codes listed. Here's a link
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml#amp
Same thing for the LG remote
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3252
I recommend connecting your sound bar to your dish receiver as well as to the television. Play around with optical and RCA to see which one you prefer the sound of. The television isn't always the best center channel so you might find that you like this set up better with the dish receiver connected directly to the sound bar. Then you can shut of the television speakers. Some people turn the television speakers back on and leave the sound bar off for early morning breakfast news viewing. Not being sure which dish receiver you're using you might have to indicate to it how you wish to output your audio, or all outputs might be outputting at the same time all of the time.
Posted on Jan 27, 2011
  • 11800 Answers
SOURCE: trying to hook up an
If you want to hear the sound from all the sources (including the Playstation) thru it you will need to connect all of them to the receiver and the sound bar to the Line-Out or headphones socket of the receiver.
You will need a cable that has an 3.5mm jack at one end (for the soundbar) and 2 RCA connector at the other end (if you use the Line-Out connectors) or another 3.5mm jack and an adaptor to the large one if that's what it has (if you use the headphone socket).
Posted on Sep 06, 2011
SD Tech
  • 14553 Answers
SOURCE: My ilive itp180b sound bar won't play sound from my lg plasma tv
Sound issues and answersa short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD.
Posted on Apr 02, 2012
willbanlaki
SOURCE: tv resolution issue
check zoom on either your tv remote or direct tv remote. someone has hit the zoom button . Its can be called zoom,picture, picture size. You want to get it back to normal. this can be done by hitting one of those buttons repeatedly until you see normal come up.
Posted on Apr 07, 2012
gopakumarg43
  • 74459 Answers
SOURCE: How to connect pacer fireplace tv stand with sound bar to my LG tv?
Refer the user manual for both; to get more wiring details. Gopakumar Gopalan Google
Posted on May 13, 2015
LG 55LS4500 55 in. TV has sound through speakers, no audio except a hum from headphones and the optical digital to analog output fiber lights up but no sound output What board is bad?
Hi Louis,
The audio circuitry is located in the main board. Try unplugging the TV for a while and try again if the audio comes back.
I would suggest to check all your settings in the audio section first and if everything seems OK then the main board should be replaced.
Feb 26, 2017 | LG 55LS4500 55 Inch 1080p LED LCD HDTV -...
LG 55LS4500, after turning on the TV the picture goes out after a while but the sound stays on. Wait a few seconds and turn it back on and the picture will come on again but after a while goes out.
BUENAS SERIA BUENO Q REVISARA EL CIRCUITO DE ILUMINACI?N DELA PANTALLA DE TU TV EMPIEZA POR AH? PARECE SER UN PROBLEMA DE SOBRECALENTAMIENTO SI TU TV ES PLASMA YO TU IRIA A POR LOS IC QUE ALIMENTAN LA PANTALLA DE NO SER ASI POR Q EL TV ES DE LED O LCD REVISARIA LAN LAMPARAS Y EL INVERTER EN ESE ORDEN ESPERO Q DES MAS DETALLES PARA AYUDARTE MAS SUERTE
Dec 11, 2016 | LG 55LS4500 55 in. TV
LED LG 55LS4500 multi color vertical lines no picture but do have sound, what causes this?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 23, 2016 | LG 55LS4500 55 in. TV
Need instructions lg sound bar remote control akb74815321
  1. Turn on your Sound Bar.
  2. Select LG TV function by using FUNC on the remote control or F on the unit until the correct function is selected.
  3. Set up LG Sound Sync (Wireless) on the TV. Refer to your TV's instruction manual for detailed steps
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 11, 2016 | LG Televison & Video
I have a LG led tv 55LS4500. Tv is showing a black screen, but has sound and the backlighting is good. I have replaced the tcon board with no results. What should my next course of action be?
Sounds like panel fault. Contact the authorized service center for LG. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 14, 2015 | LG Televison & Video
Tv will not turn on
If you have checked power supply bar and the TV power plug are both working in normal order, then you need to send in the technician for fixing the TV, may be the fuse was burnt out etc.
Jul 23, 2014 | LG 55LS4500 55 in. TV
Lg soundbar nb2020a setup
If you are currently using your sound system shown for your television sound then you need to use that with you sound bar plugged into it. You can hook it directly to your TV if you have an audio out but your tv has to produce enough output to run the sound bar. If your tv does have an audio out then there is a good chance you need to make those jacks active in the sound set up menu for external speakers. Some sound bars are powered and will require being plugged in as well.
Apr 27, 2013 | Audio Players & Recorders
LG NB2020 Sound Bar Logo
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
