Question about Jet 1HD Power Electric Wheelchair
I put new batteries in my jet 1 power wheel chair , and it charge up one time and wouldnt charge up no more. the fuse is good. what is the problem.
  • kasco Jan 31, 2009
    can not seem to power on, no lights on control. Fuses check good
  • 32 Answers
Common problem on old jet chairs is bad batt. chargers
Posted on Apr 03, 2009
New batteries new battery harness still 3 red bars and two yellow bars flashing what else could it be
[PDF]Pride Jet 2 Hd Owner's Manual - Scootaround
www.scootaround.com/.../manuals/pridemobility/Pride%20Jet%202%20...
The symbols below are used throughout this owner's manual and on the power chair to identify ... Jet 2 HD www.pridemobility.com. 3. TABLE OF CONTENTS.
Sep 28, 2015 | Jet 2 HD for 350 lbs, Power Chair,...
One wheel on my Pride Jet 3 won't go.
Have you ever solved the problem? My Jet 3 does the same thing and i would like to know whats causing it.
Thanks
Rangr90
Jan 08, 2012 | Pride Used Mobility Jet 3 Power Wheel...
Pride JET 3 Ultra power wheelchair. Problem: Batteries drain very fast after recommended charge. Things I have done: Replaced both batteries- twice; Replace On-board charger. Both items brand new. ...
check the motor brushes if they are 1/4 inch or less replace them. Next, after driving the chair for a while check the motor casing near the brake assemblies on the rear of each motor if the casing is hot then you have a sticking brake pad or pads and this can cause the excess battery drain. If you have sticking brake or brakes unfortunately the whole motor assembly will have to be changed Hope this helps
Jun 10, 2011 | Pride Used Mobility Jet 3 Power Wheel...
I BOUGHT A USED JAZZY JET 3 ULTRA WITHOUT BATTERIES AND I HAVE BOUGHT 2 NEW BATTERIES BUT AM NOT SURE HOW THE WIRES HOOK TO THEM, IF THE 2 BATTERIES HOOK TOGETHER.
Locate the two wires from the circuit breaker attach one wire (black if marked) to the negative post of the rear battery and attach the other wire (red if marked) to the positive post of the front battery. Locate the two wires coming from the power module plug with a red and black wire. Attach the red wire to the rear battery positive post and the black wire to the front battery negative post. attach the joystick to the nine pin plug at the rear of the chair and turn it on. You should have power at the joystick and the chair should work. Disconnect the joystick put the shroud cover back on grease the seat post and reattach the seat then plug in the joystick and charger plug at the rear of the chair. Charge the batteries before use and charge them overnite for the next 20 days. If you use the chair daily charge your batteries everynite while you sleep unplug in the morning. If you don't use the chair daily charge at least once per week or after you use the chair. Always put the chair up fully charged if you are going to be out of the chair for an extended time the disconnect the batteries at the large plug going to the power module Hope this helps you
Apr 13, 2011 | Jet 3 Ultra Power Chair
Need a battery charger for jet model 2904jt-24 3stage
Check around the neighborhood for others who have chairs. Any 4 amp charger for a wheel chair will work for you. You can try E-bay also. Your provider will wanna charge you a good bit for a new charger so check in the neighborhood first to borrow one until you can get one Hope this helps
Aug 22, 2010 | Jet 3 Ultra Power Chair
Sunfire power chair won't charge but lights up when plugged in
you need to have the batteries tested it is possible that if left in a discharged state for an extended time that thee batteries may be damaged and will not be able to be recharged
May 24, 2010 | Pride Mobility Products New Pride Mobility...
Chair has no power after a full charge, only allows user to go oneway before it has to be pushed Batteries are good anf fuse has been checked and changed can you help us
Many a times batteries shows you full charged but due to some reason few of the battery plates are not working, and it will only work till the charged plates get discharged.
Batteries plates turns weak or get damaged due to non use of batteries, or expiry.
Nov 02, 2009 | Jet 3 Ultra Power Chair
The battery on my jet 3 will not charge
you need to replace both batteries, their called U1 batteries (35 AMP-Hour)
Jun 08, 2009 | Pride Mobility Products New Pride Mobility...
Wheel chair will not stayed charged.
Something is discharging your battery. Possible the unit have ground fault that cause the battery lost its charge. Try to remove this ground fault & you will solve the unit problem.
Feb 19, 2009 | Jet 1HD Power Electric Wheelchair
Jet 1HD Power Electric Wheelchair Logo
224 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
