Question about Yamaha HTR-5860 Receiver
Turntable Have the htr 5860 and would like to break out the turntable to listen to the old record's again. I know there is no phono input and tried other inputs but don't get full volume for the turntable? Is there another way around it or just forget it
    Problem Solver:
  • 19 Answers
Turntables require a special input... I'd check crutchfield to see if there is something they might have to make it work better...
Posted on Apr 10, 2009
  • dhorner64 Apr 10, 2009
    I just checked out Crutchfield... WOW... they have USB turntables now... I'm not saying this will solve your problem, but at the very least you can get your old vinyl onto the puter.
How to connect a turntable connected to a yamaha a450 stereo amplifier...can I attache the a450 to the htr-6130 ?
If the turntable is newer kind you can connect it in any Stereo input like CD, VCR , etc.
If the turntable is older model you can only connect it to PHONO input (if amp has one) and make sure earthing cable is connected on Amp
Remember input is only stereo (unless your model has digital input) and select sound effect eg Pro Logic for enhanced sound,
Aug 26, 2014 | Yamaha HTR-6130 Receiver
How do I connect my turntable to my HTR-6230 receiver
It always helps when a connection question is asked that you identify all parts of the scenario explicitly.
Depends on whether or not the turntable has an internal PHONO preamp. If it does you can connect it to ANY analog input. Otherwise, you need to get a PHONO Preamp to place between the TT and the HTR.
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify and frequency-correct the tiny current produced by a Phono cartridge. Look up RIAA equalization.
Sep 14, 2011 | Yamaha HTR6260
When using tuner both speakers work but when using turntable one speaker is very low?
ONLY one channel low with a turntable?
Are you using a self-preamlified TT or an outboard phono preamp, because the HTR has no facility for direct attachment of an old-school TT.
It could be a turntable problem if you have phono preamplification most likely. Swap the two channels to prove it or not.
Try another input.
Register and download the manual for free at
Mar 11, 2011 | Yamaha HTR-5730 Receiver
I am trying to record my old vinyl records to a CD. I expected that the RCA leads from my turntable would just plug into the back of the RCD-W500C, but the manual indicates a somewhat complex cabling...
Complex? Traditional turntables need PHONO preamaplifiers (in receivers) to PREAMPLIFY the minute signal they produce to something useable.
"PHONO" is the only designated connection on a receiver that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
Just curious, priorto the arrival of the RCD, how did you play or listen to the turntable?
Feb 26, 2011 | Sony RCD-W500C 5-Disc CD Recorder
How do I connect my record player to my Yamaha HTR-3063 receiver to get audio
Since the Yam lacks a PHONO input...
If your unit doesn't have a PHONO connection you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Audio 1 or 2.
eBay always has some...
If your TT has a prwamp, that makes it a Line Level device so jack it into Audo 1 or 2. Check the TT's settings to make sure it is putting out at the Line Level.
Feb 22, 2011 | Yamaha Audio Players & Recorders
I assume that you're talking about the output from the 2 RCA Phono Jacks? Does this turntable output a "Line Level" signal, or a standard millivolt level 'turntable signal'? If it is an older 'standard turntable', then you need to run it into an amplifier that has a "PHONO" input and ground wire. This will amplify the tiny signal to a 'line level' signal that you can record or run to a computer, etc. If you do not have an older amplifier with "PHONO" input jacks, then you need to buy a separate stand-alone 'phono amp/preamp' that will boost your (tiny 10mv) turntable cartridge levels high enough (.5 to 1 volt) to record on another device. Let me know if that is the case. Good luck.
Jul 24, 2010 | Technics SL-1200MK2 Turntable
Hi there! i just bought a numark tt1650 and an ortofon arkiv cartridge, connected it properly to my old technics a700mk2 amplifier (phono, grounding and all that) but it still has a buzzing problem...
Try connecting the turntable to one of the other inputs like CD / tuner etc and see if the buzzing disappears. if so then your turntable has a built-in pre-amp so it can be connected to any input except 'phono' as this would obviously be used for turntables without a pre-amp.
a lot of modern turntables now have built-in pre-amps to compensate for certain amps and receivers made without a phono input and can now be connected just like a CD player, tuner etc.
hope this helps.
May 05, 2010 | Numark TT1650 Turntable
I get no sound when connected to CD connection
if there is no phono input,you need a pre amp to drive it.the record player puts out 5 mv from the cartridge.
a cd player is 800 mv to one volt output.
the turntable can not drive the cd input.
a phono pre amp also has a 60db gain from 20hz to 1khz to offset the -60 db curve when records are made to reduce the groove modulation.
without the bass attenuation,record grooves would have to swing 4" for bass notes.
google RIAA equalization curve for a description.
Sep 01, 2009 | Yamaha HTR-5830 Receiver
Can a turntable be hooked up to this receiver?
The Aux function is not meant for that purpose.The turntables/Record Players being way too old,now a days the amplifiers do not come with PHONO function that was specially used for playing Records/For turntables. Check if u have a phono function in your amplifier and if not then buy another amplifier with Phono function coz you need a ground wire [that comes out from the turn table] also to be attached to the amplifier and then only you can get a proper sound.
Feb 28, 2009 | Yamaha HTR-5440 Receiver
Question on Bose 3-2-1
hi! you can hook up .. first if your bose amplifier have a phono input you can put it plug and play. but if no pre amp phono input you have to buy or provide (from turntable to pre-amp phono to bose)  to heard and listen to your old vinyl.. mk2 batallion.....
Feb 24, 2009 | Bose 3·2·1 II System
Open Questions:
See all Yamaha HTR-5860 Receiver Questions
Yamaha HTR-5860 Receiver Logo
186 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
