What size load capacity is ge model wdsr2080d5ww
2 Suggested Answers
Jimster
  • 240 Answers
SOURCE: WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Posted on Feb 15, 2008
How many cubic feet are in GE electric dryer model DHDSR46EE1WW?
Features
  • 7.0 cu. ft. super capacity
    Handles large-size items and family-size loads
  • Auto Dry
    Uses thermostats to monitor air temperature and reduce fabric wear
  • Dura Drum interior
    Provides long-lasting dependability
  • Four heat selections
    Provide the right temperature for the right drying results
  • Interior dryer light
    Lets you see everything inside for easy loading and unloading
Sep 13, 2015 | GE Dryers
What is the capacity of the GE Profile WPRE6100G?
• King-size, 3.5-cu. ft. stainless steel basket makes room for more items, which
means less time doing laundry
Oct 25, 2014 | GE Profile WPRE6100G Top Load Washer
Model wdsr2080d5ww
this model does not have a accsesibale lint filter
Jan 27, 2014 | GE WWSE5200B Top Load Washer
GE WDSR2080D5WW will not spin.
One of them support rods is probably broken
Apr 01, 2010 | GE WDSR2080D Top Load Washer
How do you take the cover off of a GE model wdsr2080d5ww
standard way is to remove all screws around the top cover, including the ones by the lint filter, then prying from the front with a little force as most units have spring clips at the front, and hinge clips at the back
Jun 14, 2009 | GE WWSE5200B Top Load Washer
GE washer Model WDSR2080D5WW Transmission shaft wobbles
If you can't loosen the nut, you can break it with a hammer and a metal chisel. Tub nut is cheap. Grease on clothes = new transmission time.
By the way, after you remove the inner tub,.... you have to take the entire outer tub assembly out of the washer, flip it upside down, remove the yoke that holds the motor onto the outer tub, and pull the transmission out through the bottom of the outer tub.
Jun 11, 2009 | GE WDSR2080D Top Load Washer
GE Mod WDSR2080D5WW won't drain
The last one I repaired had a 2 quarters in the pump.
Remove the hoses and inspect the pump for coinage.
Feb 03, 2009 | GE WDSR2080D Top Load Washer
GE WDSR2080D5WW Top Load Washer
sounds like the agitator is bad not hard to replace look up on internet agitator replacement for that model
Sep 10, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
