Question about Sony Bdv-e385 Blu Ray Dvd Home Theater System Bnib Sealed
No signal with a sony BDV-385
Attached via HDMI to samsung TV
fkuk
  • 311 Answers
SOURCE: HDMI into sony bravia
plug in hdmi cable turn ps3 off then on wait and a message will apera click yes then another message appers then click yes then it should work if not connect with the red white yellow plug and then change the settings to hdmi and plug the hdmi cable in
Posted on Sep 10, 2007
  • 231 Answers
SOURCE: Sony HDZ235 HDMI
use component outputs of that unit to play on tv.Or use component or video output of sony unit and connect to cable box if available and use the source switching on cable box to change sources that way you wont have to unplu HDMI cable..By the way HDMI has a new challenger in the near future called ' DISPLAY PORT' ..
Posted on Dec 03, 2007
pazman
  • 81 Answers
SOURCE: HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Posted on Apr 08, 2008
SOURCE: sony trinitron KV-30HS420 HDMI
Yes. As long as your PC has an HDMI port as well (or at least a DVI port and a DVI-to-HMDI converter dongle).
Posted on Sep 07, 2008
mistersony
  • 320 Answers
SOURCE: KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Posted on Oct 19, 2008
Which HDMI Dongle is compatible with Sony Bravia KLV-32NX500 to make it a smart TV ? Please suggest.
As the HDMI input of TVs are only meant to accept video signals (to set HDMI specifications), any SMART TV dongle that attaches to the HDMI port is going to output a video signal compatible with the set HDMI specification. A modern TV like yours will be able to accept the digital video signal from any dongle, as it accepts all the common modern formats (1080p, 1080i, 720p, 576p, 576i, 480p, 480i)
Ref
https://www.engadget.com/products/sony/bravia/klv-32nx500/specs
Dec 23, 2017 | Sony Televison & Video
When I connect my Sony DVP-CX995V via HDMI it the TV says there's no signal.
there is interface problem between hdmi port actually signal are not reached in system ic these signaled are dropped between hdmi port & hdmi switching ic so please go to your nearest Sony service center & repair main board because this problem is in main board
Feb 02, 2016 | Sony Televison & Video
We have a Samsung Smart TV. We cannot get the signal and have installed a Digital Satellite Receiver. We have a Magnavox VCR and a sony DVD Player. We owuld like to attache the same to our TV and watch...
Depending on your Satellite receiver's output type (i.e. HDMI or Component - Red, Green, Blue) you should connect to your tv's appropriate external inputs. Example: if you choose to connect the receiver via HDMI, then you use the SOURCE button on your tv and select the correct HDMI input you have connected your device to. If connected by Component (Red, Green, Blue) then use the SOURCE button to select the correct Component input, and so on.
Note: HDMI is the best connection type - you won't be able to access your receiver from the tv's built in tuner.
As above explanation, your VCR and DVD devices should be connected to your tv in the same manner - unless it is a combo unit (VCR & DVD in one), in which case this device can be tuned into your chosen tv channel (via the tv's tuner).
Note: if you have one of the latest SMART tv's, it should already have a built-in "Hi Definition" tuner which will allow you to watch free digital tv broadcast (DVB).
Hope this helps...
"Please rate this solution"
Aug 28, 2011 | Samsung Televison & Video
I can't get a signal between my Sony Blu-Ray Disc/DVD Player and Samsung HDTV monitor. They are connected via a HDMI cable. A brief message on the HDTV reads "Not supported".
First, try to reset resolution of HDMI Sony BD output.
Unplug HDMI cable from TV and change to Component connection to reset BD output resolution.
Than after you entered to resolution menu, choose to standart resolution 720 or 480 i.
If above methode working, try to reconect HDMI cable again to HD TV.
If any problem with picture or still "Not Supported" messege appear, i suggest to change HDMI cable first.
i hope its work.
Mar 14, 2011 | Televison & Video
My Philips 42PFL5332D has quit playing my Sony Blu Ray player (model BDV-T10) it was working fine, I finished watching one movie went to put in another and it wouldn't work. Thought it was the Sony,...
Tv still working,with the incomming broadcating tv signal cable plug in,working is fine wright?Tries tv unplug,replug the tv back like an hour later.Let the tv resetting itself back to the factory setting.Go into the tv Menu goto PICTURE,go down to reset the tv Tuner signal board,that to reset the whole entire Tuner signal board back to factory setting,now all the incomming plug&play like the HDMI ports on tv,should work now.Not,than i can't tell what happen to the tv exept the tv Tuner signal board have problems,that it.
Oct 26, 2010 | Philips 42PFL5332D 42 in. LCD Television
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
The receiver is hooked up via HDMI and after about
user cable box hdmi direct access to tv hdmi input if ok ...receiver need replaced...if sam proble need replaced cable box...
Mar 21, 2010 | Sony STR-DG1000 7.1 Channels Receiver
I bought the sony bdv e500w surround sound and hooked up a optical audio to my tv and that is a sony bravia but it will not work with the surround sound when i hook it up using regular audio cords it works...
im having the same problem, except im connected via audio components and hdmi...cant get sound through the speakers when the TV is on, it doesnt make any sense.
Feb 14, 2010 | Sony Audio Players & Recorders
Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
Jul 31, 2008 | Onkyo TX-SR803 Receiver
I am trying to connect my Samsung DVD Recorder to my Samsung PS-42D7HD tv via the HDMI cable but it just comes up "no signal" on the tv - nothing at all. Also have an Olin HD Set top box with...
Hello
by befault your dvd recorder is transmiting signals via component video, so what you need to do is this connect both cable HDMI and Component or just a video cable then go into setup and then select video out via HDMI your video will go off on the screen and then with TV remote slect input source HDMI on TV and it should work fine.
Thankyou
May 09, 2008 | Televison & Video
Sony Bdv-e385 Blu Ray Dvd Home Theater System Bnib Sealed Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
